Originally Posted by avidslacker
I picked up a 3455/37 at Walmart yesterday and have been encountering some gripes. When I'm flipping through channels on the tuner, I keep getting the annoying time shift status bar. As much as I try, I cannot seem to get rid of some annoying bar or description that appears every time I change something (the channel, switching to HDD, etc). And when I'm recording, half my screen is blocked out by some text "Recording in process". Has anybody encountered this same problem and know how to fix it?
The Time Shift Display Bar is a major PITA. There should be some way to turn it off, or adjust its "hang time", but I haven't found it. The darn thing stays on for 25 seconds EVERY single time you use another Tuner control!! At the most it should stay on for 5 seconds. Then if you want it back you could press the Display button. I am CONSTANTLY having to press the Display button twice to get rid of that aggravating thing!!
Philips should pay me $75,000 a year to explain things like this to them. They really seem clueless about some MAJOR consumer end preferences.
