AVS › AVS Forum › Audio › Speakers › Monitor Audio Owners Thread
Monitor Audio Owners Thread - Page 234
post #6991 of 9217
Originally Posted by ClemsonChad View Post
Thanks Tim, that's what I was looking for! Audiogon has a few used HSU vtf-2 mk-2's for around the same price as the MA on Amazon, so I may just choose one and be done with it.
Just wanted to interject one bit that might be helpful - be sure to fully consider the size of the HSU subs versus the MA sub. They are not exactly small, but then again, neither is their sound. I like mine, but my wife has never been a fan of how imposing it is, size wise, in our living space. Just something to consider...
post #6992 of 9217
The subject says it all. Newcomer to the site and I'm an Onkyo 808 new owner who's looking to buy front towers and a center for about $1500 or less (surrounds and sub ok for now). Do the RX6s match well with the 808 or not so much? I'll bi-amp front L/Rs. Listen to all types of music but mostly zeppelin, louis armstrong, ronnie milsap, etc. Thanks folks. Upgrading from older Infinity TSS-750 5.1 speakers with an Onkyo 600 (lightening). Speakers are for mostly music, some tv watching and a weekly dvd. Excellent music reproduction is my main objective with the new speakers though. Thanks everyone.
post #6993 of 9217
Since I have you, will you give me your opinion as to whether the Pioneer 1120 AVR will give me enough power for the RS6's and matching center in this sized room? I've been talking to holt7153 about this through PMs as well. I want to make sure this AVR will be enough for my HT use, or whether I should return it to J&R and get a larger Elite or Denon AVR. I'd like to not have to buy a separate amp at this time, but I'll go with your expertise here.
Thanks again, and I apologize for the constant questions.
No worries, always happy to help.
The lower level Pioneers have typically underperformed when powering all channels simultaneously because they have a weak power supply, but I think you bought a model that is high enough in rank that you shouldn't run into this problem.
If there are no magazine reviews with power output tests for the AVR you are considering, one of the things that is a good indicator of whether or not the AVRs output will meet the published specs is the actual weight of the AVR. Good power supplies are heavy, so the heavier the AVR the better (with the exclusion of those that use digital amps, which yours doesn't).
Thankfully, the Pioneer you've chosen weighs in at a healthy 28 pounds (as compared to the next Pioneer model down at 22 pounds and the comparable Denon at 23.8 pounds). And it has been my experience that right around 30 pounds is where you see more honest power output, so I think you'll be fine. You'll still get the most power out of an AVR of this caliber when using just two channels, but there should be enough juice for moderately loud multichannel too, especially if you use a subwoofer to handle the low end.
All current AVRs will shut down temporarily to prevent speaker and AVR damage if you push them too hard, so even if you get a bit carried away, no big deal. However, if you find that you are constantly listening at levels that put the AVR into protection mode, then hopefully you can exchange it towards a heavier model.
post #6994 of 9217
You are absolutely fine with that pairing. The Onkyo you have is a well-engineered AVR with solid power supply section. (See my last post on the subject of AVR weight). You won't need to biamp the speakers, and there is typically little gain to doing so, but feel free to give it a try if you've got the extra cable.
post #6995 of 9217
Okay, well that's good to hear. I believe I'll be okay with the 1120 then. I'll set it up and see what happens, and like you said I can always upgrade to a larger model or get an amp if needed. I've read a lot of good things about the 1120, and the Elite SC-35 would cost me about twice as much!
I'm going to add two RS1's (or maybe RX1's) as my surrounds for my 5.1 setup, and either the MA or HSU sub, so I'm looking forward to getting this baby up and running...
Thanks again for your time!
post #6996 of 9217
Good point. I just measured the HSU and, while larger than the MA, it's only slightly wider and deeper than my current Onkyo sub I use. I like the fact that the MA matches in color (rosenut) and brand with my fronts, but I should probably focus more on quality than aesthetics huh..?
post #6997 of 9217
More excellent info from Tim. My quick related story...last year I rushed out and bought the Pioneer 1019 for my main home theater receiver because CNET gave it the Editor's Choice Award for best receiver. The first thing I noticed was how light it was (19 lbs). It sounded great at lower levels but never really got that loud, and I thought I wasn't setting the MCACC properly. Then came more complaints from other owners about its lack of power and we all quickly discovered that the watts per channel Pioneer claimed was for 2 channels only. I quickly replaced it with a Pioneer Elite SC-05 (41 lbs) and couldn't be happier, but kept the 1019 for an office music system, which brings me to the reason for my post.
