AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide - Page 478
post #14311 of 40764
Originally Posted by Bob Pariseau View Post
See Appendix A of the manual. There are 3-key sequences you can program into your remote for directly selecting each of the source inputs.
--Bob
Thanx!! - Mass
post #14312 of 40764
I posted and earlier post about ARC 1.2.2 setting the crossover for my sub to 120hz. I was concerned about the sub being directional. Well, that concern is no longer a concern. I watched "Live Free Die Hard", "Casino Royale", "3:10 To Yuma", and "300", and all of them sounded great. The sound was just completely outstanding. The bass was not boomy, overwhelming, or loud. It was just perfect. I guess the ARC really does know what's best. After all when it comes to sound, it's not about what you see; it's about what you hear.
post #14313 of 40764
Originally Posted by ditcin View Post
Bob,
I redid everything - when it was time to load the new settings it went fine until the final speaker settings, that's when the D2 shut down and error screen came up (same as all the other times) Along with that error message a prior message stated that no changes were made due to.... then the error screen i sent you pops up.
This is VERY ANNOYING. I know the cable that came with the unit is working since the upgrade for the D2 went fine. I'm using my PC so I know it's not a slow laptop or battery issue. I disconnected the HDMI cables from the D2. I even made sure my Virus scan was off. ( also did it with it on to see if that would cause an issue)
- Scott
BTW- I deleted the previous ARC saved settings on my PC with every new so I wouldn't make the mistake of re-loading old ones.
I think you've done everything you can try on your own, short of moving the results file to a new computer and trying the ARC Upload from there.
I think you need to give Anthem tech support a call on Monday.
The verification of the uploaded speaker volumes was something that was added in V1.31c, so it's been working for a while for many folks, but the thing that's really puzzling to me is why ARC is even TRYING to set a -19.5dB value for your subwoofer. Anthem may need to have you email them your ARC results file to see if it is corrupted somehow. Be sure to explain to them what you did (the procedure I set out for you) to pre-set the internal volume in your subwoofer prior to doing the ARC measurements.
That procedure SHOULD result in ARC trying to Upload a subwoofer volume level near 0dB. -19.5dB is way far off.
NOTE: The test tone sweeps that ARC uses are not particularly loud, and in particular the subwoofer test sweep will sound fairly quiet (particular since much of the frequency it is sweeping through is subsonic). So the lower test sweeps you are now hearing from the subwoofer portion of the ARC measurements make sense.
Have you double checked that the Setup / Level Calibration / Noise Level setting was still correct (as per the procedure I set out for you) before re-doing the ARC measurements? I.e., is there any chance this ARC failure is altering that setting as well so that you have to manually re-set it before re-running ARC measurements?
--Bob
post #14314 of 40764
Bob,
After I did the level calibration/noise level stting (as per the procedure you suggested ) I saved those settings as "Installer", then I shut off the D2 unit, waited, then turned on the D2 again to check if those setting were still in place - they were.
After I re-did the ACR I checked the setting each time and found them changed EG: the Left Front Speaker original set to 0 was now -5
So yes, I had to re-set it back to the Istaller's Setting I saved it in to start fresh. I also tried it without putting in those Installer's Settings and just over wrote during the next ACR - it was alway overwritten.
The only thing I have to do is delete the ARC from my PC and re-enstall it and try again from the Installer's Settings in hops the ARC program didn't install correctly. This seems strange since it is doing eveything up to the point of installing the ARC speaker settings, but I don't know what else to do. I know one thing, I'm more than annoyed and as of now wouldn't recommend the added expense since it seems like such a picky and sensitive add-on. My PC is just a year old, quite powerful, and fast. I'm not paying an additional $40 to get what I need to use my laptop. At that point I would just ask for my money back.
This turned out to be a birthday present to myself and it stinks.
Thank you Bob for being there and trying to sort this out. I will keep you updated after I deal with Anthem on Monday.
All the best,
Scott
post #14315 of 40764
Bob,
All the best,
Scott
Have you tried re-installing 1.33 for your D2 and 1.2.2 for the ARC? If you have not, then you might want to give that a try. What you are posting is a first; but, as the saying goes, there's a first time for everything. I understand that your are upset and annoyed right now; but, don't give up. The end result is very, very, very rewarding. You have run into a glitched that I am sure can be resolved. But, for now, I would say to re-install v1.33 and 1.2.2. Good luck.
post #14316 of 40764
I did the ARC upgrade tonight and it worked without a hit. Used a laptop with Vista and the Keyspan USB to RS232. Yahoo.
The biggest thing that I notice is my surround sound speakers are much more noticable in the room. The bass is a little to low for my liking, but I did a quick 5 measurement, so I am sure I have some tweaking.
post #14317 of 40764
ditcin,
If you haven't had contact with Anthem tech support before, I think you are in for a nice surprise. They'll be all over this one. What you are experiencing is highly unusual. I don't think we've had any similar reports here.
