Originally Posted by
FilmMixer
Sold my Denon 5805 and 5910ci and will probably have my D2 next week... I cannot wait!!!!
Bold, and surprising move! Not a single review on the D2 and you made a jump like that?
FilmMixer
I was wondering if somebody could post a quick cheat sheet for setting up the 79avi and the D2... vid settings for both, etc... for best upscaling of that setup.. this will be feeding a Sony Ruby......
I have the exact same set-up. We did calibrate everything with a Minolta spectro, Colorfacts and OpticOne.
79AVi: "Component 12 bit" (so YCbCr 4:2:2), 480i out, then copy "Direct" settings to "Memory 1". O IRE, and black level bump 1 notch to the right. Everything else is at default.
D2. Menu Video 8 Video output: HDMI, 1920X1080p60, ColorSpace: HDTV, YCbCr 4:2:2 out.
In the Gennum menu: contrast 40, Brightness 51, Color and tint at 50 (note that those settings are with my projector, and after doing a full-blown calibation, so maybe not good with yours...). Film mode "on", CUE bug filtering "on", Y/C delay adjustment with AVIA.
Sony Ruby: everything at default in the user menus (I mean contrast 80 brightness 50 color and hue 50). Sharpness at min (plus EE removal tweak in the user menu), black level off, Iris Auto, custom gamma curve (if you can't do one, then you can use gamma 3 for SD and gamma 2 for HD).
Advanced settings in the Ruby's factory menu. Most of the time I'm using "Darin's" iris tweak: other/43:140 and other/44:650 to maximise contrast. And sometimes "Alan's" tweak at 43/44 376/100 to maximise brigthness.
And at 110 hours on the bulb. Gain R 103 G 124 B 127 and Bias R 133 G 124 B 123. You can try those values just for fun, but you definitely want to have it done by an ISF calibrator, or buy a good analyser to find your values.
We also did 2 RCP custom settings: one for SD (rec 601) and an other one for HD (rec 709). It's your call here. For some material I prefer accuracy, and for other type of material I prefer more saturation (RCP off). You need precision tools to measure those tough.
Have fun!
