Originally Posted by
Bob Pariseau
Let's see, yes, you want the D2 output to be 1920x1080p/60Hz for such a display.
Yes you want 1:1 pixel addressing. Since the display has a 1920x1080p native pixel matrix, all that means is that there's no artifical overscan introduced by the display's circuitry. All 1920x1080 pixels of the input signal will light up visible pixels on the display.
Bob: Thanks for the answer.
I've read that if you're using an external VP, then having a display with 1:1 pixel mapping is critical since this allows complete by-passing of any processing by the display . Now I'm not so sure. It does seem clear that the D2 should do all the video processing. This should mean completely eliminating any display processing. Can this be adequately done without 1:1 mapping? If I send a 1080p/60Hz signal from the D2 to a 1080p/60Hz display won't that eliminate any processing by the display ... even without the display being capable of 1:1 mapping?
I've heard that there is often noise/garbage hidden in the overscan and that, without adjustment, 1:1 mapping can reveal the garbage. So, if I'm
not using a PC, is 1:1 mapping all that important? That is, does its use really affect (help to eliminate) display processing to a point where it makes a difference in the final PQ?
Bob Pariseau
The DVI input on the commercial unit will limit you to RGB color format from the D2. The D2 does some additional dithering of dark grays near black to make that work. I'd suggest you get a replacement HDMI card to avoid that. By the way this is also why you have no Color control.
The idea that RGB input is better for plasmas is not really true any longer. Although the plasma will convert the HDMI's YCbCr input to RGB as part of its internal processing, modern plasmas do that using extra bit depth in the math, so the conversion is, for all practical purposes, perfect. And the Anthem will take care of any "color space" variations automatically. Just pick an HDMI input card that's known to work well for this unit.
An HDMI to HDMI connection is also more reliable than an HDMI to DVI connection, particularly as the cable gets longer, and particularly given you are pushing the bandwidth. The difference is the newer driver chips used for HDMI.
Panasonic is working on an HDMI 1.3 board for the commerical 65" Panny plasma. It will just snap in. However, given the
internal *refresh rate* of 60Hz and the other internal limitations (inability to process deep color and larger color space) will being able to add an HDMI 1.3 board have any advantage over the HDMI 1.1 input currently on the consumer model? I think this (kind of) relates to your current question:
....how many of you have settled on YCbCr 4:4:4 format vs. YCbCr 4:2:2 format for output from the Anthems.
I know some of these questions are slightly OT, but you know more than the members on the plasma threads. Don't tell them I said that.
Actually, the more knowledge we have in all these areas, the better we should be able to take advantage of the D2's capabilites. That includes the decison of what display to pair with it.
Bob Pariseau
For this kind of bucks, you should also take a serious gander at a front projection system as an alternative. You might be able to save money and still get a bigger image almost as bright. Plus you'll be able to fiddle with "judder free" settings.
The problem is that my HT set-up is in a room with too much light. There's no way to darken the room enough. The room is in a very open area of the house. I'm also accustomed to direct view displays (CRT and Plasma) and I can't get use to rear or front projection with video sources. If I had a dedicated HT room, for film only, it would be different.
I'm thinking about waiting for a 65" + plasma with a 120hz *refresh* rate. I just have a feeling it's several years away and the price will be astronomical. I notice that there are at least 2 LCDs that now have a *refresh rate* of 120 ... but they're 1366 X 768 and the largest is 37"
JVC 37" LCD TV with 120hz Clear Motion Drive Thanks again.
