AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide - Page 1163
post #34861 of 40766
Originally Posted by jayray View Post
Auditory memory lasts about 5 seconds so unless you had two units, one with the mod and the other without, it is very hard to determine the difference.
John
Originally Posted by AVfile View Post
As for the 5-second rule (I thought it was 7 seconds ) I would say that is valid in the context of surveying the general public for say a psychology class study. However an experienced Audiophile that knows what to listen for can make mental notes.
I think you are both right.
I often find myself saying, "God, I forgot how good this sounds!" as I listen to my system, anchored by my D2 with ARC.
Its nice to both know what good sound is, and (because of my faulty auditory memory) to be re-reminded each time that I have a system that is capable of producing it.
Tom
post #34862 of 40766
Tom
Glad I could help you enjoy your system more Tom
John
post #34863 of 40766
I'm thinking about purchasing an Anthem AVM50v. I was wondering if anyone has heard anything about changes to this model or a new line coming out at CES 2012. Thoughts?
post #34864 of 40766
3 posts back
post #34865 of 40766
Only update in the works for Anthem pre/pro is 3D pass through. Minor firmware fixes every now and then.
post #34866 of 40766
Originally Posted by Bob Pariseau View Post
An upgrade allowing 3D "pass through" on half the inputs and one of the 2 HDMI outputs is in the works. The latest post here from Nick at Anthem says it is slated for the first of the year. No info yet on pricing.
--Bob
It may be the first half of the year but did they say which year?
I bought a D2V last December taking advantage of the free 1.4 upgrade offer which was due early in the year. Since then it has been 3 months away no matter what month I asked
post #34867 of 40766
January is the present hope by Anthem. The firmware and hardware are being beta tested as we speak to make sure it is ready for prime time.
John
post #34868 of 40766
Hi
I have orderd mine new Anthem D2v and i want to know witch is better for sound, Oppo 95 via hdmi or via analog cables?
Has the Anthem D2v only space for 5.1 analog in?
Thanks for the info
Martin.
post #34869 of 40766
Is this a firmware upgrade or an actual board that I would have to take into my dealer for an upgrade (assuming I could get an upgrade)?
post #34870 of 40766
^^ Yes, only 5.1 in over analog (7.1 for HDMI), although the D2v can raise that to 7.1 speakers for output.
The Oppo 95 has very good analog output so you certainly ought to try both analog and HDMI into the D2v. But be aware that to use ARC with the analog input you must let the D2v re-digitize the analog audio so that it can be processed (ANALOG-DSP for the Source audio input). And then of course after processing it is the D2v that will re-convert back to analog for output.
Now ARC is so good, I think you'll want to use ARC even for the Analog audio.
Really you'll just have to try it and see which you like better.
--Bob
post #34871 of 40766
Is there any way we can get the first post updated?
Originally Posted by LEVESQUE View Post
PANIC ROOM!
* Should I panic since the D2/AVM50 are NOT HDMI 1.3? :
Not anymore!!!
