AVS › AVS Forum › Audio › Speakers › Monitor Audio Owners Thread
Monitor Audio Owners Thread - Page 232
post #6931 of 9216
Originally Posted by holt7153 View Post
Greetings-new RS6 owner here (should arrive tomorrow). I plan to use these for 2-channel music ONLY in a small room connected to a Pio 1019. Do you recommend adding a sub or will the bass from the RS6s be adequate? Thanks in advance.
My room is only 11 x 15 and open on one side . For me, i go subless for two channel music ,and i think they are very good that way.
post #6932 of 9216
interesting, thanks. I had some cash set aside for a sub so this will free me up to spend it on other electronics-related stuff I don't need!
post #6933 of 9216
Sorry, i did forget to mention that i am bi-amping them with Emotiva
LPA-1 Amp and they are only about 12 inches or so away from the wall behind them , which re-inforces the bass , i do believe.
post #6934 of 9216
OK, thanks. Bi-amping is generally preferred over bi-wiring, correct?
post #6935 of 9216
If someone is interested with comparing BR6 to BX6 - its exactly same, little warm sound with better high tones clarity in BX. No other differences in sound, just quality of workmanship is better (no screws on front, magnetic grille, added plate for spikes).
post #6936 of 9216
yes , for sure !
post #6937 of 9216
I have a pair of the bronze in walls (CPW BR) that I picked up on e-bay. I intend to get a third for matched LCRs (and an AT screen). However, I just noticed a gold in wall (CPW is available for a reasonable price (same price as a single bronze cpw). Is it worth considering getting the CPW GS as a center, or should I stick with a matched set?
The brochure says they aren't timbred match, but I am not sure if a superior speaker for the center is worth the trade off. Any thoughts? Would be only used for HT/Movies.
post #6938 of 9216
My gut response is to go for consistency and get the matching center. But it really depends on the quality of the Bronze center. As long as the Bronze center isn't a total stinker (I've not heard it, so I can't say one way or another), having the sound be consistent across the front will create a more cohesive soundstage.
post #6939 of 9216
Hi Everyone,
So nice to see an active MA thread here and read about everyone's experiences with these products. I'm going to jump right in here and ask for some advice:
My current set up consits of GS10's as fronts, RSCLR for center and RS1 for rears. Recently ditched a Velodyne SPL-1200 II which was used for HT. Receiver is a Pioneer Elite SC-05 with front pre-out to a Prima Luna Prologue Two amp. Source is the usual PVR, HTPC and Oppo BDP-83 (analog out to external amp for CDs). This is all in a condo with decent insulation between floors and suites, but I sold the sub because it was put to very little use. The room is an open 17x23 but the listen area is in a corner which is about 9x13 with traditional rectangular HT arrangement.
Here's where I'm looking for input:
1. Sell the GS10 for RX6 to gain some bass?
2. Keep the GS10 and add a smaller/better subwoofer?
Music goes to 60% hiphop/r&b/pop, 30% jazz, 10% classical. Overall it's about 70% music and 30% TV/movies.
I went from B&W 602S3 to the MA GS10 and never looked back. The addition of the tube amp helped mellow the brightness (or maybe I just like distortion). Anyway, just wondering if anyone else has gone through a similar change, or has auditioned the GS10 next to RX6 for comparison, or just wants to share an opinion. Cheers!
post #6940 of 9216
I found a very good deal on a set of slightly used RS6's and the matching RS LCR from Saturday Audio, so I finally made the plunge to a "true" speaker system!! Yes, I'm pumped.
So, now I need you guys to help me choose the appropriate AVR. I've seen where many prefer Denon or Marantz with Audyssey for calibration reasons. Is this true and, if so, which one do you suggest? Is the Denon 1911 or 2311 recommended? I've also heard good things about the new Pioneer 1120.
