AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide - Page 210
post #6271 of 40875
Originally Posted by Rob Tomlin View Post
This question was bound to come up, as I was anticipating asking it myself. I had been using a MX-700 (which is going to be sold with my Parasound Pre/Pro) and I know that it will not support "held" commands such as those used for "Setup" and "Video" adjustment (7) either. It's too bad that Anthem couldn't just have used separate discrete buttons for these menus.
I loved my MX-700, and would be perfectly happy getting a new one, but I am more than willing to consider other recommendations (Pronto isn't for me...I must have "hard" buttons).
Rob - OT, but I have an MX500 and have learned the held button 'Setup' from my AVM30 remote.
A single press on the MX500 button brings up the 'Subwoofer +/-' adjustment menu, a press and hold of the same button brings up 'Setup' menu - just like the Anthem remote.
Are you sure the MX700 can't do this?
post #6272 of 40875
I have a HT Master remote which works for those keys. It learns them directly similar to the way the AVM50's remote will.
I'm not sure if the buttons are hard or soft.
post #6273 of 40875
Interesting.
When I programmed my MX-700, I added control for my light dimmers. The remote that came with the dimmers would need the button to be "held" if you wanted to bring the lights down to a certain level. Otherwise, one "push" of the button would turn them all the way on or all the way off.
I could never get the MX-700 to work by "holding" the button, despite several attempts to make it "learn" this.
It was on this basis that I assumed it wouldn't work with the D2's remote for "hold" buttons either, but it would sure be nice if I am wrong.
I still have the MX-700, so I may take it out of the box before I sell it to see if it will work..
post #6274 of 40875
FWIW with the MX500 I have been able to program other held buttons from other remotes as well. Such as Cable Box channel up/down and Volume up/down. Press and release does one channel at a time. Press and hold and the thing takes off like a rocket. Give it another try with the 700 before you get rid of it.
Once the MX700 is in Learn Mode, press and hold the Setup button on the Anthem remote and keep it pressed even thought the MX700 says OK or Learned or whatever it says when it reads the command OK. It 'should' read the extended command for 'Setup' and just fall back to the normal single button push as well.
post #6275 of 40875
Great, thanks Paul. I will give this a try later tonight.
post #6276 of 40875
^^^ Rob et al.. I actually got it to work with the hard buttons on the new remote, a Nevo SL.. They actually didn't have a button for Setup in their D2 template, but it shows up in their IR database...
The hard button works for the Video Setup using the IR for "7"... thanks for all of the repsonses.
post #6277 of 40875
Just read a pre-pro thread by Zissou who describes the 2 ch sound of Anthem's AVM/Statement preamps as horendous. Glad I'm not easily influenced by one person's opinion like all his followers seem to be in his thread. Very happy with my AVM50!
post #6278 of 40875
Originally Posted by FilmMixer View Post
Bob... you probably have no way to get me the hex code for that?
Correct. Harmony keeps all that stuff in the user's database entry on their site. I don't get access to that.
It's not so much a discrete code as instructions to their remote as to how to handle the situation where the user holds that button down.
--Bob
post #6279 of 40875
Originally Posted by Bob Pariseau View Post
Both the V1.11e and the V1.11g test software versions contained fixes that improved Component video robustness per posters in this thread. If you pass on your current status to Anthem they will likely ask you to try one of these. V1.11e is the version currently reported to have the least overall problems, but since you are having a Component video problem they may ask you to try V1.11g or even a newer version.
--Bob
Thanks, Bob!
I'll update the software, I was just hoping they would get a non-beta update released before I needed to update mine. I would hate to have more issues than I currently do, because of a beta software download. The blue screens don't happen EVERY time I sit down to watch a movie, and when they do, they are brief, but considering I just dropped nearly 5K on a processor, it would be nice if it were glitch free.
Anyway, this forum is awesome, and you guys are great! LOTS of knowledge here. Thanks again!
Sean
post #6280 of 40875
I had been using a Meridian 508.24 CD player via balanced outs through a Placette balanced passive linestage. I replaced this with a first-gen Sony DVD player used as a CD transport feeding the AVM50 via coaxial digital input. At least with the time I've had auditioning to this point, I can't say the SQ has suffered at all.
post #6281 of 40875
Does anyone have Nick's email address, thanks
post #6282 of 40875
Interesting.
Like said earlier, the MX-700 works just fine with the D2. I've yet to run into any problems. What D2 remote function don't you think will work?
larry
post #6283 of 40875
Has there been confirmation the AVM50 and D2 will be able to upgrade to the new Gennum 9351 chip?
post #6284 of 40875
The Manufacturer of the chip - Gennum - says it is a pin for pin
replacement for the 9350 because the 9350 is no longer made.
post #6285 of 40875
They told me no.
They also asked me where in the heck I found out about the 9351.
They also said it's 60 day wait.
post #6286 of 40875
The D2 has more DSP which may be used for future features (room eq, etc.) and also upconverts everything internally to 24/192k for processing. As it stands, I don't think the AVM's or D2 will ever internally decode DTS HD... but that's a moot point, as all that is required is decoding inside the player.
TureHD is already in the picture if you have an HDMI equiped processor... it is decoded to PCM in the player and passed along to the proc.. all of the new codecs must be converted to PCM prior to processing (bass management, time delay, etc.) and in regards to the new optical formats, I see no benefit to doing it in the processor over doing it in the player.
Also, as far as HD DVD goes, 99% of the titles out there now will not pass the lossy or lossless HD codecs over HDMI as bitstreams because they are authored in the advanced format.
And as far as Logic 7 is concerned, the Anthems have their own version of that in addition to Dolby PLIIx.
