Understood, but his measured response could also be a placement issue... that curve would seem to indicate a lack of low frequency boundry gain. It's an SVS sub, though I'm not familiar with that model and I don't see it on their site, but the PB12-NSD is flat to 18hz, and the PB1000 (a 10" driver) is flat to 19hz... so it's not unreasonable his his could easily hit 20hz.
Featured Stories
Topics Discussed
- categoryReceivers Amplifiers
Related Forum Threads
- Anthem MRX Receivers - 300, 500, 700 Owners Thread & Tweaking Guide Last post on Today at 12:41 pm in Receivers, Amps, and Processors
- probem with oppo hdmi handsake with onkyo receiver Last post on 3/2/13 at 2:22pm in Blu-ray Players
- Need ideas for a receiver Last post on 1/30/13 at 1:17pm in Receivers, Amps, and Processors
- Can I send the audio from the smart apps like Netflix OUT to a receiver from a Panasonic ET5? Last post on 2/6/13 at 7:17am in LCD Flat Panel Displays
- Refurbished Polk Speakers Direct from Polk? Last post on 4/7/13 at 11:10am in Speakers
Related Reviews
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide - Page 1317
Gear mentioned in this thread:
- jayray
- Trader Feedback: 0
- offline
- 4,708 Posts. Joined 10/2002
- Select All Posts By This User
I just don't think 18 or 19 Hz is going to make much difference as they are probably best case numbers. They'll drop in loudness at high volume likely so until the location is optimized, I'd stick with auto.
John
- ehlarson
- Autonomous Biological System
- offline
- 2,186 Posts. Joined 8/2004
So I finally got some time over Christmas to update the firmware in my D2V from 2. something or another to 3.09, and ARC to 3.02.
The process went pretty smoothly. I then remeasured my room and tried a couple of settings for the high frequency cutoff. 5K sounds a bit dull to me so I'm using 12K right now, which I think sounds better but isn't harsh. I also tried 15K but that sounded a bit harsh There don't seem to be any resonances or suckouts that ARC can't deal with so the results look pretty good.
The thing that I have a question about is the room gain. Since the room this is in opens into another room I'm getting a number of 0.6. I read somewhere that a gain of 2-4 is normal and what movies are typically mixed for. My system also sounds a bit thin in the upper bass.
What is the best way to deal with this?
I did some screen caps of the ARC application window to perhaps help describe what is going on:
Any ideas would be greatly appreciated.
- tranle
- offline
- 438 Posts. Joined 4/2004
Sometime the dip you see the higher frequency may not be due to your speakers but to your mic.
- Bob Pariseau
- Read the FAQ!
- offline
- 24,288 Posts. Joined 7/2004
Based on the red Measured curves, it looks like your room really has little to no inherent Room Gain. That is, it doesn't look like ARC was fooled by any dips in the uncorrected speaker output. The low inherent Room Gain could easily be due to the open floor plan, or, if you have bass treatments on the walls they would also reduce it. You could raise Room Gain in Targets, but you should probably not try to go much above 2dB so as to keep the ARC response closer to the natural response of the room.
Now, you do have some dips in bass that might be harder for ARC to correct if you increase the Room Gain (since that means ARC needs to apply more boost to fill those dips up to the now higher Target). So try it and see what the charts look like. Adding Room Gain will give you fuller mid bass.
Another important thing to do is check the Phase setting for the Sub. If Phase is wrong for the Sub (compared to the main speakers) then you will be getting cancellation through the Crossover octave of frequencies where Sub and Mains are playing the same content. That's a classic cause of "anemic" bass symptoms because the octave below the Crossover frequencies is the cornerstone of the bass you hear. Phase is something you have to set Manually. ARC can't adjust for Phase because it doesn't hear the Sub playing at the same time as any Main speakers.
At the high end, your Measured data doesn't give me a lot of confidence that the mic is hearing things particularly well up there, so I'd be loathe to push Max EQ Frequency too far. You got that yourself when you tried 15KHz.
