AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide - Page 489
post #14641 of 40739
Originally Posted by AnthemAVM View Post
does the 40 and 50 have the horsepoer to handle arc? if this is the case,when is the extra chip in the D2 going to be used?
I was wondering the same thing.
post #14642 of 40739
Hopefully, for dtsHD MA, Dolby TruHD and........DSD.
post #14643 of 40739
It would need a new (expensive) dual DSP board as part of the upgrade.
post #14644 of 40739
Originally Posted by ASW View Post
I use a SIIG PCMCIA card all the time with no problems.
http://www.newegg.com/Product/Produc...82E16839150016
Thanks for the link. The picture of the card doesn't look like a db9/rs232 jack, I assume it is a regular jack that takes a normal serial cable, right? May just be the picture but it looks like a plug in jack.
post #14645 of 40739
should be cheaper than upgrading to a D2.
John
post #14646 of 40739
Ah, I discovered that the serial jack plugs into the port via a short adaptor cable.
post #14647 of 40739
Is that even possible?
It would need a new (expensive) dual DSP board as part of teh upgrade.
What upgrade?
post #14648 of 40739
Rob,
We are speculating.
The AVM-40 and the AVM-50 as currently shipped do *NOT* have the necessary processing power to handle ARC. A hardware upgrade would be needed to add the additional DSP.
An audio DSP upgrade (adding the additional DSP ARC needs) would not be sufficient to enable internal decoding of the lossless Blu-Ray bitstreams in either the AVM-40 or AVM-50. Those bitstreams can only be passed over HDMI V1.3. HDMI V1.3 requires newer HDMI port chips than are currently in the Anthem products. The HDMI driver chips are on the video board. So you would also need to replace the video board (plus, most likely, additional audio processing portions as well). The video board is the single most expensive replaceable component in the AVM-50 and in the D2. So I think it much more likely Anthem will offer an ARC-specific audio DSP upgrade for the AVM-40 and AVM-50 that has nothing whatsoever to do with decoding the lossless bitstreams.
--Bob
post #14649 of 40739
Originally Posted by Bob Pariseau View Post
Rob,
We are speculating.
An audio DSP upgrade (adding the additional DSP ARC needs) would not be sufficient to enable internal decoding of the lossless Blu-Ray bitstreams in either the AVM-40 or AVM-50. Those bitstreams can only be passed over HDMI V1.3. HDMI V1.3 requires newer HDMI port chips than are currently in the Anthem products. The HDMI driver chips are on the video board. So you would also need to replace the video board (plus, most likely) additional audio processing portions as well. The video board is the single most expensive replaceable component in the AVM-50 and in the D2. So I think it much more likely Anthem will offer an ARC-specific audio DSP upgrade for the AVM-40 and AVM-50 that has nothing whatsoever to do with decoding the lossless bitstreams.
--Bob
That's pretty much how I understood it as well Bob, I just wasn't sure if Kal was serious or joking.
post #14650 of 40739
Does anybody here know if the D2's XLR audio outputs are truely balanced, ie whether the audio section design of the unit is of balanced circuitry. I can't seem to find mention of this information anywhere and am just wondering if it's worth to invest in XLR cables since my power amps are of balanced design.
-Ben
post #14651 of 40739
-Ben
This is from Anthem's site:
Q1: Are the XLR connections on the amps and preamps truly balanced?
A: Yes. All three pins of the XLR connection are part of the circuit, which means it's a real balanced connection. (If pin 3 is sent to ground or left open, as is sometimes the case, then an XLR jack is an adapter, not a balanced input.) The purpose of balanced connection is cancelling out certain types of interference and ground loops.
post #14652 of 40739
The card has a RJ-45 jack and comes with a RJ-45 to serial cable.
post #14653 of 40739
befor providing dtsHD MA, Dolby TruHD and........DSD to the AVM users they will have to provide it to the D2 users.
post #14654 of 40739
With an upgraded HDMI input, it might be. Note smiley:
post #14655 of 40739
1. I was referring to the D2.
2. I inserted the smiley intentionally.
post #14656 of 40739
But, of course, this does not really answer the question. One can drive the 3 pins with an SE>bal chip or with an SE>bal transformer.
post #14657 of 40739
-Ben
It is NOT truly balanced. I believe this is in the faq for the D1/D2 on the website, but it was also posted elsewhere, I just can't remember where. That doesn't mean that xlr cables aren't worth it. "Truly" balanced means having double the components in the balanced circuit and not many ssps will do this.
post #14658 of 40739
Our Far Flung Correspondents are starting to send in info from dealers:
There will be an ARC Upgrade at least for the AVM-50.
