Originally Posted by
paradigm25
It is hard to describe sound; but I will try. I lack clarity and the feel of a large sound stage, or someone once said as if you have thrown a towel on the speakers. Lack of enough bass is another big thing. Lot of my friends and family have heard the system, and no one ever said that it sounds good, not that I care, but just to tell you that its not just me. It sounds little open when I use Analog Audio outs form Oppo and go AnlgDIR at D2v, but bass does gets boomy when I do that, and I forego all the benefit of ARC.
And about the sound form the dealer equipment; as you would know it is a very different system in an acoustically treated room, so it did sound good, but very hard to compare and hard to say why, and what I mean by that is that it may be because of other things not because of the higher grade cables, or is it because of higher grade cables. That is the question I guess.
Thanks for your help.
thestewman
Glad you came back here before you "Bit the Bullet " for those $$$ cables and McIntosh gear.
I heard it at RMAF last month and was not impressed
You do have good equipment that should give you excellent audio.
Did the dealers system sound $$$ than yours ?
Exactly what is it that bothers you about the sound of your system ? Describe what kind of sound are you chasing ?
paradigm25
I need some advice, and I am sure it has been discussed here before.
I have my gripes about sound quality of my system, and everyone says that I have good components, and they are: Anthem: D2v and P5, Paradigm: S8's, S2's, C3 and Sub25, Oppo 95, and a Sony ES5400.
Anyway, I was at a AV system dealer in town to see if changing my D2v with a McIntosh MX151 may solve my situation. This dealer has McIntosh, and Meridian level of equipment.
After I told him what was going-on and what my problem was, he said that my weak link here was my cheap cables, and he strongly suggested replacing all my cables including power cables with Audio Quest cables. I am a big skeptic when it comes to expensive looking cables, and I do not believe that very expensive cables can necessarily improve sound quality.
I have gone through three cheaper cables myself; I started with monoprice, then someone said Mogami, and right now I am using all Blue Jeans interconnects, and power cords are what came with the equipment. I use 8 gage bi-wire for speakers and XLR, RCA's, and HDMI's for interconnects.
http://www.avsforum.com/t/678260/anthem-d2-d2v-avm50-avm50v-arc1-tweaking-guide/39300#
I am sure there are lot of people here who have gone through this, so before I shell-out couple of thousand of dollars, I just want to ask the experts here; what their recommendation is, and what their experience is with the effect of cables is in a system like mine.
paradigm25
"thestewman", "boyce89967", "bob", "dmusoke", and others:
Here are my latest ARC results. I think my problem is in low frequency area, if you see my charts, the sub really drops off at about 50Hz. Moving the sub and/or room treatment are not the options.
"dmusoke": I think I have found one SVS AS-EQ1, but have not finalized with the seller, I might get it. Would that really help?
I appreciate all the input and advice. I am just too frustrated. With all this equipment such lousy sound. I need help.