I think instead you should double check the pointing of your speakers. Treble output from speakers is much more directional than lower frequencies. If the speakers are not mounted at seated ear height then pay particular attention to their vertical pointing. Center and the Surrounds can point at mic position #1. Left Front and Right Front should not point directly at mic positions #1. The usual Rule of Thumb is to swing them only 1/3 of the angle from pointing straight at the back wall towards pointing at mic position #1.
Also keep in mind that for proper treble Measurement the ARC mic must be pointed straight up at each mic position, and it should be set with the mic tip at seated ear height (unless you have to adjust a bit to clear a seat back). Also keep the mic about 18 inches away from walls and if you have tall seat backs also movie it a foot closer to the screen to be away from them.
With any luck some corrections here will give you better looking Measured treble data, meaning you can push Max EQ Frequency higher without "correcting" bogus data up there.
--Bob
- thestewman
- offline
- 1,107 Posts. Joined 10/2004
Looks like your levels are too low also... about 68db, when they should be about 75db... I believe that is why your ARC mic picked up so much high frequency "noise" on your sub chart. Otherwise, everything looks fine. If your sub is capable, try setting it to "flat" in the targets window. This will flatten the curve down to 20hz. But be careful, if your sub is not capable of reproducing frequencies that low, you may overload it and damage the sub.
Anthem has stated that the actual levels are not critical and ARC uses them and resets them while processing
I can say that it sounds great to me, especially when compared to my earlier measurements. The first "real" test was District 9 - when they were being chased through the compound with the helicopters circling all around, the surround was amazing to me.
Do you mean at the low-end of the curve? It doesn't look (to me) that different than the other charts here. It looks to follow the Target curve pretty closely..I guess I am not understanding something.
Yes, I asked about this awhile back, when someone else was having the same issue. I did adjust the noise levels as per the thread instructions to 75db using my SPL meter prior to my measuring. I guess as thestewman says, I don't need to worry about it?
...why your ARC mic picked up so much high frequency "noise" on your sub chart. Otherwise, everything looks fine. If your sub is capable, try setting it to "flat" in the targets window. This will flatten the curve down to 20hz. But be careful, if your sub is not capable of reproducing frequencies that low, you may overload it and damage the sub.
Not sure what to make of all of this. I will have to look at the sub's specs. I'm kind of limited in my placement options, my room is far from ideal...I'm set up in the living room of a 1970's-era townhouse.
Thanks very much for all the feedback, it is appreciated.
- Mark
- thestewman
- offline
- Mark
Compare these two subs, yours and ehlarson. Notice how your subs corrected curve (Green Line) starts to fall in output after about 40hz and the other sub's output
is strong all the way to 20hz where it rises a bit.
Now that does not mean your sub will sound bad. Realistically there is not much output in those super low regions and it is not the area where the bass impact comes from
that most home theater owners are striving for to get the bass impact.
- ehlarson
- offline
Some of the SVS subs have a way to tune for a particular frequency range by inserting a plug into a port. It may be worth doing to shift the sub response lower if the sub supports this.
- Texas steve
- D2v, Sub25, Oppo83
- offline
- 536 Posts. Joined 5/2004
Correct, that's the "dive" I was talking about. Where you will miss it is not music etc but 5.1 on the .1 effects of movies etc.
Oh, ok, I finally realized as I was composing this that I should be reading the curve from right-to-left, I was getting confused because I was reading in the other direction...thanks (to you and Texas Steve) for the explanation.
I checked the specs for my sub, and it says specifically
Frequency Response: 20Hz - 150Hz ± 3dB
(quasi-anechoic) (typical in-room response 3-5Hz deeper)
Does that mean I can (or should) try the "flat" setting? I hear you saying maybe I should just let it go.
I do have neighbors on both sides, maybe for their peace I should leave it - I'm already afraid I'm rattling their dishes sometimes.
- Mark
P.S. Oh, and my sub doesn't have the plugable-port that ehlarson is referring to.
- boyce89976
- AVM 50/Paradigm FAN!
- offline
- 266 Posts. Joined 11/2005
- Mark
The easiest way to check placement is to put the sub in your listening position, then move around the room until you get the strongest, most articulate bass response... that position is where you want your sub to be.
