Originally Posted by
jayray
I can't understand why you would want to cut out ARC. Whatever "pristine" you will preserve will be lost from lack of room correction. This from Anthem's own blind testing comparing analog direct vs. Analog DSP and ARC. You paid for a great preamp and now want to bypass it for analog sources. Just my two cents.
John
I hear you about the listening tests, and completely agree with ARC for digital sources. However, in my setup, vinyl sounds more open with a broader & deeper soundstage in AnalogDirect mode. Even my less-finicky wife agrees.
Yes, I have some records - mostly 80's recordings - that sound better with AnalogDSP, but my older hard rock/ metal recordings sound much better direct. Perhaps it's because I have an AVM50v and not a D2V; not sure. Therefore, I do want the option of AnalogDirect (with bass mgmt through subwoofer) for some records and AnalogDSP (with ARC and Anthem bass mgmt) for others.
That being the situation, will I risk blowing or damaging the sub if I have LFE and line-level RCA inputs connected at all times? I know it's not an issue for AnalogDirect (only line-level RCAs juiced), but for all other modes, there's juice coming in on LFE and line-level RCAs. Thoughts??