The D2/AVM50 will both be upgradable (hardware upgrade) to do the D2v, so they will be HDMI 1.3c, 7.1, and will support decoding of DD TrueHD, DTS HD and DTS-HD Master
WRONG
ANTHEM ROOM CORRECTION (ARC-1) : AUDIO BLISS IN A FEW, EASY STEPS
http://www.avsforum.com/avs-vb/showt...=#post14142274
http://www.avsforum.com/avs-vb/showt...=#post14160614
http://www.avsforum.com/avs-vb/showt...=#post14165296
http://www.avsforum.com/avs-vb/showt...=#post14181449
http://www.avsforum.com/avs-vb/showt...=#post14192486
http://www.avsforum.com/avs-vb/showt...=#post14207104
http://www.avsforum.com/avs-vb/showt...=#post14207158
http://www.avsforum.com/avs-vb/showt...=#post14207663
http://www.avsforum.com/avs-vb/showt...=#post14214469
http://www.avsforum.com/avs-vb/showt...=#post14216213
http://www.avsforum.com/avs-vb/showt...=#post14220432
http://www.avsforum.com/avs-vb/showt...=#post14232090
http://www.avsforum.com/avs-vb/showt...=#post14236866
http://www.avsforum.com/avs-vb/showt...=#post14256232
http://www.avsforum.com/avs-vb/showt...=#post14262027
http://www.avsforum.com/avs-vb/showt...=#post14267952
http://www.avsforum.com/avs-vb/showt...=#post14268617
http://www.avsforum.com/avs-vb/showt...=#post14286844
http://www.avsforum.com/avs-vb/showt...=#post14287488
http://www.avsforum.com/avs-vb/showt...=#post14296873
http://www.avsforum.com/avs-vb/showt...=#post14306824
http://www.avsforum.com/avs-vb/showt...=#post14320989
http://www.avsforum.com/avs-vb/showt...=#post14322061
http://www.avsforum.com/avs-vb/showt...=#post14327449
http://www.avsforum.com/avs-vb/showt...=#post14335277
http://www.avsforum.com/avs-vb/showt...=#post14347781
http://www.avsforum.com/avs-vb/showt...=#post14351330
http://www.avsforum.com/avs-vb/showt...=#post14353551
http://www.avsforum.com/avs-vb/showt...=#post14363180
http://www.avsforum.com/avs-vb/showt...=#post14365808
http://www.avsforum.com/avs-vb/showt...=#post14366806
http://www.avsforum.com/avs-vb/showt...=#post14370256
http://www.avsforum.com/avs-vb/showt...=#post14372958
http://www.avsforum.com/avs-vb/showt...=#post14377508
http://www.avsforum.com/avs-vb/showt...=#post14379882
http://www.avsforum.com/avs-vb/showt...=#post14380719
http://www.avsforum.com/avs-vb/showt...=#post14383015
http://www.avsforum.com/avs-vb/showt...=#post14384710
http://www.avsforum.com/avs-vb/showt...=#post14391953
http://www.avsforum.com/avs-vb/showt...=#post14393593
http://www.avsforum.com/avs-vb/showt...=#post14393664
http://www.avsforum.com/avs-vb/showt...=#post14394305
http://www.avsforum.com/avs-vb/showt...=#post14395567
http://www.avsforum.com/avs-vb/showt...=#post14396801
http://www.avsforum.com/avs-vb/showt...=#post14407572
http://www.avsforum.com/avs-vb/showt...=#post14413014
http://www.avsforum.com/avs-vb/showt...=#post14415277
http://www.avsforum.com/avs-vb/showt...=#post14420677
http://www.avsforum.com/avs-vb/showt...=#post14422227
http://www.avsforum.com/avs-vb/showt...=#post14424204
http://www.avsforum.com/avs-vb/showt...=#post14424251
http://www.avsforum.com/avs-vb/showt...=#post14424733
http://www.avsforum.com/avs-vb/showt...=#post14429013
http://www.avsforum.com/avs-vb/showt...=#post14430627
http://www.avsforum.com/avs-vb/showt...=#post14436325
http://www.avsforum.com/avs-vb/showt...=#post14439704
http://www.avsforum.com/avs-vb/showt...=#post14439977
http://www.avsforum.com/avs-vb/showt...=#post14440383
http://www.avsforum.com/avs-vb/showt...=#post14448571
http://www.avsforum.com/avs-vb/showt...=#post14451192
http://www.avsforum.com/avs-vb/showt...=#post14458172
http://www.avsforum.com/avs-vb/showt...=#post14459485
http://www.avsforum.com/avs-vb/showt...=#post14461019
http://www.avsforum.com/avs-vb/showt...=#post14462796
http://www.avsforum.com/avs-vb/showt...=#post14469019
http://www.avsforum.com/avs-vb/showt...=#post14477302
http://www.avsforum.com/avs-vb/showt...=#post14484075
Yeah, just a few
post #34872 of 40766
A hardware change (board swap out) is required to change those HDMI sockets to HDMI V1.4. I presume it will be a change done by a dealer for folks buying an upgrade.
--Bob
post #34873 of 40766
Yeah, just a few
Have you actually read them? Many are quite short.
As to your question, at this point it is unlikely the first post will be updated as only the thread starter can do it. That's just the way the forum software works. LEVESQUE has not posted in this thread in quite some time.
