AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide - Page 1281
post #38401 of 40785
Originally Posted by drhankz View Post
Subscription Fee Every Year. Nothing is for Nothing
Actually, for TiVo, you only need to pay for the first year. You can cancel after that. I had called them a few months ago during my initial explorations.
post #38402 of 40785
Originally Posted by Thxtheater View Post
I need some help and suggestions here from the group: I'm looking for a good TV tuner solution to use with my AVM50v. I'm decommissioning Cable in my house and transitioning to over-the-air HD and streaming. Ideally, I'd like to route everything into my Anthem for two reasons:
1) Ease of switching and audio purposes.
2) Use of the 50v video card and options
3) Ability to send audio and video to a second zone where I have a second HDTV.
So, I believe that the only missing piece for over-the-air is an HD Tuner solution that I can use to give me either component or HDMI out.
Has anyone used a truly good solution?
Currently, I'm running the antenna to my HDTV and then using Toslink out back to my AVM50v.
I'd appreciate any feedback and additional suggestions.
Theo
Check out the Channel Master CM-7001 Antenna and Cable Tuner. More info from Channel Master...
post #38403 of 40785
Hi
It appears that it maybe time to upgrade my avm 50v firmware form 2.11 for the first time since there is a posted 3.09. I am hoping I can get a bit of help from the ones in the know. I have arc software 3.02 installed.
1)
Is Bobs’ belt & suspenders approach still the preferred way to flash or is it now more slip streamed as far a retaining settings?
2)
I have backed up with Settings Backup creating a small 9.20 KB .a20 file is this approximately the correct size?
3)
I have tried to back up my settings with LiveVideoSettingsEditor with no success. I connect and it indicates “success found avm 50" not 50 v however when I click “get” it just hangs with pop up indicating “please wait.... receiving data.....” after an hour I hit abort in the pop up and the window closes so it is not frozen but never finishes. This is the com cable I have ran arc on a number of times without problem. But I need it working flawlessly now for sure. Do I need these settles and what maybe the fix?
4)
The software did not come with the Anthem Setup Editor program where would I download it? And is it required.
Regards
post #38404 of 40785
Originally Posted by Shayne2 View Post
Hi
1)
2)
3)
4)
Regards
Most people just do,
1. Disconnect HDMI sources.
2. Save User Setting
3. Load Default Settings
4. Start firmware upgrade.
Personally I just start without doing 1-4 but I prefer you do 1-4 so I don't get blamed if it doesn't work.wink.gif
John
post #38405 of 40785
Thanks for the Channel Master reference. I had read a review about the ChannelMasterTV product on HomeTheater and was left with the impression of the extremely hot operating temperature. I didn't realize that they had other products too that were akin to more traditional tuner solutions. This looks like a good direction. Thanks for that reference. I'm going to look at this in more detail.
Theo
post #38406 of 40785
Originally Posted by dmusoke View Post
Has anyone ever noticed how 'noisy' the D2v can be?
When i mute the D2v sound and place my ears next to my rear speakers(closest to the unit), i hear significant broadband noise from speaker. When i shutoff the D2v, then the noise level dramatically drops and only hear the faint amplifier noise. When i turn on the D2v and mute it, the noise level jumps up again. I even went and bought RCA shorting caps and placed them on all analog and digital inputs on my D2v. Noise levels didn't change much, if at all.
Even as a long short, i replaced my RCA connections to my amp with XLRs. Meh ...tough to tell if that helped at all. Noise is just as much as with the RCAs.
In my system anyway, the D2v is the noisiest component. Sad that one pays $8K for a pre-pro that isn't as quiet as you'd expect.
Stone Cold Quite here with THOUSANDS of Watts of Audio
Originally Posted by thestewman View Post
+ 1
Maybe start disconnecting each of your sources to the D2v one at a time and see if you can find the source of the noise that the D2v is amplifying.
Originally Posted by gerard1meehan View Post
Not to jump on the band wagon, but same here. I do not experiance that noise at all. Perhaps it is comming from anther sorce? Or you are getting cross talk from a router or a cell phone?
