Originally Posted by Bob Pariseau
Is Comcast screwing up my HDTV de-interlacing?
I've been noticing more cases where my D2 incorrectly drops out of film-mode when watching 1080i HDTV movies. The symptom is that there is a second or two of de-interlacing problems and then it corrects. Watching the Film Mode indicator in the Video Source Adjust / Info panel while replaying the scene on my HD-DVR I can actually see the D2 dropping out of film mode when the artifacts appear.
The question is whether something has gotten screwed up in the D2 V1.33 software or whether this is just another consequence of the heavy-handed "re-compression" that Comcast is doing to its channels in my market?
SO: Are others seeing 1080i HDTV de-interlacing issues with the V1.33 software? And if so, is your HDTV feed giving you video that otherwise appears to be undamaged, or is your HDTV provider also screwing up its retransmissions?
How 'bout folks who might be feeding other types of film-based content to the D2 at 1080i such as folks who have decided to use scaling in their SD DVD player instead of sending 480i to the D2? Have you noticed any degradation in 1080i de-interlacing performance with the D2 V1.33 software?
480i de-interlacing performance remains perfect as best I can tell. So if there's an issue here it will be just with 1080i/60 feeds of film-based content into the D2. I'm more than willing to believe it is just Comcast screwing up my HDTV feed, but I thought I'd check with some of the old hands here.
--Bob
--Bob
I have noticed 480i SD DVD that isn't anamorphic, looks really bad even with the scaling in my AVM 50. There is a lot of artifacts the worst being stair stepping around edges an people's mouths. Is this normal?
John