Based on other info, it looks like it will also be available for the AVM-40. Apparently it will NOT be available for the AVM-30 (unless of course you upgrade the AVM-30 to an AVM-50). I don't know why this would be the case since ARC is offered for the D1 now, so the HDMI jacks and video board are not necessary for ARC itself. But perhaps the add-on "second DSP", required for ARC in the AVM units, plugs into the video board for power or whatever.
It looks like Anthem is perhaps as much as 2 weeks away from publicly announcing this.
The ARC portion of the upgrade will retain the D2 ARC upgrade kit pricing of $399, but there is also a hardware upgrade required to add the second DSP.
One report puts the total price of the ARC upgrade for the AVM-50 at $800 (hardware change plus ARC kit). Obviously any such pricing reports are not solid as of yet.
So far I've not heard anything which suggests the hardware upgrade would be dealer installable. I.e., it appears that you would need to send your AVM-50 in to Anthem to get the hardware upgrade installed.
--Bob
post #14659 of 40739
--Bob
This is great and it true will show again that Anthem is behind their customers and deliver when it comes to upgrade path.
post #14660 of 40739
This is great news for us little brothers(avm50). Can't wait. Now that this is looking like it will happen I have several questions.
1. I have several large cardboard Characters in my room. Should they be removed or just left to let ARC adjust to their presence?
2. My understanding is that if you run Standard for ARC, you can save a file and open it later in Advanced and recalculate to get the graphs. If not interested in the graphs, or adjusting anything after ARC is there any reason standard shouldn't be run?
thank,
John
post #14661 of 40739
thank,
John
This is not a news yet just speculation founded on rumors and based on dealer comments. It is not news until it is announced by Anthem.
post #14662 of 40739
Everything that is usually there when listening/viewing should be there when measuring/equalizing. The only exception would be noisy display devices. For example, I turn off my plasma display.
You can just run Standard. If you like it, fine. If you don't, you can use the same measurements in the Advanced mode for adjustments and recalculations. OTOH, I prefer to measure in Advanced mode since you get a "more considerate interface."
post #14663 of 40739
Is it good or bad if I make my measurements from the adjacent equipment room (opens up to the main room through an opening in one wall)? I install my laptop in the equipment room and run the mic cable besides the equipment rack. Previously, I used to do it inside the main room but sometimes, found myself in the way between the speakers and the mic and I used to move around to minimize the effect.
Is there a concensus on this?
post #14664 of 40739
Yes but we can dream
John
post #14665 of 40739
Thanks Kal,
gives me something to ponder until a REAL annoucement is made.
John
post #14666 of 40739
This is from Anthem's site: ...........
Thanks, ninja, for pointing me to the site.
That's what I thought (and was afraid of) after reading the FAQs. Am not really sure that it's worth the expense if it's not truely balanced.
post #14667 of 40739
A good idea. Removing all random, unrelated noise, such as might come from the PC and the user is a good idea.
post #14668 of 40739
Why? The major value, imho, of balanced connections is what lies between the output stage of the source and the input stage of the sink. The advantageous CMRR of balanced connections is accomplished by the setup in the D2 if you need it.
post #14669 of 40739
You need to have a serial connection to the D2 and of course the microphone connection as well. That limits where you can place your computer during the measurements.
In my case, I use a laptop that is set on a coffee table between the D2 and the listening positions. My laptop produces no fan noise.
I use a wireless mouse so that I can step well away from the computer (and out of the path of any of the speakers) before triggering the measurement at each new mic position.
--Bob
post #14670 of 40739
thank,
John
Set up your room as you would have it for normal listening. This includes doors opened/closed, curtains opened/closed, etc.
NOTE: The doors open/closed thing is IMPORTANT. Even a closet door being open may produce a significant change in room response in the bass frequencies.
ARC's Advanced mode is dead easy to use. You don't HAVE TO make any changes to the ARC defaults. The nicest thing about Advanced mode is that you get to decide when each phase of the process happens: Measurement, Calculation, and Upload.
For example, I take my measurements and then exit ARC after the measurements are saved to the file. Then I make a copy of that file and Write Protect the original. Then I restart ARC, open the copy of the file, do the Calculations and do the Upload. If I ever want to revisit ARCs settings I know my original measurement file is guaranteed to be the way it was right after the measurements were taken. I can just make another copy of it. There's no chance I could somehow screw up that file and need to do the measurements all over again.
--Bob