- thestewman
- offline
- Mark
Your SVS sub is fully protected by a steep roll off from 20hz and down .
But, What more could you demand from a single 10" Driver and a 300 watt amp ?
Edited by thestewman - 1/4/13 at 1:34pm
- dmusoke
- offline
- 2,046 Posts. Joined 7/2009
- Mark
Mark:
Since the in-room response is 3-5Hz deeper, it'd imply the new in-room frequency response be from 17Hz - 150Hz ±3dB even down to 15Hz depending on the room...I would definately try the flat setting IMO. Your sub frequency response is not atypical at all.
- ehlarson
- offline
No bass treatments. Just a big ole' opening into another room. I do have plenty of sub output that I'm not using in the current configuration though.
When I originally set up the sub I used a Velodyne SMS-1 to set the phase. Perhaps it's time to dig out the cables for that again.
Speaker pointing is an interesting idea.
According to the measurements of my speakers that were done in Stereophile their off axis response is pretty good up to 10K or so. Because of that I'd really like to have my max EQ no lower than 10K. When I tried 5K my system sounded pretty dull.
Thanks Bob.
- boyce89976
- offline
I have a strange problem that cropped up tonight. I turned the system on so my girls could watch a bluray, and there was a CD in the tray that started playing automatically, through the XLRs to my AVM 50v. The problem, is that it was REALLY loud (I have the startup volume set to -40). I went into the menu on the AVM50 to check ANLG Input level, which I had previously set at -6db. It was still set to -6db, but I selected it anyway, and the clipping meter that shows up when you adjust input level was almost max'd out, I had the pink bar above the green on solid, with the red bar above the pink flashing on and off with peaks. I adjusted the input level on the AVM to -20 (max range) and it didn't move the meter much at all... it was still showing clipping on the meter on the loudest peaks. So, I adjust the output volume on the Oppo down to 80 (from 100) and I was comfortably in the green. When I exited out of everything, I switched back and forth between ANLG Dir and HDMI on the AVM 50, and the ANLG Dir was close to 12db lower in output than the HDMI. I went back into the ANLG Input level menu on the AVM 50 and the clipping meter was significantly lower than it was before over the same passage of music. So, I left the Oppo at -80, and adjusted the AVM 50 input level up to 0db, while still comfortably in the green on the clipping meter. (This setting is still about 3db softer than the same music over HDMI). Exit out and go back in, and the clipping meter shows clipping again. I'm stumped. Does anyone know how to properly set the levels? I'm sure the HDMI is not clipping, and I'm NOT sure the ANLG IS clipping, since the clipping meter in the AVM 50 seems to change every time I exit and re-enter. I had initially assumed I could set the levels the same between the ANLG and HDMI, but now not so sure. BTW, I never heard any audible clipping under any of these scenarios.
The other problem I'm having... in the Oppo setup menu, under speaker configuration, I can't get any output tones. I have all speakers set to large, and the distance set to 12ft because I'm using ARC in the AVM 50... does that turn the tones off since I'm not using the Oppo's speaker setup?
- boyce89976
- offline
- airboyd
- offline
- 29 Posts. Joined 12/2007
Can someone help me figure out why my ARC charts keep dropping below 75db?
You can see from my previous posts that I've had the tone set properly using Bob's list and checked it with a SPL meter for 75db. With the test tone of +3THX is where my speakers have always had a response chart showing 75db. I ran three separate ARC reads going from 0 to +3 to +6 and all the charts show the response barely passing 70db. I gave up after the third one and went back to +3THX.
Is it microphone or some other issue? More importantly, does it matter?
I've had consistent +75db since I got the ARC between +0 and +3 this is a new issue for me.
Attached +3THX charts, 4th run of the day.
My charts started reading 65 dbs all of a sudden about a year ago and I was told it is some sort of glitch but nothing to worry about.
It drove me nuts the day I was doing it. Thanks.
