Originally Posted by obie_fl
Thanks Bob I'm just trying to think of an easy way to reverse the polarity. It is not easy working on 130lb beasts behind a very narrow screen wall. I have some Canare RCAs I guess I could try wiring one backwards as it really isn't feasible going inside the actual subs.
You don't need anything fancy in the way of cabling to test this. Get a short, cheap RCA extender cable (Male at one end and Female at the other), cut it in half, strip the insulation back, and reconnect the halves with the polarity reversed using a couple of twist on caps. Put that in-line with your normal subwoofer cable to one of the two components.
If it works, THEN you can worry about doing it better.
--Bob