In building the office music system I did heavy research and discovered/purchased Monitor Audio RS6 speakers. My office is pretty small so my RS6s and myself form roughly a 7 1/2 foot triangle. I love the bass from the RS6s but when I run the MCACC off the 1019 it wants to switch the RS6s from large to small and route most of the LFE to my newly purchased sub, and I think it makes the RS6s sound kinda weak. I realize bass is subjective and you're not able to hear what I'm hearing, but if you were me would you:
*override the MCACC, switch the RS6s to large, and keep the sub?
*keep the RS6s at small and route most of the lows to the sub?
*run the RS6s solo and return the sub?
*buy a Radio Shack soundbar?
a preemptive thanks.
post #6998 of 9217
If you have a pretty good sub your 1019 is correct in setting your RS6S to small.The RS6S have great bass for a small speaker,but if your sub is set up right and in the proper postion it should do it better.Some ARVS have a double bass option that sends LFE to both the sub and the speakers.
Try moving your sub around and playing with the crossover to see if that helps any.Bottom line is that you may like the bass from just your RS6S over your sub and in a small room for just music it may be enough.Just play with it and run your system to what sounds good to your ears.
post #6999 of 9217
For music I run my RS6 (bi-amped) without a sub. speakers are only about 14 inches from the wall behind them and about 6 feet apart from each other. I run them Large and feel that I get plenty of bass from them.I run them Large for HT too. I just adjust the Sub volume manually on the sub itself ,after the distance is set by Audyssey. It wall always shows the sub to be farther than it actually is , but leave it that way as there is an inherent delay with all subs
post #7000 of 9217
OK, guys--thanks for the helpful advice!
post #7001 of 9217
I just auditioned the RX6 yesterday and am completely smitten. The only thing holding me back is the price. A question: has anyone noticed if these go on sale at local retailers or can they be had for a good price anywhere? I know the Magnolia has the BX5 on sale now, so I suppose it could be possible?
Cheers
I was also smitten with Monitor speakers when I heard the RS6 several years ago. At that time, when I was shopping around and demo, nothing really grabbed me until I put the Chesky Ultimate Demonstration Disc in for the RS6. Sat back in this leather chair and was grinning from ear to ear. Never got around to buying due to work, travel, kid in college blah blah.... So, I may be close to pulling the trigger on the RX6 in Walnut (wife loves that finish). My question for the forum members is that I have an old school Yammy RX-V995. Do I really need to spend the extra $$$ for a nice receiver like the Pio sc-35 ($999) or new Aventage rx-a1000 Yammy ($999). What is the hype with video upscaling chips (Faroudja, Marvell), Ice Amps, HDMI, Lossless Audio etc etc. I understand the HDMI, but, my Sammy Blu Ray upscales pretty nice to Sammy 3D tv. Maybe all I need is an Emotiva Amp. I read somewhere that HDMI may be obsolete???
What do you guys think about this?
post #7002 of 9217
Thems a lot of questions Tex.
You may hear a slight improvement / difference with a more current / more expensive AVR, but it is likely to be subtle. I would buy the speakers first, and evaluate what you get at home versus your experience at the dealer, then decide if you need a new AVR.
Unless you watch a lot of standard definition DVDs and SDTV that you would need upscaled, there is little value in the video processing chips. Haven't heard of Marvell, but last I read, Anchor Bay is one of the better chip providers or Realta. I may be out of touch on this one though. I'm not a video guy, unless I'm in the process of buying a video piece I don't stay up on what's hot.
Ice amps are just another pathway to the same destination of providing power to your speakers. They are small, light and energy efficient, but there is debate over the sound quality as compared to standard Class A/B amps. Unless you need a small, low heat amp, Ice Amps don't need to be on your short list of considerations.