I have shut everything down as in lights, AC, ETC. the works. I have had my ears to my speakers doing this just the other night as I thought one of my Paradigm S8’s was having a tweeter or clicking issue. That issue was a rouge cricket, but I could hear it with during the playback of a movie. With that I had my whole system fired up (D2v, 2 x P2, and a P5 Amps, Oppo 83, Sonos, & DVR Sat box) and muted it and heard nothing. My S8’s fronts are 4 feet from my D2v, and my Sub 1 is less than two feet from it and no noise.
Do you have a line conditioned between your D2v and the outlet? Any other device on the same circuit as the amps?
By the way I had bunch of issues like this in an earlier system and it wound up that every time my blackberry sent or received and e-mail I got the noise you are referring to.
Originally Posted by Bob Pariseau View Post
^ Check the Hum and Hiss FAQ in the Audio Theory forum here for suggestions.
A common source of hiss is radio frequency interference from room light dimmers, perhaps in a different room. To test this remove power from the dimmer (not just turn it down). Many dimmers have a cutoff switch on them you are supposed to use before changing bulbs -- or cut off the power at the circuit breaker box.
60Hz interference is typically either ground loop current (see that FAQ) or power line interference that has penetrated cables which have lesser quality shielding. That last can often be addressed simply by shifting cables around.
Isolating the cause of ground loop current requires some logical thinking about how to cable things up in different combos. Ground loop current is garbage current (often 60Hz power line interference) that travels between your devices along the shields of the cables connecting them looking for a path back to ground. A device in the path doesn't even have to be turned on to form the next link in the path. The exit to ground is often through the 3rd pin of a 3-prong power outlet on some device. The most common source of ground loop garbage is stuff coming into your house on the shield of an improperly grounded cable or satellite TV feed wire. The next most common is due to using multiple power outlets which happen to be wired to different circuits with different ground potential. All of this stuff has easy fixes once you isolate the cause.
--Bob
Hey all:
After much anguish and toil late into the night yesterday, i managed to find the source of the hum. It wasn't the D2v as i had thought but it was the external bass manager i use to phase/time align my subs(AS-EQ1). The sub RCA outputs from my D2v are plugged into the EQ1 and whose output goes to my subwoofers. Somehow, connecting the D2v into the EQ1 caused the hum i have been experiening. Not sure why the shields of the d2v subouts and the EQ1 created a ground loop of sorts.
Anyway, i used the XLR outs of the D2v and went into a balun whose output fed the RCA inputs of the EQ1. Then its RCA outputs are fed back into the balun, which outputs an XLR outs for my sub. Now the noise level is gone. Thank you all for the help smile.gif.
- David
post #38407 of 40785
John
Thank you very much John. Status says 3.09 and i am listinging to Vavaldi again. Toke a really long time programing the video processor but it verified and gave me the green check mark of approval smile.gif . Not the most relaxing thing i have done today for sure. wink.gif Thanks again you guys are great.
Regards
post #38408 of 40785
Regards
Because you updated from a much earlier version, the video files took much longer to finish . Glad it worked for you.
John
post #38409 of 40785
Originally Posted by Nick @ Anthem View Post
What happens if the system consists of nothing but D2v, one amp, any number of speakers, both power cords connected to the same power source, and no other connections whatsoever besides power and D2v-amp interconnect and speaker? Please send your response to tech support - I'm about to start my regular work week and won't be monitoring posts.
Just by way of an update I have tried this - one amp, one XLR connection from the D2v to the amp, all other connectors removed - the noise remains. I also, switched over to a different amp, and performed the test again - the noise is still there.
post #38410 of 40785
Thanks again for the help with 3.09 upgrade. I am wondering if this is the firmware for the 3D board up grade and if so after the board swap should all be up and running or is there a difference and i need to flash again?
Regards
post #38411 of 40785
Regards
I believe you'll have to redo the V3.09 installation to properly initialize the newly installed hardware. Since your video board is now already updated with the new firmware, the re-install will take only about 15 minutes.
--Bob
post #38412 of 40785
Was the other amp also XLR? If not, then it sounds like a D2v problem. Please try RCA connection if you haven't and if noise remains contact your dealer or tech support (we usually can't fix something that we can't reproduce here).
