Originally Posted by libsim
I apologize if this question has been asked previously, this is my first posting in the forum, I joined earlier today.
My dealer has mentioned that the ARC system greatly benefits larger rooms but unfortunately does not do the same for smaller spaces. I live in a 900 Sq. Ft. Condo and the room dimension that my D2 is in is 10ft X20 Ft. Will the upgrade price be worth it in my case? Thanks in advance for your replies and knowledge.
Libsim.
P.s. The rest of my equipment is the Anthem A5 Amp and 2 Bowers and Wilkins Signature Diamond Speakers in the front and 2 XT4's in the back.
Libsim.
ABSOLUTELY. Odds are your room is not acoustically treated, and if you have something like a 10 foot ceiling you also have dimensions that will couple strongly with certain bass frequencies.
You don't mention whether you have a D2 (ARC upgrade price $400) or an AVM unit (upgrade price $800 plus dealer install charge for the hardware change), but in either case what ARC should provide for you will be a bargain.
If you've got room to put a sofa at your main listening position, then you've also got room to give the ARC mic positions enough spread for it to do its job.
--Bob