Lossless audio promises better sound quality, but whether or not you will realize that promise depends on a number of factors, like the quality of your gear and the quality of the recording, and how you have everything set-up. To me, Lossless is a small gain in improved audio quality, and alone it may not impress you, but if you step up to this, and better speakers you may feel the combo is worth the effort. Go to the dealer and ask to listen to the lossy and lossless tracks of a movie to hear for yourself.
HDMI is always becoming obsolete with each new revision. HDMI started with version 1.0 and now it is up to version 1.4. If you want to pass 3D through the AVR you will need 1.4.
post #7003 of 9217
Hifisponge....
Thank you for the response. You Sir are a class act. Two more questons for you and I will leave you alone.... I am basically a noob at this stuff....Are you saying it is debatable whether purchasing lets say an Emotiva Amp or any other amp will provide a substantial improvement in sound quality coming from the RX6? Also, do you favor the RS6 vs RX6? I was looking for the RS6 since I can probably get a good price since it is discontinued, but, cannot find it new anywhere. Not really interested in used.
Cheers
post #7004 of 9217
Hifisponge....
Cheers
Definitely no interest in buying used? I just picked up a pair of used/near mint RS6s for a nice price and I'm very happy. There's a guy selling a pair of RS8s on Audiogon and according to him they're "absolutely mint/purchased 2 months ago." They're roughly 50% off MSPR but it's an "or best offer" and have been listed for over 2 weeks. I've purchased a few used electronics over the years and (knock on wood) have had zero problems with any of them.
post #7005 of 9217
Hifisponge....
Cheers
Its no trouble really. I enjoy skooling noobs.
You'll hear strong opinions on both sides of whether or not a high power amp will improve the sound of your system. I'm in the camp that feels that the power needed is the direct result of how loud you listen and how far way you sit from your speakers, as well as the capability of your speakers. For me, if the sound is not distorted or harsh when you are listening at the highest levels you will practically listen to, then you don't need a more powerful amp. I think Emotiva has a trial period, so you could always buy one, try it out and see what you think.
As for RS and RX, to me they are two slightly different flavors of the same ice cream. I wouldn't say one is better than the other. If you can find the RS series at a good price, go for it. I do like the new look of the RX series though, and because I like sexy gear, I'd probably get the RX because they are the new hotness.
post #7006 of 9217
Holt,
I don't know. They seem like a good deal in CO and they have been on there for quite some time, considering it seems the RS6's that are in excellent shape fly off the shelf when they are posted on Audiogon. I have been considering the non authorized dealer venue. Perhaps Digital Craze or Absolute Audio Video which have "ok" BBB ratings. Both these places are close to where I live. Yea, I know there is a risk with them such as warranty etc etc. At least I get to visually inspect them. Also need to figure out a fair price to offer an authorized boutique dealer and see if they bite.
Any suggestions on a fair price to offer for RX6?
post #7007 of 9217
Holt,
For the purchase of just a single pair of speakers at retail, I wouldn't expect mor than 10-15% off. For a package deal, like speakers + AVR, maybe 15-20% off. The retailers have overhead to cover, so they can't discount too heavily unless they are doing high volume. Most aren't.
post #7008 of 9217
Holt,
that's a good point-I wonder why they've been available on A-gon for so long? I see a few RX6s new on eBay.
post #7009 of 9217
Good news indeed. I thank you for your input. I find the comment interesting that biamping (passive) wont improve speaker performance. I guess that's why I ask the experts in here - to learn something.
post #7010 of 9217
Old speakers vs New.
I've been hunting for new speakers for quite some time now and the RX6's seem to be my choice. That being said, I have an older pair of Technic SB2822(you know one's with the 10 woofer, 4' midrange and 2' 1/8 tweeter), for now I'm playing these guys in stereo with a Harman Kardon 3600 and I must admit, the sound is pretty good. Especially the lows. Specs:8ohms, Power 200watts, crossover 3000hz-6000hz, 91db/w (at 1.0m).
