Originally Posted by
Hyenna
Anyone else having problems with 480i output from the Toshiba A2 HD-DVD player?
Since I installed 1.11g (and now 1.11e) all my colors are screwep up when I select 480i output from the Tosh, works fine with 480p, 720p and 1080i though.
Tried every color settings and that did nothing. Colors are fine if I connect directly to my TV.
Wish I had stayed with 1.06 now - it was working back then.
Can you describe the color screwup more precisely? Are you using HDMI or Component?
Double check the settings in the Video Source Adjust menu to be sure nothing odd got introduced there in the course of the software changes.
Insure that Video Source Adjust / Output / Frame Lock = OFF.
If using HDMI, insure that Setup / Source Select / HDMI Repeater = NO.
If using HDMI, insure that Setup / Video Output / Preferred = HDMI.
Double check that any overlayed inputs (DVD1 vs. DVD2, etc.) that you are not using are "disabled" so that you can't select one of them by accident. Do this in Setup / Source Select for each input in turn.
EDITED TO ADD: If the above doesn't lead to a fix for your problem, switch your A2 to 480i (so that you have the problem) and see if you can bring up the Video Source Adjust menu. If you can, go to the Info panel and report what it is showing for both the input and output values.
Back out of the Video Source Adjust Menu and, presuming you are still seeing the problem, press the Select button on the remote repeatedly and report what it is showing for each set of status (except we won't need your unit serial number). This status info can also be read on the Anthem's front panel display if your TV imaging is so screwed up that you can't read it there.
--Bob