Also, I will be upgrading my surrounds and sub in the near future as well. My use will be 75% movies/TV/PS3 games and 25% music.
post #6941 of 9216
Originally Posted by Snyper886 View Post
Hi Everyone,
I've owned the GS60's and listened to the RX8 at the store. Even though the RX series is newer, IMO the GS series still sounds better so I would stick with the GS10 for the sound quality and get a good sub. A sub will give you true full range performance whereas a small tower speaker will not go that much deeper than your GS10. However, using a sub to the best effect often requires the use of EQ to address room boom, and achieving proper sub / GS10 integration (setting the crossover point, the phase, and level) is also going to be difficult if done by ear. In your set-up, introducing as sub is going to be tricky I would think since you are going straight from the CD player to the amp. If you were using the Pioneer for music, the onboard EQ would take care of the room problems and the auto-calibration would take care of the sub to main integration.
The Velodyne SPL-1200 is actually a very good sub, so I have to wonder if you were already faced with room problems and not being able to set it up properly. Many 2CH guys poo-poo subs because they sound disconnected from the rest of the system and boomy, which 9/10 is due to the room and trying to calibrate by ear. What didn't you like about the Velo?
post #6942 of 9216
I would agree with with Tim on this and stick with the 10's. I have never heard the SPL-1200 but if Tim says it's good I would not doubt it.
If you already sold it(SPL-1200) you might want to take a look at this: http://www.epiksubwoofers.com/legend.html
It recently came out but if it's anything like it's older sibling(it got pretty good reviews),it should be a great sub for that price.
post #6943 of 9216
I own the Rs6 setup with rs1 in the rear . I am using a Marantz Sr5003 avr and i am very happy with it. I am bi-amping the Left and Right fronts . I am using an Emotiva LPA-1 amp for all 5 speakers. I run my outdoor speakers (at the pool) off of the AVR itself.
post #6944 of 9216
Thank you for the feedback guys. I was leaning towards another sub and keeping the GS10s. Indeed, there were some problems with set up and I gave up on that sub, even though it's well received. I couldn't get it to mesh well; it was too boomy even after running MCACC on the Pioneer. In the end I'm just looking for some more extension, but don't want to rock the place and have the neighbors at the door constantly. CDs would normally play 2ch amp-direct, but sometimes I've gone 2.1 thru the receiver.
I'll take a look at the Epik sub, but have also considered the BK XLS200. Any other recommendations?
post #6945 of 9216
I don't know what your budget is, but I went from a Velo DD15 to a JL Audio F112 and I couldn't be more impressed. You might want to look into a JL F110. The JL subs are very tight and articulate, and they also have gobs of output for their size.
post #6946 of 9216
Budget is around $1000 to $1500, but another issue is size; don't really want to go bigger than the 15" cube of the Velo, infact smaller the better. In hindsight, wonder what the use of an EQ like the Antimode 8033 would have done... The F110 is worth a look, maybe can find a used one around here. There's a F112 for sale locally but $2000 asking is steep.
I was able to take a listen to RX8 next to GS60 in the same room, and RX6 in another room, but this was a walk-in listen without familiar material. I'll have to go back next week for a proper audition.
post #6947 of 9216
Well, I just got the Pio 1120 for $500, including shipping and the warranty...couldn't pass on that deal.
I'm clueless and trying to learn when it comes to home audio, so please tell me what amps I should be looking at, if any? I didn't see the Emotiva LPA-1 anywhere for sale.
post #6948 of 9216
Here ya go, a JL F110 for $1400.
http://www.audiogon.com/cgi-bin/cls....lack-gloss-wit
I think he has a little padding in his price, so you could talk him down a bit, or offer full asking price with shipping included.
Or, I have a contact that could probably get you a new one for just about the top of your budget.
JL F110 dimensions: 15.64H in x 12.92W in. x 17.27D in.
The JL has a built-in single band EQ to take out the most severe room mode, which does the trick for many rooms.