This might have to do with the XLR side:
http://www.rane.com/note165.html
Edited by Nick @ Anthem - 9/12/12 at 7:37am
post #38413 of 40785
ah but it might have taken less time if you said "hum" in your last post, which said, "When i mute the D2v sound and place my ears next to my rear speakers(closest to the unit), i hear significant broadband noise from speaker."
There is a big difference between hum and broadband noise, aka hiss, pink noise, white noise, random noise, and waterfall sound.
Public service announcement: Please always be precise when describing a problem or noise. These are all different but often confused (certainly not singling you out dmusoke):
hiss - there will always be some, but should not be audible from the listening area with average-efficiency speakers
hum - almost always caused by a ground loop, can be caused by bad filter cap in power amp (or bad design) but I haven't seen that since the tube days
buzz - most often caused when there is a ground loop with cable TV connection, at least when I was in tech support. Quick easy test - disconnect cable to see if buzz disappears. It just occurred to me that I haven't heard anyone mention it since the switch to digital cable, no idea whether that amounts to anything. Also caused by faulty ground connection in interconnect. There are other causes but they're relatively rare as far as everyday HT is concerned.
snap, crackle, pop, whine - exactly what each name implies
digital noise - can mean anything, please be more specific
When reporting any of the above please always indicate relative loudness, such as how far from speaker one has ot stand to hear it, the speaker model or efficiency if known, and exactly when noise does and doesn't occur. This could save a ton of time in the end.
post #38414 of 40785
Yes, both tests were via XLR. I will try RCA tonight. Andrew in Tech Support is currently helping me try a few things to troubleshoot the problem.
To clarify on the noise, following your post above, it is a high pitched hum - I may have referred to it as a whine previously because of the high pitch (though I'm not sure at which point a high pitched hum becomes a whine? smile.gif ) - this is combined with excessive hiss. It's just about audible from 15ft, clearly audible from a few feet.
Thanks for the link to the Rane article - I have been doing a fair bit of reading on the XLR wiring. Can you (or anyone else) confirm whether PIN 1 on the D2v's XLR terminals are wired to signal ground or chassis ground?
post #38415 of 40785
Believe it or not, BEFORE i had the problems mentioned a few posts above, i too had a high-pitched noise in ALL of my speakers from the D2v when i power the bass manager(BM) from my racks built-in 12VDC power supply rack-mount module. Regardless of whatever input i used on the D2v, it was always there which was frustrating.
I panicked for a long while until then ended up using a standard 12V AC/DC converter that i plugged into my 120VAC outlet to feed my BM. Powering the BM using the racks built in 12v supply caused high-pitched noise. Powering it using a standard 12V wall wart eliminated the noise. Why ???? Really don't know but it worked.
- David
Edited by dmusoke - 9/12/12 at 10:37pm
post #38416 of 40785
^ That's a perfect example of why it's important to keep an open mind, treating each case as its own and not relying entirely on previous cases to try and match symptoms with causes. Tech support makes seemingly unusual reqests at times like temporarily bypassing any kind of power conditioning and connecting power cords straight into the wall. Along with braking the system down to a basic one these are just inital steps which can lead to any number of findings. The rack itself can be the cause of a ground loop, so sometimes equipment has to be pulled right out, not just interconnects.
post #38417 of 40785
It's also about what's shielded in addition to what the shield is connected to, and our equipment meets Neil Muncy's good practice recommendations. The XLR socket's construction plays into it too.
By swapping in RCA as the first step I just wanted to see whether the noise was XLR-related for any reason before further investigation.
post #38418 of 40785
I tested again last night Nick, and basically unplugged everything both from the back of the D2v, and unplugged all equipment from each other and from the mains. Then I just plugged the D2v and one amp directly into the wall socket and tested firstly with and XLR cable and then an RCA cable. In both cases the noise was present, and was alternating between a constant high(ish) pitched hum/whine, and a warbling/variable pitched sound, every couple of minutes.
When I went back to the rear of the rack, and turn off the amp again, I could hear the exact same sound coming from inside the D2v itself - but with a more high pitched electrical/static type sound (I hadn't hear this before with all the other equipment on). This sound also changed from a constant pitch tone to a warbling tone. I switched the amp back on and checked the speaker, and the sound it emitted (from constant to warble) changed at the same point the sound changed that was coming from the D2v.
