Originally Posted by
thestewman
I know you have probably looked at this numerous times before but, Please double check
Do you have SACD Priority: Set as Multi-Channel – To play the multi-channel surround audio layer
Do you have HDMI Audio: Set as LPCM – Digital audio output via HDMI
MOST IMPORTANT
Do you have a
coaxial or optical cable connected between the Anthem and the OPPO ?
If so remove it.
What source are you using to play your SACDs ?
What MODE have you preselected for that source in setup ?
Let me know
SACD is set for the Multichannel layer.
HDMI Audio is set to LPCM.
No coax or optical digital connection - just HDMI, the analog 5.1, and a network cable.
Does the source matter? I've tried it on one of the DVD sources as well as the 6-channel. Since you can completely configure them, I didn't think it mattered. Either way, set to HDMI audio, Auto Dig NO, neither works with multichannel SACD, both work fine with stereo SACD.
I found and installed the original 6ft OPPO HDMI cable. No change. The OPPO is definitely showing it's reading the multichannel layer and outputting by PCM on the front panel as well as the OSD.
I'm afraid I'm going to have to drop back to firmware v1.33.
Does anyone know if all saved settings survive a firmware change? I'd hate to have to redo the whole setup...
Thanks everyone for all the help.
-Ravi
