DIY Shuffleboard - Page 3
post #61 of 69
That looks so cool. I want one, but I have never played shuffleboard.
I had better not try it, I would then need one and that is where the trouble begins!
post #62 of 69
I have played only 20 minutes, I have to adjust it with a wrench. a 3/4" wrench does not fit it...
I will let ya'll know after I get it adjusted. Oh funk, I thought these things should have only been 1K...
post #63 of 69
Hey~ I'm trying to build a couple economy level shuffleboard tables for our student center. There is a real interest in playing but I can't afford to go out and get a couple nice tables. I found this epoxy at Lowes, has anyone used it, or do you guys think it would work. Here's the link
w.eclecticproducts.com/glazecoat.htm
If not what works best...thanks for your help!
Sorry for dropping the first 2 w's in the link, it wouldn't let me post the url yet since I just signed up....
post #64 of 69
hey...anybody still on this thread??? i'm looking to build a table, but my main question is how is the playing surface mounted/attached to the cradle surface itself??? and where do the climate adjusters come in???
post #65 of 69
If any one is still on this, im currently under construction of my own table. I made the playing surface out of 20 1x3x10 maple boards, glued together and planed. I have just finished painting it as you can see in the photos, and I am just about to coat it with a 2 part hi gloss polymer.
Specific question for MercerT if he still exists on here. You said the moat you made around the first table when you poured the poly made a ridge. Is it better to just pour the poly on and let it trickle off the sides? I am worried that the edges will be slanted down and the pucks with fall of easier.
post #66 of 69
Looks great, if it comes out well Ill ask you to make me one for $999 OK
post #67 of 69
I just finished a shuffleboard / curling table myself. Got a lot of guidance from Dave's website.
I documented the process with pics. If you're a beginner like me, it may be helpful.
buildashuffleboard.com
-Patrick
post #68 of 69
how much did it cost you, and what are the boards dimensions including thickness?
post #69 of 69
The project-specific materials cost me $495. I also had to buy all the tools, because this was my first project. With everything it came in at $837.
Dimensions for the playing surface on my board are 16 feet by 20 inches. Full details of the dimensions, blueprints, pictures, etc. are here: http://buildashuffleboard.com.
Let me know if you have any other questions. Good luck if you decide to give it a try!
-Patrick
