Originally Posted by carlosarg
Hi,
I have a Denon AVR-4806 CI receiver and I would like to drive with it five Monitor Audio GS60 (f/l, center, f/r, s/l and s/r) + a subwoofer. Denon specifies that it needs speakers with an impedance of 6 to 16 ohms and the GS60 has 6 ohms nominal impedance.
Is this going to be a problem due to excessive heat in the receiver or would it be within safe limits?
My listening room is not big, then I would not need high levels of volume and I could provide proper ventilation.
Any help? Ideas? I am a bit lost about the impedance issue....
Hi,
You should be fine with the Denon. IIRC the GS60 is fairly efficient at 90dB which helps fill rooms.
I would just give the AVR some breathing room as 5 towers will definitely exercise it a bit.
