Originally Posted by
Carl_Ballard
Is there a listing somewhere of what the various firmware updates add/fix?
Here you go, this is from the AVM-50 file. Notice it lists the latest firmware upgrade first.
CHANGE LIST
v1.06:
1. Increased HDMI compatibility with a certain DVD player.
2. Removed from menu 8 output resolutions which can't always be supported by HDMI connection due to bandwidth restriction. **YOU MAY NEED TO RESET OUTPUT RESOLUTION IN MENU 8 depending on which you had set. If you cannot see an image on your display after the update, use the front panel display to navigate through the menu. Even if you are getting a picture immediately after this update, check menu 8 to make sure that the output resolution and refresh rate are set correctly since the setting may have changed to another that works, but with lower performance.
If you are saving your settings in menu 12, be sure to back them up after making this change.
If you were using Settings Editor, the wrong value will may stored there. After the software update, save the setup again using Setup Editor v1.06 (now called Setup Editor to prevent confusion with the Live Video Settings Editor).
v1.04:
1. Increased compatibility with HDMI-connected equipment that doesn't follow all of the HDMI spec.
2. Added adjustments for analog video inputs - see pdf file.
Tip: If you are using S-Video inputs and prefer the appearance of the hi-def OSD characters vs the default S-Video ones, you can enable the HD characters with S-Video inputs, although they will appear only when a video signal is present - change first item in menu 11 to HD Only.
v1.00 D2 / v1.01 AVM 50:
1. Initial releases.
