Originally Posted by Bob Pariseau
Try this:
Make a copy of your current ARC measurements file (so you don't risk screwing it up).
Run ARC in Advanced mode. Open the copy file (File menu). Go to the Targets window. Is your Room Gain now showing as 0?
In the Targets window, do an Auto Detect.
Is you Room Gain still 0?
The "Room Gain" is detected by the ARC application as a preliminary processing step after you take the Measurements and before you do the Calculation. It shows up in the Targets window after you complete the Measurements. An Auto Detect causes the ARC application to re-evaluate the currently opened Measurements file and reset the Targets (to the values ARC thinks are best) according to what it sees in there. I.e., you can use Auto Detect to undo any manual Targets changes you might have made.
A Room Gain of 0 strikes me as very unusual. I don't think we've seen any other reports of it here. You may want to email your ARC measurements file to Anthem tech support and ask them to take a look at it.
--Bob
Try this:
--Bob
Bob,
This is the same thing with me, a room gain of 0.000 most of the time. It went up to .17 and maxed out at .34 with some other measurement cycle.If I don't force a room gain of 3 or 4 dB, the Bass sounds thin but still tight. I will also send my ARC results to Anthem for further analysis.