They WILL get it working for you. Hang in there.
And by all means keep us informed of the progress.
--Bob
post #14318 of 40764
If you haven't done any room treatments for bass room modes, odds are the bass you are "used to" contains some significant room resonance peaks. The boominess that those produce may not have been so bad as for you to think your bass was bad, but they *WILL* color your perception of what *PROPER* bass should produce.
The point is, by all means do a careful re-measure and check out the ARC curves for signs of trouble, but be prepared to live with the ARC produced results for a while before you start tweaking ARC's calculations. You may discover that your preconception about what constitutes enough bass is not, in fact, as good as what ARC produces for you with real movie content.
--Bob
post #14319 of 40764
Hello,
I am the fresh owner of a new D2 and have some issues with video.
Your help is much needed.
Before I go and read the extended articles written here about video I would like to ask a question to the more demanding users around here.
I have been using my HTPC connected straight to my projector via an HDMI <> HDMI cable and a DVI > HDMI adaptor on the HTPC's end.
The picture was noiseless, crisp, natural. And I spent some hours getting this result with calibration material.
Now, thru the D2, the picture is grainy, noisy, not natural. And the motions on screen are sometimes jerky and have jagged edges.
Before I go into reading and experiencing I have a question of principle:
- If you are a video purist that owns a D2 (and of course there must be some) did you manage to get an equally good or better picture through the D2 and how?
Just a few precisions.
- HTPC: using nVidia 8600GTS display adaptor, 1920x1080p/24fps output
- D2: set for 1920x1080p/24fps input and output
- HTPC to D2 connection: DVI <> HDMI high-grade 1080p compliant cable
- Projector: Sharp XV-Z20000 using HDMI input and 24 fps compliant firmware
Thank you
P.S: Just noticed on the docs that I should only input Interlaced signals. Didn't succeed to set my nVidia to 1920x1080i/24 though. Only 1920x1080i/60.
post #14320 of 40764
--Bob
Thanks Bob,
When I was talking about tweaking, was running the ARC in a differn't location then the quick 5 that I did.
post #14321 of 40764
How big is the Video Souce Adjust / Patterns menu (under the "7") on your screen. Mine is about 1/4 screen size and is centered. It seems small and can be hard to read.
--Don
post #14322 of 40764
--Don
The Video Source Adjust menu itself is of fixed resolution so it can be a bit hard to read on a 1080p display. This is a limitation of the video processor chip that produces that menu (i.e., it apparently can only display that at one resolution that has to work for displays from 480 on up). The usual workaround is to get closer to your display to read that menu until you get familiar with what it says.
The test patterns themselves (Video Source Adjust / Patterns) should FILL your specified Setup / Video Output resolution, regardless of which resolution you have chosen. If the test patterns are not filling your screen then there is something screwy in your setup.
--Bob
post #14323 of 40764
Originally Posted by xtrips View Post
Hello,
Thank you
It is not correct that you should send only interlaced signals to the D2. The rule of thumb is to send to the D2 as close as you can get to the original source content. I.e., let the D2 process it from there. For normal movies off a Blu-Ray disc, for example, that would be 1080p/24 (whether or not you also happen to have a to /24 capable display). For standard DVDs and SDTV broadcasts (in the US) that would be 480i. For HDTV broadcasts that would be either 720p or 1080i depending on what the channel is currently broadcasting.
The trick to using the D2 properly is to FIRST calibrate your display to best reproduce the video generated by the D2 (as shown by the D2's internally generated test patterns). After doing that, then refine the video with each source device using the input setting adjustments in the D2. It is the D2's job to convert all inputs to that one "best" output to your display.
[CAUTION: There is a bug in the current D2 software such that the Color and Tint controls for the currently selected input source (Video Source Adjust / Picture for each input) may *INCORRECTLY* alter the output of the D2's internally generated test patterns (Video Source Adjust / Patterns). When using the D2's test patterns to set up the levels in your display, you need to temporarily reset the D2's input Color and Tint controls for the currently selected D2 input to their default values (50). Also note that applying Gamma Correction inside the D2 (Video Source Adjust / Output) *CORRECTLY* alters the D2's test patterns. I.e., if you apply Gamma Correction inside the D2 then you must iterate back and re-adjust Brightness and Contrast in your display until you find the sweet spot setting for Brightness and Contrast in your display and Gamma in the D2. EXAMPLE: Raising Exponential Gamma in the D2 darkens the video output of the D2. You adjust for this by raising Brightness in your display, and then also refining Contrast as these 2 controls usually interact.]
