Originally Posted by darryl b
i'm really looking hard at the d2. i am reading this entire thread( believe it or not) i wanted to be sure to read answers to a few basic questions, so i posted them below.
some of the out-board box vps now offer picture by picture and picture in picture. has the video section of d2 been supported with such upgrades? how are upgrades applied, easily?
which amps are some of you using? i have a gemstone 200*7, is that in the same league as the d2?
is the d2 economical compared to a pre/pro and out-board box vp?
i have a ruby, am on pre-order for the jvc rs-1, will get hddvd and a ps3. will the antem statement d2 be the piece to rule such a system?
i don't read much about d2 audio, what about the sound?
thanks,
darryl
thanks,
darryl
Darryl,
The D2 does not offer picture by picture or picture in picture. Nor is that something that seems to be on the wishlist of the many different owners posting in this thread -- who on the whole aren't shy about expressing their demands (grin!). Presuming we are representative of what Anthem is hearing, I wouldn't expect to see it anytime soon. As to whether it could be done, that's a tougher question. The Anthem does a significant amount of processing on its video path. I'm not sure it would have the processing power to handle two video input streams at the same time and maintain that quality. In addition, HDMI video's copy protection might get in the way if two HDMI video sources were to be merged.
I don't know the Gemstone amp. Folks are using all sorts of different amps with the D2. Of course some go one stop shopping and use the Anthem amps (P5, etc.) If you like your current amp, I'd suggest you keep it until you get familiar with your D2 and then you can work with your dealer to try out new amps at home and see for yourself.
"D2" and "economical" are two terms that seldom appear in the same sentence, but yes the D2 is good value for the money compared to a high end pre-pro combined with a high end video processor of current design. The level of integration provides added convenience as well.
Many people are using the D2 with equipment very similar to what you listed. Ruby owners seem particularly excited about how well it works with the D2. The D2 is excellent for HD-DVD, Blue Ray, and standard def DVD. I can't say there are any sources which I think don't match well with the D2. If you have a record turntable, you will need a separate phono-preamp prior to the D2 as the D2 does not have a dedicated phono-stage input.
The audio section of the D2 is the Anthem Statement D1. You will likely find reviews of the D1's audio around. Personnaly I think the audio of the D2 is very VERY good. It has exceeded my expectations for a surround sound processor, both for home theater and for music.
The audio side of the D2 lacks Room EQ -- a feature found in many high end audio systems. The rumor is that Anthem has been working on a very powerful Room EQ solution that is supposed to be added to the D2 early next year (free software on both the D2 and a PC plus a calibrated microphone that you pay for).
The video side of the D2 has one acknowledged weakness. Its noise reduction is not quite as powerful as the best such solutions out there. This is relevant if you watch a lot of crappy TV signals -- weak off air broadcasts for example. It is not an issue for video of normal to good quality such as is typically found on discs. Lest you get too concerned at this, I should point out that most people use their D2 with video noise reduction turned off anyway (which is also the factory default setting), i.e., they don't need it at all, much less need a more powerful version of it.
--Bob
. It is very economical when you consider how much gear you are combining into one box. Another feature is that both audio and video are converted to digital and switched together, so everything you connect can have the same processing power applied to it. Of course, every input can have its own tweaked settings.
I'm sure this will be taken care of shortly. The AVM line continues to impress me with the performance/price factor and I look forward to the next upgrade!
