A local big box warehouse store is advertising an Optoma HD6800. I have never heard of this model before. Is it new or have I been living in a cave? The advertised description and features are:
The HD6800 projector is a true 720p, high-performance projector for home theatre enthusiasts. The HD6800 features Texas Instruments' BrilliantColor colour processing technology to deliver higher brightness and provide truer, more vibrant colours to the projected picture. With a 7-segment colour wheel and its 5000:1 contrast ratio, the Optoma HD6800 home theatre projector delivers great colour saturation and subtle colour details for the best image quality.
Features:
* 1100 ansi-lumens
* 5000:1 contrast ratio with ImageAI
* 720p native 1280 x 768 resolution, 1080p (1920 x 1080) compressed
* Single 1.65 cm (0.65 in.) DarkChip 2 DLP technology from Texas Instruments
* Fully HDTV compatible with 1080p, 1080i, 720p, 480p, 480i
* Supports VGA, SVGA, XGA, WXGA, SXGA+ and UXGA resolution
* NTSC, PAL, SECAM, VESA, MAC and PC compatible
* Lightweight - 3.2 kg (7 lb.)
* Noise level: 27 dB
* 1.2x manual zoom and focus
* Picture size: 0.71 m to 7.72 m (28 in. to 304 in.)
* I/O connectors:
* Inputs: HDMI, DVI-I with HDCP, component (Y,Pb,Pr), S-Video, composite video, dual-IR receivers, +12 V trigger relay
* Outputs: RS-232
* Lamp type: 220 W UHP lamp
* Bulb life: up to 3000 hours (normal use)
Features:
* 1100 ansi-lumens
* I/O connectors:
* Outputs: RS-232
