Originally Posted by
Randall Morton
I've been trying to set up my D2 to work with my current system and I'm having trouble getting audio out. I've got my video side working fine through HDMI(SA8300 and XA2).
I don't have a dedicated amplifier yet and am using my main audio outs from the D2 to the Ext. inputs on my Denon AVR 5800. I've tried using SPDIF input also and I get no sound either way. I'm really not sure if it is a problem with the receiver or the D2. Any idea of a way I could troubleshoot this, or what the simplest setup would be to check for any audio at all?
The easiest way to verify your audio output connections is to use the Anthem's own internally generated test tones in the Setup / Speaker Lvl Calibration menu. Set the test tone to Manual and then scroll down line by line to get a test tone out of each speaker output. This is, of course, independent of any source device.
If the test tones work and you are still not getting source audio, then something is wrong in your source setup in the Anthem.
While playing something, press Select repeatedly on the Anthem remote. One of the status displays will be what the Anthem is seeing for audio input, and another will be what it is sending out for audio output.
If the Anthem reports no audio input, double check your Setup / Source Setup menu for that particular input. Note that if you are expecting audio to come in over HDMI you need to make two entries in the menu page for that input. You must select the appropriate HDMI input jack for the video that goes to the scaler, and also down in the Audio line you need to specify that you want to use the HDMI Dig audio.
Remember that the Anthem is like 3 devices in one, each of which can be separately controlled by the remote. The buttons at the top of the Anthem select which device the Anthem remote will control. Press the Main path button to make sure you haven't accidentally hit Zone 2 or whatever. THEN use the buttons at the bottom of the Anthem remote to select the input source device for the Main path.
Be sure you haven't muted your audio output by plugging in headphones or by setting the power on volume too low to hear.
Be sure you haven't selected an "overlayed" Anthem input (i.e., DVD2 vs. DVD1) by pressing the Anthem's input selection buttons more than once. You can avoid any such problem by going into Setup / Source Setup and setting "disable" for any overlayed input you are not actually using.
Be sure you haven't accidentally turned on Simulcast (video from one input with audio from another input) by accidentally pressing and holding the source select button too long. Temporarily switch to another source and back to clear this.
--Bob