As a side note, while the Anthems (current models) will never accept 7.1 inputs on the HDMI ports, I am firmly in the camp that believes that discrete 7.1 trakcs will be indecernable from 5.1 extractions using DPLIIx.... why? If I want to pan something to the back center of the room, and I am using stereo surrounds, I will get the signal in both the LS and RS channel.. If I use a DPLIIx decoder, and have a 6.1 or 7.1 setup, it will end up on the CS area... since the decoder doesn't have to worry about a surround channel like straight DPL does (i.e. decoding and LCRS from LtRt), it doesn't suffer from as many steering artifacts, and should be hard to discern from discret LS LSB RSB RS sources...
Although I am working on some 7.1 tracks myself, this once again, in my opinion, is a lot of marketing that ends up making consumers nervous.... in the same way that HDMI 1.3 does.
Don't believe the hype
Great post!
post #6287 of 40875
Interesting.
I have an MX-700 and a D1 as well as a Lutron dimmer. I had no problems programming for either the D1 or the dimmer. I can e-mail you my MX-700 file if you would like. Please contact me via a PM on this fourm and I will see about sending them to you when I get home later this evening.
In addition, go to www.remotecentral.com and you can find both Anthem and different dimmer setups that peolple have already programmed for the MX-700.
Mike
post #6288 of 40875
Go to the first post in this thread... it is on the second line of that post.
post #6289 of 40875
larry
Based on my post above, I didn't think any of the functions that required you to "hold" a button would work, since I could never get that to work for my light dimmers.
I was wrong though, because I tried it last night, and sure enough, I got it to work!
My MX-700 is going to be sold with my Parasound C2 though, so I am considering my options for a new universal remote, and am open to suggestions. As much as I loved the MX-700, it is no longer made so I may go with a MX-850, 900, or 950.
Mike
Thanks Mike, I appreciate that! If I get another MX-700 I will definitely take you up on your offer.
post #6290 of 40875
OK, going to go with a D2. I'm mainly HT, but do enjoy throwing on a CD now and then as well. My system is 10 years old and am upgrading my whole system so now am wondering what you use for CD player or just CD transport (if the DAC's in the D2 beat all else).
AM updating to a new HD or BD dvd player as well. Will the HD XA2 serve OK as a CD player/transport?
Thanks in advance...Mark
post #6291 of 40875
Rob,
Search on ebay I found one there after I sold my halo stuff. This is a great remote.
post #6292 of 40875
Mark- Congrats, you are going to LOVE it!
Bill- last time I looked on eBay, I didn't see any MX-700's for sale. I will keep my eye open though. Another ex Halo user, huh?
Edit: actually there are 2 listed right now.
post #6293 of 40875
The halo stuff while beautiful to look at never sounded that good to me.
post #6294 of 40875
In hindsight (now having spent time with the D2), I have to agree with you. On it's own, though, I thought it was great. I had no idea.........
post #6295 of 40875
Rob,
If you can hold out a bit longer, URC will be selling a couple new remotes. One will be an MX-810 which is RF capable, software programable, and should list for $400.00. This remote is unlike anything they have done before, and will feature a color LCD, very nice. It looks like it may fit between the current MX-850 and MX-900.
The other which I am aware of is a URC R70. Cosmetically, it is identical to the MX-810. The URC R70 remote will not offer the software you currently use (MX-810 will), as it is "wizard" based, similar to Harmony programming, and will not offer RF capabilities. The URC R70 should list for $300.00.
Both of these remotes are late out of the gate, and should have been released already. Although, dealers are speculating roughly two more months for the MX-810, the URC R70 will follow shortly thereafter. Rumor has it, new URC software will be availabe with the pending releases.
Lastly, a good guy to buy from is Mike (also a member here), from surfremotecontrol.com If you call him, he is the guy answering the phone, is an authorized dealer, and was within a few dollars of Ebay prices when I purchased from him.
Here is a link to a photo of the URC R70, which again, looks identical to the MX-810. http://www.remotecentral.com/wn000076.htm
Hope this helps
Mark
post #6296 of 40875
Yatchatks - thanks for the info. Will the MX-810 work with existing RF receivers ( such as the 250? I have two MX-850s now ).
Then again I might sell one MX-850 with the receiver, and buy a new 810 w receiver if the receiver also works with the 850.
post #6297 of 40875
Originally Posted by soapman72 View Post
Thanks, Bob!
Sean
Beware - I upgraded to 1.11g and the blue screens continue. They are replacing mine, believing it to be a hardware problem.
post #6298 of 40875
That's too bad hantman..
Good news for me on my front though. I got 1.11e from Nick last week.
Got a chance to update the unit. That went well, apps to do it where all nice.
I followed the great tips here. Though I didn't need to, I reset it to factory just to keep everything really smooth. However, the one thing I didn't realize till after was that the scaler settings are not saved by the setup utility - you have to use Live Video Editor to download scaler settings and save. So I lost those. Thankfully I just used the Live editor to re-input everything as I'd written things down.
After the updating, component 1080i worked (xbox360) and my HTPC recognized the D2 as it seems to now issue proper EDID information, and I got it working over HDMI in 1080p/60 nicely.
My PS3 still works nicely (haven't watched any full movies yet though) and the 8300HD still works fine with HDMI too. ( I don't channel flip - just watch recorded HD 720p or 1080i so don't mind any resync )
Everything is working swimmingly with my D - wooohoo!
If only I'd get my RS1 back so I could watch some CIH HD stuff now that I have the D2 all setup!
Ciao.
post #6299 of 40875
Can someone elaborate, provide links to this issue? About to set up the 8300HD under a AVM 50. Thanks
post #6300 of 40875
Originally Posted by yatchaks View Post
Rob,
Hope this helps
Mark
Thanks Mark, very helpful indeed. The MX-810 does sound interesting. Whether I will be able to hold out for another 2 months is another question though!
