Originally Posted by benleeys
Yea, it's an idea to fiddle with. Set up with SMS-1, run ARC, then fine tune with SMS-1. Or run ARC, then fine tune with SMS-1. Thanks for the suggestion.
Basically though, I am more concerned with the shift of the ARC calculated response peak from 50Hz down to 25Hz whereas peak for the other speakers remains at about 80Hz. Means there's a more pronounced dip between them and I don't think it's a good idea to fiddle with that with the SMS-1.
But we're deviating from my original question, and that is, from comparision of the 2 subwoofer graphs, whether it would be advisable for me to discard the SMS-1 and rely solely on the ARC.
-Ben
-Ben
Ben,
I looked at your graphs again and it looks like you are better off without the SMS 1. SMS1 decreases your 20 to 30 herts output by 10 dB and ARC can manage only around a cut of 6 dB, the resulting curve(with ARC engaged) is better without it.
