How do you connect IR to D2?
I use Xantech 789-44 connection block for IR distribution (http://xantech.com/products/p_folder/p_78944.htm). It outputs to a regular 2-conductor IR emitter. I tried cutting off the emitter, stripping the two wires, and inserted them into D2's IR connection block position 1 and ground.
This didn't work, however. It shorted the two conductors when I inserted the connection block back into the D2.
How do you guys do it? Of course I can stick an IR emitter on the front, but that's ugly. I'd like to use IR receiver in the back.
Thx,
Max
Thx,
Max
I'm still w/in my return period, and this firmware failure prevents me from further evaluation of the D2.
