Originally Posted by mlbrand
So... will the HDMI Audio still be ouput from the HDCP copy protected source, and if so will the D2 let you listen to the audio from that HDMI input and view the video from another (component) input at the same time?
(and yes, us component input only HDTV owners are desperate to stay current!)
HA! Understood. I believe the answer is yes, it will allow you to use HDMI input for the audio from a given source and match it with a particular video input for that source, including Component.
If I get some time this weekend, I will switch things around a bit and test this theory.
It will be interesting to see what you find out ManWithAPlan, thanks for all the info.
