Originally Posted by obie_fl
Agreed John. I have a very similar issue if I switch to my Cable DVR from another HDMI source. It usually occurs if I forget to use my power up macro. Never have a problem with the other sources so I always blame the cable box but if I'm careful powering up everything seems to work.
Tom,
I will try changing sources but I don.'t normally. The start up sequence has worked flawlessly but I do feel for those who still have syncing issues.
John
Just tried switching to my HDDVD player, the only other hdmi source I have and no syncing problem.
. But once everything is on I think he is having problems when switching sources. First time turning things on, yes the sequence works great. I never have problems with syncing since I started using this.
