AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide - Page 1248
post #37411 of 40764
Originally Posted by AVfile View Post
You are still running 2.10 release?
I don't have AIX (only Toy Story 3 for 7.1 test) but I don't recall hearing this issue in v2.10 - v2.13 beta.
I'm told the MRX products which are much less mature don't have this bug, so why do we have to get this bug? mad.gif
yes - still runing 2.10
on the AIX test disc - when play the DTS HD MR 7.1 test signal , side surround. there also are coming "noise" out of the front L/R.
One more thing - there have been some (my self inkluded) there have reportet higher volume on the movie Thor....about 6db, when it is Bitstream.
Last night i wash watcing Ice age III there are also i DTS HD MR 7.1 track. This track is also 6db higher than the PCM from my Oppo bdp 83.
i also have a Integra 80.2 processor - i then try to run the same thing on that - no problem confused.gif
i know that the DTS flag is very complex - but why isent there others there have the same problem - Denon - Integra - Yamaha - etc.....?
very frustating to have a high end gear that can't handle things right
Edited by p.las - 6/26/12 at 12:29am
post #37412 of 40764
Studley:
Actually, you can temporarily set one input settings (say the one for the BD player) to "None" and perform the test. Afterwards, you can return it to its original setting smile.gif .
- David
post #37413 of 40764
If you reloaded v2.11 release at this point I would be curious if it worked any better.
For non-3D folks I don't see any point loading v3.00 beta as Tech Support has just informed me all the latest fixes are for 3D only.
Russ
post #37414 of 40764
I may be looking to trade my less than one month old Integra DHC 80.3 for a D2v with Arc with some cash to equalize the difference. PM me if interested.
post #37415 of 40764
Originally Posted by RussVC View Post
Russ
Not surprised Tech Support did not know or did not give me all the information.
Were you at 2.14 prior to that?
post #37416 of 40764
Yes it is frustrating. I have a Yamaha sound bar for another TV that seems to handle the various formats more gracefully.
I recall you also saying bitstream sounds more dynamic and better bass impact than PCM, and I think I heard it too. So there are a few reasons to continue bitstreaming despite the fact that digital theory says PCM should be just as good.
post #37417 of 40764
Yes. It whas where easy to hear on the the ICE age bd disc .
post #37418 of 40764
hello Bob.
thanks for you help with my graphs.
just want you to see the new messuerment after i have installed a bafflewall
320320532
what i big difference a bafflewall do:)
post #37419 of 40764
hello Bob.
320320532
I can't remember what your previous graphs looked like, but these look excellent. Now you'll be able to detect differences in DTS MA 7.1 tracks even better;)
John
post #37420 of 40764
John
Hæhæ - i wount dissepoint you ;-)
Before there was some nasty null from 150hz to 100hz , on All tree frontspeakers.
post #37421 of 40764
Well you've done a great job. Enjoy. BTW, have you tried Flat in ARC for your sub? Looks like it could do it.
John
post #37422 of 40764
If by setting the video to none you mean the scaler in then that does not give me the purple haze going to or coming from an input with that set up. What I did find though playing around this much is that several times I lost audio too and sometimes my set up screen would not even show on screen, I had to read it at the receiver. Think I am going to revert back to 2.11 and start getting in touch with support again.
post #37423 of 40764
Can someone help me?
I am thinking of purchasing an Anthem D2 used to save some cash. I can't afford the $9K for the newest model. Is the Anthem D2 upgradeable to the latest "V" model? Does anyone know the cost of doing so? Is there anything in particular I should look for (our out for) when buying one of these used (something about a "red board").
Any help would be appreciated.
-Brian
post #37424 of 40764
John
I DO recall what his old charts look like and these are a BIG improvement.
p.las, now that you've tamed your bass problem you might want to experiment with raising Max EQ Frequency to 10 or 12KHz (I probably would not try to go any higher due to mic response issues that are likely the cause of the steep drop off at the highest frequencies) to see if you like the result of extending correction an octave higher into treble. In addition to judging the sound by ear, also keep an eye on whether raising Max EQ Frequency results in poorer correction (a less clean Calculated curve) in the low frequencies. If so, back off Max EQ Frequency and see if you can find a compromise setting that maintains good correction in the low frequencies, while still extending correction in the high end somewhat above the default 5KHz.
Your Subwoofer also looks like it might be a good candidate for the Flat option in Targets > Advanced settings, which will minimize the roll-off at the lowest bass frequencies.
--Bob
post #37425 of 40764
-Brian
Brian, there was never an "upgrade" to go from the D2 to the D2v. The D2v has an entirely new, expensive video board (among other things), so the upgrade cost would have been excessive. What there was, for a while, was a factory sponsored "trade-in" program -- return your old D2 and get a new D2v. But I don't believe Anthem is doing that any more.
That means if you buy a D2, your upgrade path down the road to a D2v would be to sell the D2 -- perhaps by making some sort of trade-in deal at an Anthem dealer.
Also be aware that some D2 units were sold BEFORE ARC was bundled with the unit. A big part of the value of the Anthem stuff is its Room Correction system for audio (ARC). Check that your used D2 comes with ARC. If not, then you CAN buy an ARC kit for the D2, but that will run you about another $400. That gets you the ARC microphone, mic stand, cable, and software. (There is no hardware change needed in the D2 to use the ARC upgrade kit with it.)
--Bob
post #37426 of 40764
Russ
Bummer not for me but good for you smile.gif !
post #37427 of 40764
-Brian
Agon has some really mint ones (less than 6 weeks) for about $6.5k. A few older ones for $6K...
post #37428 of 40764
hello Bob.
Peter ..congrats! You've tamed that ugly null you had in the past setup and now things should sound great! smile.gif
post #37429 of 40764
hello Bob.
320320532
I'm curious as to what ARC calculated for your room gain. looks like you set it to these values. did you chance cutoffs too?
post #37430 of 40764
ARC set the speakers to 100hz and sub Cut off to 120hz. Roomgain what set to 3.8 dB.
I have thosen these settings above, becurse this is where it Sounds Best to me.
post #37431 of 40764
3D kits begin shipping today to those who bought from 2010, then to others who want to upgrade.
John
post #37432 of 40764
John
Good news!
http://anthemelectronics.blogspot.ca/2012/06/introducing-anthem-avm-50v-3d-and-d2v.html
post #37433 of 40764
Just saw that Anthem released the 3D kit and it is free for purchases in 2010 and up. It willbe interesting to see how they handle and prove when a pre/pro was bought by the end user and not the delaer. As I know mine was sitting on a shelf ain the warehouse for a while.
Anyone know how they will handle this and or not having a local dealer. I am moving to the middle of nowhere in 3 days!
post #37434 of 40764
were do you see that it is free.  I do qualify
post #37435 of 40764
It is true.
John
post #37436 of 40764
It is true.
John
FAQs on Anthems page or here?
post #37437 of 40764
well I dont see it anywhere.
post #37438 of 40764
From Nick.
John
post #37439 of 40764
not on Anthems site,  just announces the 3D no info on free anyware.   can one of you guys give me a link please.   Perhaps I drank too much JD in my youth!
post #37440 of 40764
See the link above.
