Sorry, I don't really have a speaker recommendation for you. The usual problem in a surround sound setup is not only matching quality but also matching timbre between your speakers. And I don't know what would go well with your other speakers.
Richard, one of the posters here, discovered from his ARC measurement charts that one of his speakers had a bad driver. He had been living with a broken speaker for who knows how long and thought it sounded pretty good! Of course the fixed speaker sounded even better.
Thus Richard Syndrome: Discovering, via ARC, that one of your speakers is actually broken. Yet another fine audio improvement feature of ARC!
Of course if your Center speaker really is broken, and if you liked it enough to begin with, one possible solution is to get the bad driver replaced in it.
ETA: My personal opinion is that a Center speaker is essential for quality movie listening. If you go without a Center you really need to move your Front L/R speakers closer together for proper dialog, and that screws up their use for music content, even in movie tracks. I set up the "Music" configuration in my D2 without the Center speaker however.
ETA 2: Some higher end speakers have separate inputs for low and high frequency drivers, with a bus-bar cross connecting them for when you only use one pair of wires to them. If your Center speaker is like that, double check that your still have a good bus-bar or wire connection to your high frequency input on it.
--Bob
--Bob
