Hi guys. I've never been satisfied with any hidef TV's before, and I found this set visually standing out with my "trained eye" searching (and not finding) motion artifacts on this set. I knew nothing about this set until I noticed I couldn't see any motion artifacts on it unlike every other set in the showroom floor.
IE: I can tell you from the other-way-around (not expecting this at all, but always on the lookout for it feature-wise), this is the first HDTV that I have seen that has "hit it" for me.
Do a google search on
retina blur hdtv
and click the first link to understand how hdtv's actually make a blurred image in your retina and not on the set.
I routinely hit the stores to see if any of the displays have fixed the motion artifacting problem that exists with most HDTV sets I have seen.
The fact is, and I have proved this empirically for myself as I was a huge skeptic: the blurring from motion artifacting results from a general lack of strobing (pixels always on). The blurring isn't on the screen, but in your retina. An interesting trick to help you understand this is to take a video camera, and do a video of your TV showing objects moving around on the screen where you notice blurring artifacts. Now take that (60Hz) video and display it on a CRT, and voila, NO MOTION ARTIFACTS!
This is because the blurring isn't from the content, but rather from the fact that a continuous image is being swept across your retina in periods of 16.67 milliseconds. A result of each pixel on the screen being "always on" during the frame period as opposed to instantaneously on for a CRT.
Freaky.
Anyway, you can forget the geek talk and just remember that JVC is leading the pack on dealing with motion artifacts.
What this means is that video games and computer stuff will look great when you're playing an FPS or side-scroller, it should rock instead of being a blurry mess.
I'm not saying there aren't more expensive options that don't have solutions to motion artifacting, but I just don't know about any others, and certainly not in the pricerange I'm willing to spend.
I hope this is helpful, and I hope I don't rub anyone the wrong way. Just my 2 cents after seeing one of these sets and being
ABSOLUTELY BLOWN AWAY!!!
- AHigh
retina blur hdtv
Freaky.
- AHigh
