AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide - Page 418
post #12511 of 42717
The Keyspan USA-19HS USB/Serial adapter appears to work fine when used with Windows XP, on Bootcamp, on a Macbook.
The driver that came with it is 3.4. The latest driver on the web site is 3.7s. I initially loaded 3.4 and then updated that to 3.7s which worked without issues in the Bootcamp environment, but produced some unexplained complaint in the Parallels environment.
With the 3.7s driver, Live Video Settings Editor works without a hitch to Get and Load the Video Source Adjust menu settings.
So I did a Load Saved User Settings (to get the Video Source Adjust stuff back), used Live Editor to save that to the Mac, and then re-did the firmware install. It too completed without complaint. Then the 30 second power cycle, reload factory defaults, reload saved user settings, and Open and Load the saved Video Source Adjust settings from the Mac. Again, no complaints. For good measure, I did another 30 second power cycle.
Unfortunately, the Video Source Adjust menu settings still revert to defaults when you power cycle.
I'll just have to try to work this with Anthem in the morning.
But for folks planning on using an Intel-based Mac, my advice now would be to use Windows XP on Bootcamp with the Keyspan USA-19HS adapter.
ETA: This Mac itself is running Leopard 10.5.2, fully updated, but I doubt the Bootcamp environment depends on any of that.
--Bob
post #12512 of 42717
Well the new load of V1.31 has not fixed anything, but it has broken something new that worked under the previous load of V1.31. One of my S-video sources is no longer recognized. Curiously, the Info panel shows the correct input resolution, but the status line above it says No Video.
I suspect I'm going to need something like the Flash Eraser program from Anthem to force a completely fresh reload of V1.31.
Ah well -- I'll be on the phone with them in the morning.
--Bob
post #12513 of 42717
Happy April 1st, 2008.
post #12514 of 42717
Question for all of you ARC users..
When Using the Advanced mode, and inputting your targets, you will notice that the Default Frequency is like 5000hz..
Is this for a reason? I would think that 20000hz should be the correct value, as your room would effect some or all of the entire range?
If I did set it to 20000hz, am I now using up more EQ power to cover the entire range, therefore not as accurate?
What setting do most of you leave it at? I will use 80hz for the all channels, but the room gain, freq. have me wondering..
Thanx..
post #12515 of 42717
I have an AVM50 and am looking for improvement on the sound side of things. I have the chance to upgrade to a new D2 w/ARC by trading up my AVM50 for ~$3800 (paid $4500).
I have recently upgraded my amp from an Emotiva MPS-1 to a P2 running the fronts (Emotiva still runs center and surrounds) and am impressed with the improvement in sound. I have Focal Profile speakers in a 7.1 setup with a new Paradigm Signature Servo Sub connected to a Velodyne SMS-1.
I do not have a super CD player or Blu-Ray player, but do use a Denon 3910 for SACD/CD and DVD-A/DVDs and the PS3 for Blu-Ray. I also listen to a lot of stuff on iTunes (very convienient) thru my DIY music server.
I know the AVM50 and D2 are identical on the scaler end (I am super happy with that), but using a D2 w/ARC matched up to my present equipment in an untreated room, would one expect an improvement in sound for music? movies?
post #12516 of 42717
Thanx..
To be honest I haven't even looked at the Advanced ARC-1 option.
What benefits does it give you in running ARC that you miss when running the automatic mode?
Cheers,
Richard
post #12517 of 42717
Cheers,
Richard
Using the Advanced mode, since I can set crossovers different for MUSIC/MOVIE calibrations this is useful.
I find in my system, that setting all speakers to 80hz, then re-calculating, gives my system better sound...
post #12518 of 42717
I think you would notice an improvement in sound on both movies and music. The ARC would help a lot as would the better Preamp section of the D2.
post #12519 of 42717
I was completely duped!
I spotted all the other April Fool's jokes today, but not this one. Very nice. Very nice indeed!
post #12520 of 42717
As I have said its April 2nd here in the Philippines and I was caught off guard. I was wondering it it were true, how would you change your forum name? LexiconMC maybe?
post #12521 of 42717
What a relief
Better take down the post before some read it and take it for serious
post #12522 of 42717
Try this. Leave your BR player outputting 1080p/24 (Native disk resolution) and using the D2 Video configurations, have one at 1080p/24 and one at 1080p/60. (Use Configs 3 & 4 if they are not in use and you don't want to mess with any you already may have set up if need be).
Start the movie and go into the D2 setup menu > Video Output and try each. If the /60 works and the /24 doesn't then your projector probably doesn't accept /24.
In either case once you figure it out, send the 1080p/24 (native Rez) to your D2 and let the D2 do the scaling. My HP Pavillion MD658N (or something like that) doesn't accept /24 either so this is how I set it up and its amazing.
As a few general rules (for me anyway):
If you can send the D2 the native rez, do so and if needed let the D2 do any scaling, deinterlacing or whatever.
