Originally Posted by CycloneMike
A couple of questions regarding my current ARC curves - attached.
The movie run is on page 1 and the music on page 2 - 5000 Hz cutoff.
Is the dip at 15000 Hz due to the way ARC measures high frequencies, or possibly due to the height I am using for the microphone or is it truly a room mode? I know all my speakers are not going to roll off at the same frequency... The resulting sound does not seem to be missing the high frequencies as shown, or maybe my ears just can't tell...the sound is great!
For my music run ARC set the crossover at "full range" - why does it not use a flatter curve down to 20 Hz for the target? The curve looks the same as for the 40Hz curve for my movie setup that ARC picked for the front speakers.
I think there is a glitch in the ARC calculations for music. I went back in a did a different calculation with the cinema and set the cutoff down to 25Hz from the ARC selected 40HZ and it set the dB level higher at 20 Hz for the target than it does with full range with the music. In addition, the system will not allow me to change the target numbers for the music setting in advanced mode, only the cinema - is this correct?
Opinions please.
Opinions please.
No, its not a room mode as they are dependent on the dimensions of your room. There are 2 kinds of audio wavelenghts in an enclosed room. Standing and travelling waves. If your shortest room dimension is 8 ft(floor to ceiling), any frequency above 140 hertz(1130/8) is a traveling wave and below it, a standing wave. 15khz. has a wavelenght of just 0.9 inch therefore it can move easily within the room.
I suspect your HF measurement is inherent on your tweeter's response. Its not that bad as 90% of the sound that we hear are bunch up between 125hz. to 4khz. anyway. I won't worry about it.
Yes, The LF target curve is also a puzzle to me. Its ovious that the measured response of good subs extend below 20 hertz and still the target and resulting calculated curve attenuates the deep end response.