- studlygoorite
- offline
- 667 Posts. Joined 1/2007
- studlygoorite
- offline
- AVfile
- offline
- 1,448 Posts. Joined 12/2002
^ Check his subwoofer polarity and phase. He may be losing bass due to cancellation vs. the main speakers through the Crossover octave of frequencies.
Check that he's not doing something silly like playing movies with Secondary Audio Mixing enabled -- which causes the lossy compatibility track to be used in lieu of the lossless track he thinks he is playing (typically authored with less bass). He'll have the same problem if he's using Optical/Coax Digital cabling for audio instead of HDMI.
Check that he has Dynamic Range Control (may be called different things) turned off in whichever device is decoding the Blu-ray Bitstreams. (Compare Bitstream vs. LPCM input.)
--Bob
He can also set the sub to FLAT in the advanced settings menu of the target screen. This should extend the upper bandwidth of the subwoofer to include frequencies up to 120Hz which are used by movies for LFE. Mains, even though have a low extension, simply can't do justice to the LFE that movies have.
It (FLAT setting) will flatten the sub frequency response from 20Hz to its measured 3dB bandwidth (up to 120Hz) ensuring equal reproduction of those frequencies by the sub. It will also NOT correct frequencies below 20Hz so any LFE belwo 20Hz will go unfiltered as intended by the movie producer.
No worries as the Sub12 can handle any infrasonics it may encounter...
Just a suggestion, but make sure the MRX is running the latest firmware, v50.25, as the was an issue with an earlier version that gave correct ARC graphs, but did not infact apply any correct to the Sub or Surround channels, only Front Left & Right - on "some units".
Regards, Mike.
Thanks all! I went over to my friend's house and confirmed what he was hearing. It reminded me of the same lack of impact that I heard with the Sub12 when I auditioned it in my own home. I ended up keeping my ancient Mirage bipolar 2x12" sub. The Paradigm isn't a bad sub, in fact very clean sounding, and his sub chart looks way better than mine but there seems to be something missing at times. We did check phase and levels using various test tones and my SPL meter, but adjusting the phase had no effect on broadband pink noise. It did unevenly raise the response on some discrete test tones at 40 and 80Hz.
Mike - turns out he has in fact been running the old MRX formware with the bug! So he updated to the latest and noticed volume levels changed. Everything, including the sub gets a bit softer now when ARC is turned on, where before ARC had very little effect... what a horrible bug to have! So if anything the bass is even leaner now. The boomy Nowlan Dark Knight movies are no longer boomy and sound just right to both of us. However the majority of other reference material (Transformers, Expendables, Inception) are seriously lacking bass impact. With ARC turned off we liked the sound of the sub a bit better on these movies.
A long time ago I noticed the ARC in the MRX is less powerful than our processors, so I had him reduce the upper correction limit to 1k (max is 5k) in order to let ARC concentrate on the bass. I think this was a bad idea because it resulted in lean bass and slightly harsh treble (most of his speakers have a small peak at 2k now uncorrected. I am going to suggest he store another ARC solution with maximal treble correction at the expense of bass correction in the Music mode. This should provide a warmer sound, and he can try both solutions on the fly, to suit the program material.
I also suggested getting a second sub placed elsewhere in the room to "fill in the gaps". Finally I wonder if 7 speakers with 5 drivers each is too much for the MRX500. A separate amp for the front speakers might be in his future.
- jayray
- offline
I've tested my mrx500 with a 7.1 system and it had no problem in a 14x18x9 room. A Servo 15 was the sub and it sounded fantastic. ARC in the the MRX uses the same resources for the Sub as in the pre/pros.
John
Edited by jayray - 1/5/13 at 4:18pm
- Kris Deering
- Trader Feedback: +8
- Avid HD Watcher
- offline
- 5,997 Posts. Joined 10/2002
I posted this in the Oppo 105 forum also, but since it could be an Anthem issue, thought I should post here also:
Why are you using the volume control on the Oppo at all? Why not set to fixed volume output into the Anthem and use the volume control on the Anthem??
