AVS › AVS Forum › Audio › Speakers › Monitor Audio Owners Thread
Monitor Audio Owners Thread - Page 54
post #1591 of 9216
Originally Posted by skywing269 View Post
I have an RSW-12 and could not be happier with the bass it produces
I'm not trying to dog on the quality of MA subs, just stating some objective findings. Like I said, I am huge fan of MA speakers, their subs just don't seem to have much bottom end. Have you compared your RS to any other subs in your room?
post #1592 of 9216
Just finished setting up the new RS8's (and friends) last night.
Now... I have a simple Denon 3808 receiver, did you guys use the bi-wire method or just hook up to the low posts?
The MA manual recommends it, should I take that as gospel?
J
post #1593 of 9216
J
Personally I just wired the lower posts. Maybe if I had a dedicated amp I would bi-wire and even then I do not know if I would hear a difference.
post #1594 of 9216
For the money I think you can get alot more bang for the buck compared to MA offerings. Maybe something like a Hsu VTF-3 MkIII for $700?
What's up skywing?
post #1595 of 9216
From what I have read it seems that bi-amping might make sense, bi-wiring..eh.
It's just that I was prepared to follow instructions in my shiny new manual. Curious what everyone was doing.
J
post #1596 of 9216
J
Please post impressions of the 8s. I hope you enjoy them.
post #1597 of 9216
this weekend i plan to compare the rslcr directly to the silver 10i. since they dont have the 12i
can someone tell me is there a big diffarance between the 12i and 10i? i know the 10i and 12i match my silver 8i better, but i am looking for a better speaker, id rather have a better speaker thats a little off with my fronts than have an okay speaker thats a match?
also the 12i is from ebay bid right now is 250
and i can get the rslcr for about 450
post #1598 of 9216
bball,
Trust the advice you've been given about the importance of matching up front. The 10i and 12i are not "okay", they're both quite good center channels. Yes, the RSLCR is also very good when matched with the appropriate fronts. But that's not your situation. Now if you had some really crappy mains and it was either get a crappy center to match them, or pay the same for a great center channel, by all means get the great speaker.
If you want the best performance as a whole, match - match - match!
post #1599 of 9216
I can't remember which bi-wire speaker cables I tried out on a pair of my GS60's, but they did retail for over a grand. I got them for much less however. I was using my Parasound A21/Pre3/Primare CD31 at the time. I could not tell the slightest difference in the world, none, zip, nada. My nephew couldn't, and friends from a local HiFi store could not. I gave them away to be sold on Audiogon.
Now, I understand that others may feel different, but for those that claim some gigantic difference in what they hear with bi-wiring, i'll just be happy for them and wish my ears were that good.
post #1600 of 9216
While Im a huge GS fan, I am more skeptical of MA's subs. According to the measurements posted in the HT mag review, the GS sub only reaches down to around 50Hz in room. While I'm sure that it will sound clean and tight, that isn't very good bass extension.
I looked over that review, and seemed interesting that they only got 61hz -3db out of that thing. I will have to bring this up to Monitor Audio, and find out if it was a defective unit or something. They claim response down to 18 hz, so something seems strange.
post #1601 of 9216
It may be defective, but this sort of limited bass extension is not unique among the measurements I have seen posted on other MA subs.
post #1602 of 9216
has anyone heard the 10i or 12i?
any opinions on them?
can anyone compare them to the rslcr?
post #1603 of 9216
bballgms - come on man, you're killing us here. You keep asking the same question over and over again, just different ways. You have nice speakers, BUY THE MATCHING CENTER SPEAKER (it will be just as nice), and be done with it. The 12i on ebay right now is brand new, it matches the finish of your speakers, it is within your budget, and it comes with buyer's protection if you use Paypal, so the risk is low and it is the perfect tonal match for your current speakers.
If you aren't going to buy the matching center, then GO LISTEN TO THE RSLCR. Nobody here can tell you if you are going to be happy with the sound of that speaker. YOU HAVE TO LISTEN TO IT.
post #1604 of 9216
I am in a real fix now. Torn between Monitor Audio RS6 vs Dynaudio 72 vs Jamo C807.....regardless of price.
Has any of you RS6 owners ever AB compared these 3 speakers before? What's your opinion ?
post #1605 of 9216
buyers protection?
post #1606 of 9216
HI,
I am thinking about buying the RS8, which of the following receivers do you recommend:
Onkyo TX-SR875
Pioneer VSX-94TXH
Denon AVR-3808
It is going to be mainly for Home theater.
post #1607 of 9216
I would personally avoid Jamo. A Klipsch-owned company that has had very strange distribution here in the US. Similar problems faced by Mission, Wharfdale, Kef, etc. You would likely have a hard time getting after sales support.
The Monitor Audio RS6s and Dynaudio Audience 72s sound very different. You have to listen to both products and you should be able to make a decision pretty quick from that.
post #1608 of 9216
buyers protection?
yes, if you don't get what you paid for, or the speaker is defective then you get your money back.
post #1609 of 9216
hifi,
You are a prince of patience.
post #1610 of 9216
Originally Posted by kcrowder View Post
hifi,
You would think, but I have a fist full of hair right now that says otherwise.
post #1611 of 9216
**** off ebay it doesnt come with warranty?
another reason y i shouldnt get it?
post #1612 of 9216
at least you have hair to pull out
post #1613 of 9216
I suppose I do have that to be thankful for, but not for much longer I think. I'm not getting any younger.
post #1614 of 9216
+1
post #1615 of 9216
do bannana plugs help sound?
post #1616 of 9216
Is this a good set-up for my MAs? Are these speakers enough. The room is 15 x20! Thanks for the advice. I got all the speakers for under $2000!
1 x MA R180 Center
4 x MA R270s Front and Back Left and Right
1 x MA R360 Sub
Onkyo 605
Onky0 404 Upconverting DVD Player
Panasonic 50 inch Plasma
Comcast DVR
Apple TV
Logitech 1000 Remote
post #1617 of 9216
1 x MA R180 Center
1 x MA R360 Sub
Onkyo 605
Comcast DVR
Apple TV
I have the R90's F/R/Surrounds, the R180 center and the R720 sub. I love them. They are clearly the best sounding small speakers I have heard. Good thing you stepped up to the 270's for most of your speakers, as your room would be a little to big for the 90's or even the 180's.
I do have two suggestions for your set-up though. See about replacing the 180 center with another 270. The center speaker is responsible for over 70% of the sound in a movie and they tend to be pushed the hardest in a soundtrack. Having that smaller 180 as your center could be a weak link. But the proof is in the listening and if you don't crank your system, the 180 may be fine.
My only other concern is the 360 sub. It really isn't a true sub as much as a mid-bass speaker. You would be better off with the 720 or the RSW12 from the Silver series. Both of these will have more low end power than that little 360.
But again, judge for yourself. You may find the system meets all of your expectations as is. Just sharing my experience with these speakers.
Happy listening!
post #1618 of 9216
Yes, installing them is like getting a new set of speakers! But only if they are Rhodium plated, cryogenically treated, long-grain copper, splashed with holy water to get all of the bad sound out of them.
Seriously, the only things bananas do is taste good.
OK, really they are only meant to make connecting and disconnecting your speaker wire more convenient.
What else you got? Bring it!
post #1619 of 9216
so there is no differance in sound quality compared to bare wire?
post #1620 of 9216
I just realized I miss ValhallaPC.
  Back to Forum: Speakers
