Originally Posted by
p.las
i finale made it.
i'am not sure that the room gain is correct, becurse i also use a SVS a1 EQ, so ACR can't see the peaks, and this will cheat the mesured roomgain
but i must say that the bass is very presice, witt a lot of texture.
any comment will be nice.
regards Peter Denmark
edit: i'ts a mistake in the mowie setup......the front is set to 90hz by ACR, and it works great.
Peter ...congrats on getting to post your graphs
- Now, I really don't understand why your sub high frequency response is set too low by ARC since its capable of much higher response. Assuming no crossover setting is set (doubt it as it would have shown in the measured curves), you might ttry to boost your room gain to 1.5 - 2.0, recalculate, upload and give it a listen. This should lower your mains freq response to mesh in well with the subs high frequency cutoff.
- Might try raising your high freq response from 5K to 10K. Your front mains can handle up to 15k but your rears can't. Give it a listen as well.
- Set sub highpass filter setting to flat as has been already mentioned.
