Just wanted to get some consensus on this topic. I am planning on wall mounting my plasma in the next few weeks. Prior to reading anything about plasma wall mounting, I had the basic idea that I'll just need to drill a couple of holes on the drywall and run the a/v cables plus the plasma power cord through them. I have the PureAV power console and I want to make sure all my a/v equipment are protected by keeping them plugged into the console. Yesterday I ran across a number of threads and search topics that mentioned violating the NEC (national electrification code) if I run the power cord behind the wall. I said WTF??? Now I am trying to look for options on how to proceed without much cost. I'd like to believe that there is still a way to proceed with running the cord behind the wall but adding a little bit of safety measures along the way.
So now I am asking everyone here who has a wall mounted plasma or LCD. Cmon now, admit if you ran the power cord behind the wall irregardless of NEC. How did it turn out for you? What was the other side of the wall with which you connected the TV? Did you try to protect the power cord as you ran it behind the wall with some sort of insulation? Did you have to drill separate holes about 6 inches apart with one for the a/v cables and the other for the power cord? Do you notice or is concerned about any static caused by running the power cord behind the wall? What safety measures can you suggest to me (or anyone stubborn enough to follow NEC) in proceeding with this plan?
BTW, the house is a condo that I own. I will eventually sell this to move up and might consider leaving the plasma behind as it's already mounted in the wall.