If you have an HTPC you probably already know this, but just in case, 1080p/24 should only be used if the original source content is "film based", that is, if the original content was recorded at 24fps.
There is no good way to convert video based content -- shot with a video camera at 30 or 60fps, or computer animation generated at 30 or 60fps -- into 24fps. Doing so is guaranteed to produce jerky looking results.
[CAUTION: Please note that /24 is actually a short-hand for the TRUE frame rate used when film-based content is presented as video. The exact frame rate is actually 23.976 fps for technical reasons. Your HTPC, being a computer after all, may be able to send out both 24.000 fps and 23.976 fps. If so, 23.976 is the correct value to use. A similar thing is going on with 480i/60 broadcasts.]
"Film based" content coming off a normal, Blu-Ray, movie disc is 1080p/24 if your player allows that form of output. [More precisely, 1080p at 23.976 fps.]
Live TV Blu-Ray discs on the other hand -- typically live music concerts these days -- are captured with a video camera and come off the disc at 1080i/60. You must not try to convert such content to 1080p/24.
"Film based" content broadcast for TV (in the US) has been raised from its original 24 frames per second of film speed to 480i/60, 720p/60, or 1080i/60 via the telecine process that duplicates selected fields (interlaced half frames) of the video in a specific cadence. It is possible to detect and remove the repeated fields and retrieve the original /24 from that /60 stream but the Anthem does not currently do that. Unless your HTPC does that properly, you'll need to use 480i/60, 720p/60, 1080i/60 or 1080p/60 when sending such content to the Anthem. This would include playing movies off of standard DVDs for example -- which would then be sent to the Anthem as 480i/60 if the player allows, even when playing a film based standard DVD.
Normal TV shows on the other hand, are "video based" and must be left at /60. This would include regular TV shows sold on standard DVDs.
Notes on video calibration basics for the D2 can be found in the "Video Calibration for non-ISF Techs" post which is in the collection of links in the first post of this thread.
Notes on frame rates and such can also be found in those collected links.
Finally, be sure you have updated your D2 to the latest firmware (V1.33 at the moment) as there have been significant video imaging improvements compared to older firmware. The latest firmware can be downloaded from Anthem's D2 web page.
--Bob
post #14324 of 40764
to: massimo n.
i enjoyed the h/t pics, which triggered a question. did you not "apply" any sound attenuation devices to your room? i am thinking of bass traps, wall panels, etc.
my room is 16 x 22, and i am in the attentuating process. great mystery and confusion - been reading for months -a lot to discover. but, on topic, the attenuation issue regarding your h/t. any insight is appreciated.
this wed my arc comes in(well, it is promised for then) thense the upgrade to the D2, do arc, be amazed at the results.
walt
post #14325 of 40764
Just upgrade to 1.33 and it all went fine. However, sometimes (regardless of source) I hear annoying beeping from the speaker(s) until it picks up the sound/video from the source. It's weird...this morning, if i turned the volume (without the source playing yet) it would beep from the surround left speaker. What's that about?
Upgraded in anticipation of receiving my ARC kit this upcoming week. Never had this on previous version I was running.
post #14326 of 40764
Give Anthem tech support a call tomorrow. It should not be doing that.
My guess is they will ask you to try re-installing V1.33 on top of itself as a first step just on the off chance that some portion of the install got corrupted. Note in particular the install instruction to make sure there are NO POWERED HDMI CONNECTIONS to the D2 while performing the firmware install. I recommend you remove wall power from everything other than the D2 and the computer during the install just to be sure.
They will likely also ask you to check the Muting setting in the Setup / Source Setup menu for each source to see that it didn't get altered by the install.
And Room EQ should be OFF in each of your Setup / Source Setup menus until after you do your first ARC results Upload.
What you are hearing COULD indicate a hardware problem in your D2, but work with them to eliminate software as the issue first.
--Bob
post #14327 of 40764
Bob, thank you. There is so much info in your post I will have to print it to work it out.
I admit i didn't get everything and I will need to make some research.
Most of the movies I see are MKV's or BD all based on 24fps (23.976).
So I think I will optimize everything for this fps and live with it for the old avi.
You didn't write it expressly but I suppose that you think that the D2 is capable of improving my HTPC's output in the end, after the tuning, right?
post #14328 of 40764
I don't know how far you went with your HTPC. There are some HTPC setups out there that easily rival or exceed the best standalone video processors.
Odds are, however, with proper setup you will be able to get at least as good through the D2 as you got with the HTPC directly connected.
--Bob
post #14329 of 40764
--Bob
That's what i wanted to hear to put myself in an optimistic mood.
I'll take your word for it.
Let's start to work.
post #14330 of 40764
Bob,
- Scott
Scott,
For what it's worth, the same thing happened to me when I tried to upload my settings. I must have tried at least half a dozen times all in, including giving up and starting all over again the following morning. Always the error message after the D2 shuts down in the middle of the uploading process.
