AVS › AVS Forum › Audio › Speakers › Monitor Audio Owners Thread
Monitor Audio Owners Thread - Page 55
post #1621 of 9217
Originally Posted by Mike N Ike View Post
I just realized I miss ValhallaPC.
I showed that video to my wife and it totally freaked her out. Maybe she saw my future?
post #1622 of 9217
Valhalla had sausages, you've got bananas - I can see why you're concerned!
post #1623 of 9217
Maybe my bananas would sound better if I wrapped paper around them? Hmm . . .
post #1624 of 9217
Lol
post #1625 of 9217
can anyone give me alink that will show how to change the drivers of the speakers.
in a couple of hours my new drivers should be arriving and i want to know exactly how to change it
please supply a link on how to change drivers
post #1626 of 9217
hi i recived the drivers,but the box says silver rsfx but on the order list it says driver for silver 8i and 3i and 10i. also on the box it says it contains 1 silver rsfx fitted with frille 1 wall fixing kit, 1 insturction manual and 1 warranty card , but it only was the drivers . are the drivers for the rsfx or my monitor audio 8i and they just put it in this box?
post #1627 of 9217
i changed the drivers they still dont work,
ummmmm i was wondering can i connect my speaker wire that is coming from my reciever into the driver?
post #1628 of 9217
Originally Posted by fbenarouche View Post
HI,
I am thinking about buying the RS8, which of the following receivers do you recommend:
Onkyo TX-SR875
Pioneer VSX-94TXH
Denon AVR-3808
It is going to be mainly for Home theater.
My RS8's have been playing music nonstop for the last 3 days. I LOVE THESE SPEAKERS. My reciever is the Denon 3806 and has plenty of power for my 12x18 room. However, I am easy to impress since I had the Energy Take 5 speakers all the way around my room for the last 7 years. The Monitor Audio overhaul was the last piece of my home theater puzzle.
Front stage, RS8's with the RSLCR, side surround uses the silver cp in walls, back surround uses the silver cp in-ceiling models.
I'm still playing around with placement of acoustic panels, but these are such a quantum leap from the old speakers all I can do is smile.
Next week, I add a 15" velodyne sub to the mix.
J
post #1629 of 9217
Congrats bennutt! Coming from the Take 5's, that's got to be a big upgrade in sound.
post #1630 of 9217
Now I have to start watching all of my movies over again!
Just played the matrix lobby scene on HD-DVD. It's like I was missing all of the great sounds in between the sub bass and whatever those energy's were kicking out.
post #1631 of 9217
I actually think the the Take 5's are a great little speaker system, but as they say, there is no replacement for displacement. In other words, while the Take 5's may be good for their size, they won't touch what a full range speaker like the RS8's can do.
Now go throw in the pod race scene from Star Wars episode 1, and the opening scene from Saving Private Ryan!
post #1632 of 9217
Yes (don't crank the volume). That'll at least tell you if the driver is working or not. Although, it sounds like you need professional help as I doubt there's a problem with the new driver. Triple check your wiring and make sure that your speakers have the jumpers installed (things that connects the two pairs of posts on the speaker). Also, try connecting the speaker wires to the other set of posts to see if your tweeter now "goes out". Are you able to post pictures?
post #1633 of 9217
Crossover could be out as well, I've had to change out a couple for people.
I agree about the poor performance of MA subs. I have heard the RSW12 and I didn't like it at all. No low bass extension, all tight midbass. Next.. They really need to go back to the drawing board on that sub. I also owned one of the older FB-212's, gave it plenty of chances but I ultimately ended up hating it. A $2k sub should not bottom out and distort as easily as this one would. I used to just sit there and stare at it with anger as it would let me down again and again. I wholesaled it the first chance I got for a Sunfire True Sub Eq, ahh theres my low end with no crunching and clanking.
Although I will say the Radius 720 has been a pleasant surprise, and I would say it is MA's best sub. Problem is it is expensive and easily beaten by cheaper subwoofers. If they stopped carrying subs I wouldn't be all that upset.
post #1634 of 9217
anyone know know how much the price for two new monitor audio 8i drivers cost?
post #1635 of 9217
also wats a good price for a used rslcr?
i might get the rslcr this weekend.
post #1636 of 9217
Finally got my all black GS60s and GSLCR hooked up... waiting for a parasound 5250 and 2250 to come in so i can run wire and hooke up the surrounds... I was just wandering for HT and Music what settings you guys like to use for crossovers... my room is sealed and only in the 2000cbft to 2500 and i have a JL fathom 113 with a integra 9.8 pre amp... going to go run the setup tonight and see what audessy throws at me... thanks
post #1637 of 9217
hey i have an extra reciver lyieng around can i connect it to my speakers, can i bi-amp?
i heard that makes a huge diff. is it possible?
post #1638 of 9217
With the amount of trouble you are having grasping just about everything else, I wouldn't even attempt to explain to you what to do there.
post #1639 of 9217
i have an extra reciever please tell me how to bi-amp?
post #1640 of 9217
Do not even worry about bi-amping dude. Just go listen to your speakers and enjoy them.
post #1641 of 9217
please tell me how to ****ing bi-amp
post #1642 of 9217
I think it's official.... this dude is a troll.
I would much rather get alerts for legitimate questions and reviews rather than read "illiterate question of the day".
Throw bi-amp into a google search if you care, which you don't.
Go start a Kraco car stereo thread and ask how to adjust the volume or maybe "which side does red wire go on...please tell me how"
post #1643 of 9217
People have spent a lot of time answering your questions. Perhaps if you were more respectful, and thankful, you'd get some more help. Those are old fashioned ideas, but they go a long way, even on the internet.
post #1644 of 9217
im not a f*cking idiot im 15 years old which is in the process of learning i know more than everyone else at my school about speaker!!!!!!!
post #1645 of 9217
bballgms, you've stepped over the line. You certainly aren't going to get the help you seek with that approach. The problem here is, you ask questions that you could find the answers to by doing more research on your own, and most of them have nothing to do with MA speakers. You can't expect everyone else to do the work for you. If you really want to learn more about this hobby, put a little more effort into it. Use the search function of this forum to find others that have asked the same questions before you and go to web sites like www.ecoustics.com, www.stereophile.com, www.ultimateav.com, and www.hometheatermag.com and read the articles on how to get good sound. If, after reading those articles, you don't understand something, you can seek help in this forum but place your post in the appropriate area, and write in complete, coherent sentences, not text-messaging speak.
post #1646 of 9217
i understand that but he should f*cking diss me like that. saying red and black wire
post #1647 of 9217
DUDE.....CHILL.
post #1648 of 9217
not anything to hifi hes a good guy.
post #1649 of 9217
i hate bennut hes the guy thats pissing me off.
i cant drive and my parents arent really into this hobby as much as i am. so its really hard for me to get the right speaker for the right price.
post #1650 of 9217
Yeah, that wasn't cool, but watch the language or you are likely to get booted off of this forum.
  Back to Forum: Speakers
