Hello everyone,
I got a DN-191H a couple of weeks ago and I am relatively happy with it. I like the image quality when using the upconversion ports and it plays the .avi/divx files nicely, without stops or gaps. However, there are some things that are cutting down on my satisfaction with this player and being relatively new with it, I have a couple of questions for the hardcore users.
First, is there any way you can keep the aspect ratio of a divx/.avi file? I have some files with 2.35:1 or so image compression and they would look stretched
on a 16:9 (which is roughly 1.78:1) screen. If someone knows of any setting that would keep the original aspect ratio, I would be grateful.
Also, my TV only has a DVI input port and therefore I need to use a HDMI/DVI cable and get the sound on the audio cables. However, even though the TV specs are stating that the DVI digital input works together with the audio analog inputs, I can't seem to make it work. I'm wondering if this could be because of the player itself, I was thinking that outputting the digital signal through HDMI might not allow the analog audio outputs to be enabled in the same time
. This is right now quite a dragdown, because even though the component cables allow the upconversion, I can only play the commercial DVD's at 480 res through component, which is not that much of a quality gain. Anyone tried HDMI/DVI successfully?
Thank you in advance for the help.
