Originally Posted by SimonNo10
Well followed Nicks instructions to the letter using the Data Analyzer program and it didn't work so it's a bricked unit. Not happy. I can understand Bob about the warnings about using Beta but it should install and not fail 10mins into it, warnings are for the firmwares actual use after it installs that I can agree with.
Denon can get this right with their flagship pre-pro I just wish Anthem could be the same. Oh well back in the box once again (2nd time with this unit) and organize a courier next week to have it sent to my local (over 30kms away) repairer. Good times....NOT!!.
Thanks Bob and Nick for your continued assistance. Appreciate it.
Followed the same instructions on using the Data Analyzer program he recommended and it simply refused to work. I hope they perform a quick turn around of less than 4 days.
BTW, is the 3-D board 4K compatible?
. Unfortunately, its things like this that makes folks to shy away from beta testing their firmware. It wouldn't be so bad if one could easiliy uninstall the buggy FW. I remember the days of yore when all you had to do to reset your motherboard's bios was to short the pins of its EEPROMs or simply move a jumper to reset the bios
