Originally Posted by
funlvr1965
lately my the handshake switching between my ps3 and hd dvd player and projector have been getting worse, no blue screens just flashing screens of snow until it finally locks on sometimes taking what seems like forever. I have the D1-HD with ARC, I have only done one firmware upgrade so far and I dont believe its the latest. What is the current proven update (no beta) and will I lose my source or any settings including the settings in ARC by updating the firmware? will this also take care of this handshake issue? One more thing, I have the Marantz 11S2 projector and want to use to try using the Gennum inside the projector what should the video settings inside the Anthem be.
Thanks in advance
You don't say what version of firmware you have installed now.
In any event, the firmware you should be using is V1.33. You can download the install kit from Anthem's public download page.
To do the firmware install you will need to Reload Factory Defaults, so you should Save User Settings first, then Reload Factory Defaults, then install the firmware, then Reload Saved User Settings. Be sure you have no powered HDMI connections during the firmware install (I recommend you remove wall power from your display and sources).
After that I recommend that you open up your ARC results file in Advanced mode and do a new Upload to be sure your ARC data is all installed correctly.
CAUTION: If you are are updating from a firmware version older than V1.29j then you will need to take an additional step using the Live Video Settings Editor utility (part of the V1.33 firmware install kit) to save your Video Source Adjust menu settings to a PC file and to restore them after the firmware install. Read the text file that comes with the V1.33 firmware install kit for details.
The current ARC version is V2.0.1 -- also downloadable from Anthem's public download page. After doing the firmware install you may want to install the new V2.0.1 ARC application on your Windows PC and do a new ARC setup. The new ARC appears to be a significant improvement over the previous ARC V1.2.5 which itself was a major improvement over all older ARC versions.
If you are upgrading from an ARC version older than V1.2 you will need to do an extra step to make sure your pair of licensing/calibration files gets installed in the correct, new, folder in Window's Program Files directory. Read the text file that comes with the ARC V2.0.1 installer for details.
Handshake problems are often the result of marginal HDMI cables or loose plugs. HDMI plugs are just a friction fit and even the weight of the cable can shift them the tiny bit necessary to make the signal weak. Try the wiggle test where you grab the HDMI cable about an inch from the socket, push it gently straight into the socket, and give it a gentle wiggle to see if the connection is working better. If so you may need to support the cable in some fashion near the socket. Be sure to check both ends of the cable.
Since you are having this problem with all of your HDMI sources, you should look first to the cable from the Anthem to your display.
Firmware V1.33 is not perfect with HDMI, but I find it works very well with my PS3.
Typically, saying that you want to use the video processor in the display or projector means you want the Anthem to "pass through" the video signal unchanged from the source.
You can not do that with HDMI on the Anthem. HDMI output is always processed to whatever Video Output configuration you have specified.
You CAN if you wish "pass through" Component video input to Component video output -- but not to HDMI since the conversion from Component to HDMI is a type of processing and brings along all the rest. And of course you can't output HDMI sources as Component due to HDMI copy protection.
--Bob
