Originally Posted by Joe C5
I will have to slightly disagree here
(please note Smilie). While in most cases XLR do not help much in a home invironment, they can in some. I believe the S/N is slightly better in most configurations (though I'm not positive on this), but where it really helps is in rejecting noise from amoung other things, ground loops. With modern systems having many pieces of equipment (not always configured or grounded correctly), when you throw in that DVR and the associated cable connection, bad things can happen. Case in point, I was running the old D1 to some Adcom amps and had horrible hum. Disconnecting the ground helped, but is not a good idea. Adding a Cable isolator (one that isolates both the center and shield) got rid of most of it. Changing over to XLR got rid of it all (same amp). Of course YMMV. I just thought I would throw that in there. In my opinion (and you know the old saying), if you have XLR then use them (there are inexpensive cables out there that are not bad at all). Just my 2 cents
FYI, I had rca, switched to xlr and noticed a definite improvement. I was experiencing some hum. I think it is worth the few extra bucks to remove any doubt over marginal improvement in all systems.