I switched everything else off and unplugged it, and just kept the D2v on and the noise coming from it continued.
I think therefore my beloved D2v must have developed a fault.
Andrew at Anthem Tech Support has already referred my case to the UK Support team, and Tom Garrett has already contacted me to arrange transport of my D2v to their premises for testing/repair. I guess I get to try out Anthem's legendary customer support!
post #38419 of 40785
Greetings all!
Is anyone else seeing an increase in the audio volume bug since 3.09 update? (I don't know if this affects D2v users too)
I have a 50v and since I upgraded to 3.09 (I was previously on the 3.0 build) I've noticed a pretty dramatic increase in the number of times I get the audio bug on startup. To summarize, when you startup the Anthem, volume sounds like it's been muted. You need to crank up the volume to -10 for it to be equivalent to somewhere between -55 to -45 normally. Turning the unit off and then on again normally corrects the issue and volume is normal again.
Prior to the 3.09 update, I'd get the bug perhaps twice or three times a month with almost daily use of the 50v. Now, since the update, I'm getting the audio bug as often as 2-3 times/week. It's very strange and I want to know if I'm the only one.
I'm also assuming that there's no further progress on correcting this issue?
Theo
post #38420 of 40785
I experience the bug occasionaly on my 50v but I don't think the number of occurances has increased since upgrading to 3.09.
post #38421 of 40785
Thanks for that validation. It could just be a cluster on my end and perception that's why I wanted to ask around.
post #38422 of 40785
This occurred quite a few versions back but haven't had it since.
John
post #38423 of 40785
Running v 3.09 on my avm50v. Not a single issue after upgrading. Low volume before upgrade had happen maby ten times in a year
post #38424 of 40785
Greetings all!
Theo
I noticed it also with my 50v, but a couple of weeks ago I had to run ARC again because of some changes I made to my system and I haven't had it happen since. Of course now that I said that, it will probably happen the next time I turn it on. smile.gif
post #38425 of 40785
I have a 50v and have never had the audio come on low (muted). The audio would just not come on at all and I would need to cycle power or sometimes switch to another source and back would create the handshake. Maybe i just did not hear it since my on volume is set a -35 db but I think not since the sub did not power on with the knock sound? High speed HDMI cables helped but did not correct this problem completely. This was with 2.11 and as of yet have had no issues with 3.09. The wife mentioned "it is nice to turn it on and you get sound beofre you would not alot of the times" I have her monitoring the no audio for me also. Will repost if that changes but to date 3.09 seems to be a improvement.
Regards
post #38426 of 40785
Glad you brought this up. I have a 50V and had no low volume or muted volume issues on startup while I was running 2.10. Since I installed 3.09 I have low volume on startup approximately 20% of the time. Not muted volume always low volume.
I figured Anthem would be issuing a software upgrade shortly to correct this problem since it was reported by a couple of other users a while back. Maybe not, since it does not seem to be widespread.
I wonder if any new purchasers of their product are having this problem since new units apparently are being shipped with 3.09 installed? And if they are what happens if you are not aware that you are having a low volume issue and try to run ARC?
Did you try to reinstall 3.09 to see if that would correct the problem? I haven't to this point. I guess i was just happy that my first install seemed to go okay.
post #38427 of 40785
I just don't understand the root of the problem. Nick... I know you sometimes lurk this forum; is there any light you can shed on this for us????
post #38428 of 40785
^ So far very little... we've been getting reports for a while but it's been very difficult to reproduce. About a week or two ago someone mentioned that the problem occurs when powering on to a certain source, one which has an nVidia card. Aside from the problem apparently being AVM 50v-only, this is the first real clue! If you observe the problem please send details to tech support, especially the model number of the source being powered on to and what it's playing if anything. Hopefully we can put enough pieces of the puzzle together that way.
post #38429 of 40785
Hey guys ... need some advice here.
My rack is full on equipment that has many LED lights...red, green blue and amber. Some blink frequently but others are steady. Unfortunately, this makes for a Las Vegas style rack which is very destracting.
Anyone know of some HT light friendly covers?
post #38430 of 40785
I use small squares of tar paper left over from when I built my HT, and they let no light though them. The price is right but if you use the room during the day, you might not like the look. In low lighting they are invisible.
John