If you are volunteering to start your own FAQ, one suggestion is to add a link to it in your post signature.
--Bob
post #34874 of 40766
Sorry I haven't read past the first few. Just thought I'd ask, to benefit the newbies that seem to constantly pop in and get redirected to the "FAQ".
For example, if I were looking for tips on how to place the microphone (since I find the stand too tall on my chairs) where would I start? I don't want to start and the beginning with all the historical info about ARC upgrade kits, etc.
Actually I found your most recent post about setting up subwoofers very informative and should be in the FAQ if not already.
post #34875 of 40766
Yes, well that's how the list of posts grew that long in the first place.
I believe that particular subwoofer setup advice is already in there, but perhaps not.
--Bob
post #34876 of 40766
I found a microphone boom attatchment that fit on the Anthem stand.
It allows me to place the stand infront of the seating/mic positions and put the mic in the optimum place. Works great and its cheap.
Attachment is picture of the boom- this was on the Sweetwater site, but you can find a similar model at any music/guitar store for $10-$15.
Tom
post #34877 of 40766
Thanks Tom, that is a great idea! I ran out at lunch and found something similar in a local shop.
post #34878 of 40766
UPDATE.....new Anthem product comes with a new stand. Lighter and with boom arm. Has been the case for several months.
TJG
post #34879 of 40766
TJG
That's great news! Do you know if the stands coming with the newer 50v and D2v are the same stands that come with the MRX receivers?
post #34880 of 40766
Yep!
TJG
post #34881 of 40766
Yep!
TJG
Awesome! Thank you, sir.
post #34882 of 40766
Why are some BluRay movies so much louder than others.
For example, I find movies in DTS 5.1 MA like King Kong, Aliens, Saving Private Ryan to play so much louder off my D2v using Neo 5.1 DTS MA over movies like Jurassic Park and Forbidden Kingdom which are 7.1 DTS MA? I am using the same DVD player (BDP S550) when playing these discs.
Anthem just said it has to do with the disc/source. They suggested changing my Dynamic setting from Reference to Off. Literally, I have to come down about 10 plus decibels when playing King Kong for example (I find this with most DTS 5.1 MA discs) vs Forbidden Kingdome for example or most DTS 7.1 MA discs which play so much softer. Any ideas/comments? Thanks.
post #34883 of 40766
This isn't the answer but prologic IIx works best for all formats, NEO not so good.
John
post #34884 of 40766
Known issues http://www.avsforum.com/avs-vb/showt...5#post20844765
If you use the Dolby Volume Reference setting you need to go into the level settings and set the Dolby Volume level setting to reference level(-30dBFS tones = 75dBC) using an SPL meter, otherwise it won't play at the correct level when engaged on content. Ie if you need to apply a -6dB to the DV reference setting and you didn't then when you engage DV Reference it will play +6dB louder than reference.
Cheers
post #34885 of 40766
Have you also used the front trims to turn down the center channel 3dB for DTS HD?
There is of course the fact that some BD are just mastered too damn loud. Last night I was nearly deafened by Resident Evil 3 and it's Dolby TrueHD!
post #34886 of 40766
I'd agree with that!
John
post #34887 of 40766
Yep, Armageddon BD is another......compressed and cranked, had to turn it way down as even the dialog was too damn loud. Haven't double checked if the DVD was mastered the same though.
Cheers
post #34888 of 40766
On the way to listen to an AVM50v. This product has been out for a while. I have a AVM20 which is now showing it's age. Is the AVM50v design, processors, ... starting to show their age or is this still a viable product?
Don't want to purchase it this year if there is an AVM60 or whatever product around the corner.
I spoke with a dealer that stopped carrying Anthem because they wouldn't upgrade a customers D2. Thoughts on purchasing this or waiting for next generation?
post #34889 of 40766
I doubt there is any NEXT Generation.
HOWEVER - Anthem - has announced a Video Upgrade for
the D2v and AVM50v in January 2012 to support HDMI 1.4
and 3D Video.
post #34890 of 40766
Being a dealer for many years, that explanation really doesn't ring true.
There was ample time for anyone to upgrade. Maybe there were other reasons.
Go for the 50, it will amaze you!
No AVM replacements in the pipeline.
TJG