- boyce89976
- offline
Because of this: The pic below is with the Oppo's volume set to 100, connected to the Anthem via XLR and set up on the 2-CH Bal input in the setup menu. Even with input trim on the Anthem set to -20dB, the level meter shows maxed-out clipping at the inputs. What I don't know is if it's a glitch, or if it's really clipping at the inputs. Any help you can provide on what I'm doing wrong would be greatly appreciated!
- Bob Pariseau
- Read the FAQ!
- offline
Use -6dB for the level adjustment in the D2v for the XLR inputs coming from the OPPO. You can then use Volume FIXED (or Variable 100) in the OPPO for its XLR output.
You can verify your levels with a calibration disc. Using Stereo audio mode in both cases, and ANALOG-DSP input for the Analog case the, XLR inputs should match the HDMI input.
(Using ANALOG-DIRECT the levels may differ since you have, in essence disabled ARC and bass steering. Whether the difference is enough to be noticeable depends on what ARC is doing in your room.)
--Bob
Edited by Bob Pariseau - 1/5/13 at 6:45pm
- dmusoke
- offline
Bob:
Why am i getting the pink bar(possible clipping) when i'm using Analog-DSP with my 105 XLR outs with the gain level set to -6dB in the Anthem menu?
I thought you said the Oppo XLR outs and Anthem 2CH XLR in's are compatible when levels are set to -6dB? Anthems D2v datasheet doesn't seem to give the maximum input voltage on its XLR/RCA inputs. If anyone knows, please let me know and show me where that data is...
- boyce89976
- offline
As stated in the OPPO thread where you also posted this, that bar graph is not valid when using ANALOG-DIRECT. The fact that it is showing at all is a bug (minor) in the UI of the Anthem.
--Bob
Thanks Bob, truly appreciate the help! I wasn't sure if this was an Oppo issue or an Anthem issue, hence posting the question in both forums. I got my Anthem just before Christmas, and the Oppo last week, so both are brand new to me (came from Pioneer Elite and Panasonic), so I appreciate the patience as I learn the new gear. I'm a quick study though!
Levels match perfectly between HDMI and 2-CH Analog with the settings you suggest.
- boyce89976
- offline
Bob:
Based on Bob's response, I would think you're clipping the DSP inputs on the D2v during conversion from Analog back to Digital for DSP processing. But, I'm obviously no expert!
- Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide
Recent Discussions
- › Official Samsung UNXXF7100 Owners Thread 25 seconds ago
- › NE Spring Speaker Shootout results thread - April 13, 2013 27 seconds ago
- › Hot Off The Press: The Latest TV News and Information 52 seconds ago
- › List of Reference Level, High Sensitivity & SPL Speakers 52 seconds ago
- › 5.1/2 AVRs 2 minutes ago
- › iView-3500STB DVR & Tuner Owners Thread 2 minutes ago
- › Official OPPO BDP-105 Owner's Thread 3 minutes ago
- › GTX 680 FTW Overclock help 4 minutes ago
- › The 'Official' 2013 Denon "E Series" / "X Series" AVR Model Owner's... 4 minutes ago
- › Suggestion on High-End media streaming solution!! 5 minutes ago
Recent Reviews
- › Sony BRAVIA KDL55HX850 55-Inch LED HDTV by Falgoonit
- › Marantz AV8801 by zuluwalker
- › VIZIO 55 inch Class LED - M3D550KDE by indept
- › Optoma GT700 3D Game Time Projector by paul65000
- › InFocus X1A DLP Multimedia Video Projector by coastercard
- › BenQ W1070 1080P 3D Projector by arjjr
- › Epson PowerLite Home Cinema 8350 by Natros
- › Epson V11H501020 PowerLite Home Cinema 3020 2D and 3D 1080p Home... by sailorb
- › Elite Screens ER110WH1 Sable Fixed Frame (110" 16:9 AR) by DDT0C
- › Elite Screens ER100WH1-A1080P2 Sable Fixed Frame Projection Screen by DDT0C
New Articles
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
- › Clarus Power Cords by Good Tunes
- › A Theater Is Just Is Not A Theater, Unless... by David Bott
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