Eventually, I copied the Correction file onto another PC and tried again. This time, it went smoothly first try. I still don't know why the first PC failed to upload. And I've always been using it to update the D2 firmware without a hitch previously.
Maybe you should try to upload with another PC too!
Ben
post #14331 of 40764
--Bob
Bob,
My nVidia control panel shows that I successfully created a custom resolution of 1920x1080i/23.976fps and applied it. Nevertheless the D2 video processor shows an input of 1920x1080i/50fps.
What can it be? Any idea?
post #14332 of 40764
to: benleeys. you mentioned that you used a second pc to "fix" the loading issue.
Question #1: were either of the computers mac based, running bootcamp (ala bob)?
second question: software the same in each (is vista on both, or xp on both )
i have yet to order windows for the D2 / ARC process, and am looking for user issues with one or the other of the windows os's. various postings have suggested either is ok, but, then, up jumps the exception.[could be you]
( turns out the o/s issue could be more than a passing question, as i recently found out that apple is having a major problem with the mac pro 15" laptop - zebra stripes, etc. the post at apple is long, and worldwide.)
thanks!
walt
post #14333 of 40764
Bob,
Yes. I don't believe that's a valid input resolution for the D2. /50 is as close as the D2 can handle for that. During the HDMI handshake, the D2 is undoubtedly telling the nVidia that, and the nVidia is modifying the output you set to the closest thing the D2 will accept.
What you want to use, I suspect is 1920x1080p/23.976 instead.
[An interlaced video rate of 1080i/24 is the equivalent of only 12 full frames (2 interlaced fields/frame) per second.]
--Bob
post #14334 of 40764
Bob,
All the best,
Scott
I had a similar problem and after many troubleshoothing sessions with Nick, he suggested to go in the D2 menu 11 (RS-232) and to make sure of the followings:
Tx Status = OFF
Flow Control = None
baud rate set to = 19200
In my case I found that the Tx status was set to On. After changing it to off, the ARC file could be uploaded correctly to the D2.
Good luck....I hope this works for you.
post #14335 of 40764
The RS-232 settings Nick asked for (in Setup / Triggers, IR, and RS-232) are the factory default settings as well.
SEISMO, did you ever figure out how your TX Status setting got changed from the factory default in the first place?
--Bob
post #14336 of 40764
--Bob
No not really (can't remember for sure), but it could very well been my own action.
post #14337 of 40764
I have been a D1 owner for several years but did borrow a D2 to test in my home a few months ago. When I picked it up from the store (unit was a display unit) and put it in it had more video quality issues than I care to list. I tried to work it into a good looking picture for about 45 minutes with limited success. At that point I reloaded factory defaults and saw a huge improvement. From there I got a very good picture establishing for myself that the D2 VP does a much better job than the scaler in my Infocus 777.
No doubt another customer had twiddled with one or more settings on the sales floor and had gotten the unit more out of calibration than I could readily fix. Depending on where you are in getting this worked out you might consider a reset and fresh start in case you unit came in with some odd settings in obscure places.
Hello,
Thank you
post #14338 of 40764
I had several problems uploading Arc and I did restore factory defaults before. Maybe on some units it is setting RS 232 to on instead of off. Mine was on and after turning it off I had no problem. I used a Mac Mini with XP,bootcamp and a keyspan adapter. I very seldom use that menu and don't ever remember changing the setting. Possible I did but I sure don;t remember it. By the way it set my sub to crossover at 105,fronts 40, surrounds 45, center 70, rears 80. Sounds excellent.
Dick
post #14339 of 40764
Dick
Why did you set your sub to 105 and not 80 Hz to overlap with the rears? I will try something like that just for fun.
post #14340 of 40764
This is a question about the TWC SA8240 and using it with the D2. I had an SA 8300HD and it worked fine with the D2. Then TWC did their upgrade to a new software. The sound didn't work on analog channels with HDMI. So I went to a digital coax. Everything was fine.
Well the SA8300 went south this weekend.(it died) So I had to swap it for a new one. Everything worked when I plugged it in using HDMI. But when I switch to another source like Blu-ray player and then back to the SA 8240, no picture. Sound will work through the digital coax but no picture. I rebooted and pulled the HDMI out then put it back in and again the picture worked.
But when you switch sources and come back the picture is blank. Seems like the SA 8240 HDMI doesn't do the handshake with the D2 like the SA 8300HD did. Anyone have this problem who owns a D2? Is the only way to fix this is to go back to component cables? I'd hate that. Seems like there are a lot of problems with the new software Mythnos(sp?)that TWC is now using. They said they are not doing any firmware upgrades for this new software till the roll out complete and every single HD costumer has it.