I'm interested in hearing your impressions of the GS vs. the RX.
post #6949 of 9216
I'm running the RS6s in my office without an external amp (I'm using the Pio 1019 for this setup). I added a sub as it's really for 2.1 hi-rez music only and I think it sounds amazing. I've got en Elite SC-05 in another room for home theater, again without an external amp. Having an external amp is awesome but PERSONALLY I'd rather blow the cash on better speakers or sub.
post #6950 of 9216
I've been very impressed with my JL F110. Although have'nt had much time to optimize set-up. One thing I've noticed is it's ON all the time (at least the led is constantly ON). I notice the amp heat-sink is always warm as well, is this normal? I thought I followed set-up procedure properly. Sometimes switching a random lightswitch (on the same circuit) will enable loud transient (boom). Also, when I turn-OFF main system power on my Furman conditioner.
post #6951 of 9216
Hmm, well, the JL does have an auto-on function, but I never use it because I've found these types of functions to be inconsistent as to when they trigger on, and because they do things like cause thumps when then power up. I don't know how energy inefficient it is to leave the sub on all the time, but that's how I roll.
post #6952 of 9216
I see, you (purposely) have yours enabled ON full-time. I thought I followed the Auto-ON procedure, but not sure it's behaving that way, I'll have to go through set-up again. I found it to function okay this way (auto-ON) in the past, no hiccups or random transients
post #6953 of 9216
I've also heard that it's best to always keep them ON as opposed to AUTO as occasionally when they go into "sleep mode" it's hard "wake them up." Any truth to this?
post #6954 of 9216
I can't say with the JL because I've never tried the auto function, but yes, with the Velodyne I used to own, the auto-on would often not work when watching TV at low volumes. Not enough signal strength to wake it up.
post #6955 of 9216
I personally do not have that much experience with amps . the onlt two that i have owned are the NAD 218 THX(two Channel amp) and the Emotiva LPA-1(what i curreently use ). Though a lot of people say that you can't go wrong with almost any amp from Emotiva, as far as bang for the buck goes.
You can pick up a used amp on audiogon pretty reasonably.
This one is supposedly very good for the money
http://www.audiogon.com/cgi-bin/cls....-7-channel-amp
Here is a list of all of the Emotiva amps for sale on Audiogon
http://cgis.audiogon.com/cgi-bin/srch_fs.pl
I hear good things about the MPS-1 and i would use two channels for each left and right speaker (bi-amp them).
In my opinion the RS6 really open up when bi-amped. When I ran them with one amp channel i could hear some cabinet resonance when pushed , but not when bi-amped . I hope this helps. maybe others could chime in as well.
I know that you will get people that tell you that you do not need an amp at all, and they are correct , but i personally feel that those speakers do best with an amp and when Bi-amped.
It doesn't have to be an amp that delivers massive power especially when bi-amped. Even this amp should be good http://emotiva.com/upa7.shtm It is the Successor to the LPA-1
I hope this helps
post #6956 of 9216
Agreed, the Velo I had also suffered from this problem even with a Y-cable.
post #6957 of 9216
From the brief listen, the GS were more clear in detail and highs were more pronounced than RX. Didn't get to hear anything with more depth so can't comment about bass response. Not sure when I'll have time next week for an audition, but I'll provide some feedback when I get around to it. There's also a pair of PL200 in the same room and will try to hear them too.
As for the sub, I might be able to get a used F112 for around max budget, so will wait and see how things play out.
post #6958 of 9216
Yup, the GS are very clean and just a touch bright, but they seem to ride the fine line and don't veer off of being harsh or fatiguing.
post #6959 of 9216
On the above; I have a Velo CHT-12R and have had the auto-on working perfectly for 3 years. Sub-channel gets sound, they turn on, 15 minutes no signal, they turn off. There's a few second delay while they get the idea and kick in but that's it.
On the RS6's, I've had mine bi-amped from new so I can't really comment on whether they are better ran this way but they've taken everything I've thrown at them and never ran out of steam.
post #6960 of 9216
I've been considering an upgrade but will likely wait and see if the GX range comes out before too long.
  Back to Forum: Speakers
