I'm trying to narrow down a BluRay player purchase and am finding it confusing since I'm also looking at buying a D1 or D2 and there may be some overlap or features in the BluRay players that are irrelevant if the D2 does them better.
Hence my questions below for you experts! Thanks in advance!
(1) Does the D2 scaler do anything other than 60Hz output? Can it do the CRT projector friendly 48Hz or 72Hz? (eliminating 3:2 pulldown judder). I would likely run my projector at 1080i/72Hz. If yes, how accurate can you get? I say 72Hz but it's actually 71.928Hz.
(2) Similar to (1), how adjustable is the resolution output of the D2 scaler? Can you do oddball resolutions? Interlaced? I'd likely do 1920x1080i (note the 'i' - this is not 'p').
(3) The D1 doesn't have any HDMI inputs. Odd, since HDMI isn't about video only. Assuming I don't care about the video side of the D2, I'm supposing that if I want to get into higher quality audio from BluRay (ie: lossless) in the near future, I will need to get the D2 so that I can feed the prepro a multi-channel LPCM signal over HDMI if i want to do more than 5.1 channels since both the D1/D2 have 5.1 analog inputs but not 6.1 or 7.1 analog inputs. The D1 just seems very limiting for the future, even when ignoring the video side, no?
(4) Some source devices (such as the Sony BDP-S300 BluRay player) have crap scalers built in for upscaling standard DVDs. (The Samsung 1200/Panasonic 10A are better but have other limitations). Is this a moot point if you use the scaler in the D2? In other words, is there a way to output standard DVD's at 480i from the Sony BDP-S300 directly to the D2 and have it upscale to whatever my resolution my projector 'enjoys'?
(5) Re: 24 fps output. Some new BluRay players now output 24 fps to avoid any sort of judder artifacts. I think I read that the D2 can take that input signal and covert it to 60Hz for the projector? (Would be nice if it could simply double it to 48Hz or triple to 72Hz as per question (1).
That's enough for now! Thanks everyone.
For the curious, the D1 or D2 will be likely mated with a new P5 amp, all driving my existing Paradigm Signature S8/C5/ADP/Servo15 speakers. (I'm replacing an Acurus ACT-3 prepro and two multichannel Acurus amps).
Kal
Kal
