AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide - Page 1408
post #42211 of 42673
Originally Posted by AVfile View Post
It's in Source Setup. You'll need to set it to THROUGH to bypass the video processor or watch 3D.
What I was thinking was, if it was set since the "3D upgrade" then you have significantly changed the HDMI chain and may wish to try a different setting.
The THROUGH setting is not in Source Setup when I look. Also, I tried DTS-HD and TrueHD test tracks that I know for a fact were working perfectly before the 3D board upgrade. This is getting a bit frustrating. The only thing that has changed in the whole system is the 3D board upgrade and the firmware upgrade.
DTS 5.1, Dolby Pro Logic 5.1 tracks work just fine and register correctly. My computer is configured for 7.1 speaker config as it needs to be. The display on the D2v reads 7.1 PCM when playing the Dobly TrueHD track, but no sound output at all. The D2v display only reads Digital with no 7.1 or 5.1 reading when playing the DTS-HD track.
post #42212 of 42673
I'm asking this here cause I heard that there is an Anthem Rep that comes into this thread.
But I was wondering, does the "Analog-Direct" function still put the signal through the ADC and DAC just not perform any EQ on the signal? Or does it bypass the ADC and DAC entirely?
post #42213 of 42673
When you set the D2v to Analog Direct it bypasses the DAC and there is no Room EQ option available in the source setup.
The only thing in the analog path are the op-amps for the volume control.
post #42214 of 42673
The THROUGH setting is only available on HDMI 1-4 connections. Under Source Setup scroll through Video Outputs Cnfg.
You should have choices 1-4 and THROUGH.
Note: If you use THROUGH you will not have audio on HDMI 2 out.
Note: You only need THROUGH for BluRay 3D video output. If you rip a 3D Blu Ray to SBS or Top/Bottom viewed with polarized glasses you do not need to use THROUGH.
Are the Blu Ray videos you are playing ripped files ?
Are you using MakeMKV or DVDFab to rip your files. You may not be getting the lossless audio streams.
Some BluRay discs I encountered said something like Uncompressed 7.1 PCM
or something like that. They were only 48k PCM. NOT lossless streams
They were not DTS HD Master or Dolby True HD audio.
If a ripped BD try using Media Info and check the audio files that are in the video you are using.
I asked before.
Are you using HDMI connection on the video card or on the motherboard ?
And you are using that HDMI connection for your audio ?
Edited by thestewman - 12/23/13 at 4:38pm
post #42215 of 42673
HDMI connection from GPU. Using the HDMI for audio. Configured correctly in D2v setup.
Mediainfo shows proper DTS-HD Master audio when looking at the audio track.
post #42216 of 42673
Did you do the 3D upgrade yourself? I believe there were issues earlier where the board wasn't physically installed correctly and I beleive there was a very specific order in which the firmware add to be installed. Try searching this thread.
I'm concerned that you don't have a through setting, sounds like something didn't take.
post #42217 of 42673
Did you check in Setup under Video Output Cnfg for THROUGH ? I believe it is Line "B"
post #42218 of 42673
Wondering if people could take a look at my graphs and pick the problem areas .
I am a bit limited by placement and room layout but looking for any improvements I can make
where feasable ?
post #42219 of 42673
My suggestions which are from an unprofessional viewpoint.
There are some strong 100 to 200 khz peaks and dips in both the right and left fronts. I would try to reposition the front speakers and use Quick Measure to see if the changes help.
The critical area are the left front at 125 khz and the center at 80 and 150 khz.
You might try to see if you can move them forward or back slightly or change the aiming to help alleviate the frequency dips.
ARC has helped a lot on the right front but was unable to eliminate the dips on the left front and center speakers.
Overall it should sound good. Your sub looks very good
post #42220 of 42673
Mark:
I would definately move the left front speaker around to eliminate the dip between 100Hz and 200Hz. That is a room mode. If you don't have room trearments(bass traps) behind your speaker, i would do so. They are good at absorbing resonant frequencies under 500Hz.
I would move the center speaker closer to the wall for better bass loading to reduce the swings between 50Hz - 200Hz.
Lastly, your right rear speaker placement to be optimized if possible. Superb sub by the way ...
My 2 cents...
David
post #42221 of 42673
Wow, these speakers are amazing. I wasn't aware ARC sampled that high:)..
post #42222 of 42673
Thanks very much for the suggestion guys it gives me some idea now of where to start
to find tune things a bit. But limited for movement as I said but will see what the response
Is like with some repositioning . At least the sub is good a paradigm Sub1 btw smile.gif
Mark
post #42223 of 42673
Originally Posted by dmusoke View Post
Wow, these speakers are amazing. I wasn't aware ARC sampled that high:) ..
I noticed that extended response also.
I have never seen ARC respond above 5000 khz without changing ARC to a Max frequency higher than 5000khz. and never at that flat a curve
I wonder how this came about ?
Mark
The Anthem Subs are awesome. I had a SUb 1 until Anthem delivered my Sub 2.
post #42224 of 42673
The word of the day is "K" as in Kilo. Stew you need to drop some zeroes or the "K". wink.gif
post #42225 of 42673
May be the beryllium tweeters and the fact they are level with the listening position ?
Mark
post #42226 of 42673
Yes. My typing mistake. Good catch
post #42227 of 42673
Well David caught it first but you missed his rolleyes.gif and ran with it smile.gif
post #42228 of 42673
Mark
$10K for a Sub 2 :eek:?
post #42229 of 42673
$10K for a Sub 2 eek.gif ?
Nope. I bought it when it first came out and the original price it was substantially less.
Then there was a substantial discount from my dealer
post #42230 of 42673
The 100-200hz dip might be wall interference. I forget the technical name and it has to do with the wavelength and cancellation, etc. Beyond me but a local acoustician explained it to me. Anyway, the closer you move the speaker to a wall this cancellation will happen at a higher frequency, the further away the speaker lower the frequency it will occur. For an 80hz crossover the speakers have to 3.5ft or greater from the wall to get this phenomenon below the crossover point. There are other solutions as well like moving the speakers closer and treating the wall. This is one of those things EQ can't fix. See what happens when you move your speakers.
post #42231 of 42673
I noticed that too. Even the Sub-1 has increased 2 g's in as many years.
post #42232 of 42673
Good deals with substantial savings can be had
post #42233 of 42673
Yep I paid almost half retail just recently for my sub 1
post #42234 of 42673
After getting feedback from everyone I played around with the speaker positions a little - dont have much leaway , and moved the listening position (couch)
forward a little . So while not ideal I think the results are a little easier on arc this time around.
edit to reupload images for missing graphs
Edited by Marke001 - 12/31/13 at 6:43pm
post #42235 of 42673
Two things. I do not see any improvement in the actual measured response.
Your charts are missing the displayed graph line were ARC actually made the changes.
Your graphs only have the measured response and the changes ARC would attempt to make
post #42236 of 42673
Looks good to me.
post #42237 of 42673
Open ARC ---> View ---> Show Calculated
post #42238 of 42673
Dont know why it didnt show I just recaptured and updated
post #42239 of 42673
^ You are good to go. Enjoy!
--Bob
post #42240 of 42673
Looks nice but in my view, since the LF speaker has no gain in the 100Hz region while the RF has the 4dB of room gain, i'd reduce the room gain maybe until the responses match in that region?