If the source is interlaced (like SD DVD, My SAT box, My cable Box) again choose native or at least one of the xxxxI/xx (Interlaced Options) and let the D2 again do the processing up to 1080p/60.
Cheers,
Richard
Cheers,
Richard
Thanks Richard,
Im gonna try this today and I'll let you know. I think the Sony Bravia 52 inch is not 1080p 24 but 1080p 60 and thats the problem.
I seem to remember when setting up I chose as an output 1080p 24 and had no image and when I changed to 1080p 60 the image came up.
Is it an automatic thing with the Sony Bravia ?
cheers,
Bruce
post #12523 of 42717
Well UPS ground made it in 1 day, my ARC is out for delivery. I guess my workday will be shortened.
post #12524 of 42717
Originally Posted by Bob Pariseau View Post
It may be important that I'm using a DVI display for output.
--Bob
I have been following your 1.31 Story.
When you talk to Nick - You might find your statement above is the PROBLEM.
post #12525 of 42717
--Bob
It is available on the Anthem SW Site.
post #12526 of 42717
Originally Posted by Tim Winders View Post
That's funny.
I didn't realize the Lexicon didn't have a scaler. That's a good and a bad thing depending on your point of view and other equipment.
NOT ONLY NO SCALER - but it can only handle 1080i
post #12527 of 42717
Well the Sony Bravia does not accept 1080p 24 as I get a check device message when I send using this
So I have the BD player set to 1080p 24 output in to the D2 and the D2 changes it to 1080p 60.
Is it better than straight 1080p 60 straight thru ?
post #12528 of 42717
YES
post #12529 of 42717
Really? That's interesting.
You missed an exciting day yesterday Dr. Z.
post #12530 of 42717
I had to work - but I read All Bob's Story and I did see the April Fools Joke
post #12531 of 42717
OK. That's what I was afraid of.
I cannot duplicate the problem you are having. It might be a hardware compatibility issue. Unforutnately, as you've probably already guessed, you'll have to talk to Anthem on this. I hope a software update can fix this. I don't know if others with "older" D2s who have upgraded have checked their custom video settings to know if they get changed through power cycles.
I have not seen this issue.
post #12532 of 42717
It's pretty straightforward Tim, as best I can tell, anything changed from the defaults gets returned to the defaults.
For an HDMI source, make changes to Video Source Adjust / Picture / Color or Tint for example. For an S-video source make changes in Picture / Video ADC. Also set Scale Out for any source to anything other than Anamorphic.
Now power cycle. When you are back up all those changes will have vanished if you are having the same problem I'm having.
Note that it is ALL changes for ALL inputs that are compromised here -- not just the input in use when you powered down or powered up.
--Bob
Bob - did you try making video source adjustments manually from the D2's menu and save on the D2 rather than using Live Video Settings?
post #12533 of 42717
The MC-12HD handles 1080p at 24/50/60.
Sanjay
post #12534 of 42717
Yes. No luck that way either. The changed Video Source Adjust menu settings do not survive a power cycle.
--Bob
post #12535 of 42717
--Bob
Good luck with your call to Anthem today.
post #12536 of 42717
I'm waiting for a return call from Nick now. I didn't catch the name of the guy who answered my call, but he said he had not heard of any other reports of failure of the Video Source Adjust settings to survive a power cycle.
I must say, I'm surprised at the imaging improvements for SD-DVD and HDTV compared to V1.11. I haven't had a chance to watch any SDTV critically yet. The sound field for DD 5.1 content appears to be more natural as well, although there could be some wishful thinking in there since that's harder to judge.
But a friend also immediately noticed the imaging improvement in SD-DVD -- he assumed I'd made new calibration adjustments.
The V1.11 video was so good, I wonder what they might have changed and when they changed it?
--Bob
post #12537 of 42717
[...snip...]
The key to the question is the phrase untreated room. Typical home listening/viewing rooms have a lot of acoustical problems. It is likely you will experience a significant improvement - especially since you have great downstream equipment.
Most people have never heard a correctly treated room.
post #12538 of 42717
--Bob
I thought the SD DVD output was exceptional from the beginning of my D2 experience. Of course, I started with 1.20.
In fact, it was so good that when I first got the PS3 and we put in a scene from Harry Potter, my oldest son said "Blue Ray is a ripoff". For the next 2 weeks, every time he say a Sony BD commercial, he'd scream that.
Now we don't watch too many SD DVDs. The ones we watch are from TV shows, so the quality isn't so great to begin with. Now, everytime we put on a HD TV show or BD disc, he says "wow the picture is so amazing".
FWIW, the BD version of Blue Planet has some exceptional HD footage.
post #12539 of 42717
Okay Bob you are getting me very interested with your observed improvements to the video, hope you get your settings issued resolved soon.
I am sitting here with my AVM50 with version 1.06, do I do it, no, should I try it, NO.
For you guys that have access to Anthems test software web page, do they have older versions of the software there?
I would really like a copy of 1.06 to go back to in case disaster strikes.
post #12540 of 42717
Good luck setting it up.
