Help.
Please.
My 3455 is still usable as a DVR, but it's running into problems where the DVD drive (or more precisely, the DVD drawer) is concerned.
For a good while now the machine has been refusing to open the drawer, either to accept or allow removal of a DVD. Been getting it to cooperate by giving it a knock just above the door and that's done the trick. Maybe two days ago, tho', it started not CLOSING the door. A little push seemed to get it moving, but then that quickly stopped working. Even if I can get the door to close by manually pushing it, it doesn't catch and the readout still says "blocked".
Now no way to play DVDs or record on them.
I have plenty of stuff on the hard drive (which is working fine), some of which I'd like to still eventually put on DVD. It works fine with analog cable and also with a digital OTA converter box, so if this problem with the door can be fixed, that's all it'd need.
Has anyone had any experience with getting these machines fixed? (Maybe a new DVD drive put in place of the old one?)
Please.
