I'm trying to decide between an Anthem D2v2 and a Denon AVP-A1HDCI. For more background on what and why, see
this post or
this post. To help make the decision I would appreciate any and all input (especially since I am not going to be able to audition these units prior to purchase, darn it), but I have some specific questions that I presume can be answered straightforwardly by folks on this (massive!) thread:
* What was the cost of the upgrade from D1 to D2?
* What was the cost of the upgrade from D2 to D2v?
* Is "D2v" the same thing as "D2V2"? (Anthem's site only refers to "D2v" in terms of actual, current model numbers.)
* Does modern HDMI always include audio as well as video? (I noticed there were only 3 Toslink inputs, which I would overflow way too quickly if even one of my HDMI-capable components requires Toslink in addition to HDMI. And I set up my HD system 10 years ago, when everything was component, so I'm not intimately familiar with the behavior of HDMI yet.)
* What is the difference between a D2v and an AVM 50v? Anthem's comparison chart shows only 3 differences, total: 1) "Yes (differential circuit)" vs. "Yes" for "6 channel analog input", 2) "special order" vs. "optional handles" for "Rackmountable", and 3) "Yes" vs. "No" for "Premium faceplate finish". What value is that "differential circuit"? And are there any other internal differences? (I can live without a "premium faceplate".) What is the price difference between these two units?
* It has been said that Denon might be preferred for its features. What features? Yes, 6 component inputs vs. the Anthem's 4, but only 6 HDMI inputs vs. the Anthem's 8, and I suspect going forward that the Anthem's will be the better mix. The Denon has 4 TosLink inputs vs. the Anthem's 3, but if most audio is provided via HDMI, that's acceptable. The Denon has 12 channels, supporting 3 subwoofers, vs. the Anthem's 10 channels, but I have no intention of using more than one subwoofer. Aside from the one extra Toslink input, I haven't found any flexibility that makes me prefer the Denon over the Anthem.
* Does the Anthem output video and audio simultaneously on all outputs of equal or higher bandwidth? (I believe the Denon does.) Does it do any downconversion (so a 1080i or 1080p input signal is output over composite, say)? (The Denon does not, though it will output a 480i or 576i input signal over composite out.)
One interesting tidbit I noticed is that Denon says it does not provide its onscreen GUI over 1080p, only 1080i and lower, while Anthem clearly states that its onscreen graphics work for all resolutions (presumably including 1080p).
For context, this is going into the following system:
Being replaced: Krell HTS pre/pro (Home Theater Standard)
Krell 250a 2-channel left & right
Krell 250a/3 3-channel center & surrounds
Martin Logan reQuest left & right
Martin Logan Scenario rear surround channels
Martin Logan Logos center channel
Sunfire Signature sub-woofer
Sony VPL-VW70 (having recently replaced a lightning-damaged Sony G90)
Thanks! - larryy
