It would be GREAT if Anthem published the proper values for some of the more common HDMI equipment on the market today. I assume Anthem tests many source components, so this should be relatively easy to publish.
Failing that, is anybody aware of publicly confirmed information for some of the components such as:
Sony projectors (pearl, ruby, etc)
HD-DVD and Blu-ray players
Originally Posted by Bob Pariseau
"Standard" for HDMI to HDMI connections is YCbCr 4:4:4.
"Optional" and *POSSIBLY* superior for HDMI to HDMI is YCbCr 4:2:2. This can only be "better" if the devices at both ends will support greater than 8 bit samples (as the Anthem does).
YCbCr 4:2:2 comes in 3 different flavors -- 8 bits per sample, 10 bits per sample, or 12 bits per sample. This is typically selected automatically by the devices at either end of the cable -- they use the highest sample size they both support. YCbCr 4:4:4 always uses 8 bits per sample (at least until HDMI V1.3 connections arrive). YCbCr 4:2:2 supports the higher sample size because it only sends one color sample for each two luminance samples across each line.
"Standard" for HDMI to DVI connections or DVI to HDMI connections intended for home theater use is RGB. HDMI devices will typically also handle RGB for when they are connected to a DVI device, but RGB should only be used if YCbCr won't work -- as when either end is DVI.
"Standard" for HDMI to DVI connections or DVI to HDMI connections intended for use with typical computer graphics cards is Extended RGB. If the DVI side of your connection can be set to use just RGB (also called "Studio RGB"), then that's the one to use. Only use Extended RGB if the DVI side of your connection gives you no option to do otherwise. Typically any DVI connection with HDCP will either offer a setting for "set top box or DVD" vs. for "PC or computer", or will warn you that it is ONLY intended to be used for "set top box or DVD". The "set top box or DVD" setting is the one you want for Studio RGB.
Another way these are identified is Studio RGB means Black = 16. Extended RGB means Black = 0.
--Bob
--Bob
