AVS › AVS Forum › Audio › Receivers, Amps, and Processors › How to upgrade Linn AV5103
post #1 of 3
This is a message from China, sorry for my english.
I bought a Linn AV5103 from ebay.
There is no DTS logo on the front panel, also can't find DTS option on OSD manual.
so I guess it's a early non-DTS version.
How can I upgrade it to DTS and lastest software.
I love its sound as a music pre-amp, don't mind it's only 5.1, but I need DTS when I watch movie.
post #2 of 3
so sad, the remote also have problem.
the red LED flash when I press key on remote, but no respond on AV5103.
Anything I do wrong?
I've reset to factory setting, but didn't solve these problem.
please help!
post #3 of 3
You have to send it to Linn for DTS if it really is an early one - the processor was changed. I not sure whether they still do that upgrade. The serial number for the change was about 1550 if I remember right.
I can't help with the remote, but try to borrow another universal remote programmed to be a Linn, to let ou find out whether it is the remote or the 5103 that is the problem.
This thread is locked
