Originally Posted by
Bob Pariseau
....you *CAN'T* feed a native HD-lite signal to the D2 because the DirecTV receiver doesn't make it available to you. So if a given, bit-starved, 1080i HD-lite channel actually comes in to your receiver at 1280x960i equivalent bandwidth, the satellite receiver will "scale" that up to 1920x1080i (i.e., reconstitute the "original" signal) before you can get your hands on it. So the quality of that proccess in the receiver becomes an issue. Although this is not precisely what happens with bit-starved signals, the best way to think of it is that the receiver de-interlaces, scales and re-interlaces. Yuck.
Hey Bob: If I thought I could consistently ... or more often than with D* ... receive 1920 X 1080i or 1280 X 720P from Comcast, I would switch tomorrow. In my area I've heard more negative comments about Comcast than D*. But mostly about analog SD and not enough HD content. So what to do?
I hadn't thought about the D* receiver being required to de-interlace and scale the HD-lite before it feeds it to the D2. Bummer!
I was hoping there was some way to pass the signal, untouched, to the
D2 no matter what resolution the D* receiver encounters. This messes up my intention of how the whole process ... with the D2 to the rescue ... will work with the STB or the DVR and D* or Comcast for that matter. I guessing Comcast has HD-lite also.
You're not saying that Comcast consitently sends out full 1920 X 1080i or 1280 X 720P are you? I 'm not sure how to verify what my Comcast does with the HD resolutions?
Bob Pariseau
Now that said, the H20 is your best bet for DirecTV (as I understand it). The S3 plus a simpler satellite receiver will not gain you anything. The simpler receiver will still have to handle the HD-lite stuff before the S3 can get anything.
The
S3 TIVO ("The world's first THX-certified, dual CableCARD DVR") only works with cable and OTA. The H20 is only a D* receiver only. The HR20 is a D* DVR. At $800 and being THX certified, I'm willing to bet the S3 has a better de-interlacer and scaler than the HR20. But does that really help the situation ... if HD lite is invloved?
Bob Pariseau
Set the H20 to "native" resolution output. This will be a big win for SD because you will get a true 480i signal (they don't bit starve SD since there aint enough bits to starve) and the D2's de-interlacing and scaling will take it from there. For HD you will get the HD-lite scaled up to the "original" 720p or 1080i by the H20 -- there's no way around that -- and the D2 will take it from there. This will be a win vs. setting the H20 to always send out either fixed 720p or 1080i no matter what you are watching.
It sounds like the same situation would be needed if I switched to cable, except that the D3 should have a better deinter/scaler and perhaps Comcast HD will be less compressed than D*. Maybe no HD-lite. Our Comcast is also alledgedly adding HD channels in the near future (5-7 channels) but with a bastardized (from the days when AT&T screwed up everything) 750 MHz system, I have no confidence in them.
Bob Pariseau
Now for SD you will still see macro-blocking due to the over-compression DirecTV foists on you. This is not equally bad on all channels -- DirecTV tries to pick its enemies. It is worst on channels with lots of commercials and on local SD stations rebroadcast by DirecTV to you. You will also see it on animation channels due to large blocks of solid color that just show it up more....
For HD you will primarily see artifacts in areas of rapid motion. This is a combination of bit-starving and then re-scaling in the receiver and also some over-compression. Again this varies between channels and from time to time. Mark Cuban at HD-NET has a running battle with D* about what they do to his signal.
I only watch local channels OTA which is significantly superior to D* in PQ and SQ. HD-NET consistently has the best PQ. I intensely dislike artifacts, especially on bigger screens.
Bob PariseauNow I don't want to make this sound too grim. You will see BETTER stuff through the D2 than you are getting now. SD will gain a lot. Although on channels with bad over compression that may just make the compression artifacts more noticeable, the good SD channels will definitely show improvement. In addition, the color space issues between SD and HD will be taken care of automatically by the D2. HD will be improved due to feeding both 720p and 1080i to the D2. The D2 will also enable you to better calibrate the levels for your HD feed. The result CAN BE very very good. But two days later you may find the same channel has been given the D* "touch". Record the same HD program on the same HD channel on different days on your H20 and you may very well see different quality when you compare them. And that's entirely due to what D* does to the signal since the H20 is merely recording the exact bitstream coming down from the bird.
Cable providers that are still using mixed analog and digital systems often over-compress the digital channels to cram more digital channels into limited bandwidth.
Cable providers that have finally managed to eliminate their analog stuff don't have that problem (more or less) and the resulting digital signals can be excellent. For Comcast that means when they start offering the Motorola 3412 HD-DVR instead of the 6412 HD-DVR. The newer 3412 is digital-only while the 6412 is mixed analog and digital.[/QUOTE
I should add that even cable companies that over-compress the bulk of their digital SD channels typically have very good HD channels since that's their main point of competition.--Bob
In my area Comcast is in the process of a full analog to digital conversion. It should be complete by Spring. The roll-out will take longer. However, Comcast will continue to use the old MPEG-2 rather than the newer MPEG-4 compression standard. This contributes to their tight bandwidth limitations. Apparently their next priority is to free up bandwidth for local phone service ... to compete with SureWest.
Generally, with the exception of the members of this forum, people don't care much about PQ. Somtimes I feel like giving up the quest for greater PQ.