My question to you is this: How much better of a quality sound will I get from the RX6's? Outside of it's looks,It just got me wondering if it's worth it to plunk down $1500 on fronts when these sound fine to my ears.
post #7011 of 9217
Well, the truth is that speaker technology has not changed a whole hell of a lot since the inception of the dynamic driver, so there is a chance that your old speakers could be competitive with a modern design, but the only person that can answer your question is you. I suggest that you burn a CD of your favorite songs, listen to them at home first, then hop in the car and head down to the dealer and play them on the RX6's while your memory is still fresh. Your choice should be clear when you are done.
post #7012 of 9217
"Well, the truth is that speaker technology has not changed a whole hell of a lot since the inception of the dynamic driver..."
True, the basic technology hasn't changed, but that technology has become much, much more refined. I think of it like cars: Still a gas engine, 4 tires, etc, but newer cars tend to be much more refined than cars from 20 years ago. And in some ways, even cheap new cars have advantages over old cars that were expensive at the time.
post #7013 of 9217
To the moderators,
Please remove this post as it is likely against Forum policies. Thank You.
post #7014 of 9217
Well, I wouldn't quite use cars as an analogy because the cars of today are better than the cars of yesterday in almost all aspects, but I have heard that speakers have not changed that much.
If I can still remember clearly, the RX6's brought out a cleaner sound when I was auditioning with jazz music. I often find that vocals sounds pretty good with almost any speaker but pianos often sound muddy.
Another thing that has changed is the looks. The speakers of today look very nice as to compare with my boxy Technics.
post #7015 of 9217
We've been Monitor Audio dealers for about 2 years now. We initially piked up a set of Silver RS LCR speakers as the front speakers for our showroom and Bronze BR FX for the rears. Shortly after we picked up the line, the RX series was introduced. We happened to be in the process of moving our showroom to a new location and because of the associated expense, we decided to not update the RS speakers at that time.
This past week we finally did make the jump to the RX line. We now have RX8's for the front left and right and the RX Center for, well... the center. The BR FX were updated to BX FX.
The difference in the two lines is impressive. Aside from the better low frequency extension that one would expect from a larger speaker, there is much more mid-range detail and a better sense of openness as well.
I could kick myself for not picking the newer speakers earlier, but now that we have these I'm quite pleased with our showroom system. We also have the BX and Radius HD lines on display along with several of the CI architectural products. We are planning on adding something from the Gold line in the not too distant future as well.
So, if you're in Colorado Springs, give me a shout for a demo.
post #7016 of 9217
Antone?
I'm currently looking for a house - to buy - in which to have a dedicated theatre room - hopefully...
I'm curious however, what surround configuration you guys favour? I currently have a pair of RSFX but am planning to buy a second set.
I know the THX guidelines suggest using these speakers on the side walls just above head height but I'm curious as I've seen that some of you run two sets of surrounds along each side - which I can get going with more speakers - I'm 'limited' (lol) to a 7 speaker set-up as I like to have my front 3 bi-amped (I have the Pioneer SC-LX90).
So, the question is - 2 sets of this type of surrounds on each SIDE wall or a set on the sides and two at the back? Any opinions?
Also, I notice that some other speaker surround packages like the Mordaunt Short Performance or MA Platinum, use either floor-standing or standard bookshelf-style speakers for surround duty. Do these go on the wall, at the sides or back or do they typically go to the back with this type of speaker?
post #7017 of 9217
damienbuckley, many of your questions are dependent on the size of the room you end up with. For example: having multiple side surrounds is often indicative of a large room with more than 2 rows of seats. If your room is smaller then you may not need more than a single side surround.
When a second set of side surrounds is added, it is typically sourced from the same feed. In other words, the two speakers on the same wall are playing the same thing: they are there to cover a larger area.
For you, I'd likely say that you should stick to the standard surround setup with a single pair on the sides and a single pair in the back.
post #7018 of 9217
any rx1 owners finding it to be way too boomy ?
post #7019 of 9217
Boominess, especially in something small like the RX1, is usually a result of speaker placement and room acoustics more than the speaker itself.
post #7020 of 9217
I have change speakers from jamo e8 (e850, e805 and e8 center) series to new bx range (bx6, bxfx and bx center) and i must say i am very very satisfied with the speakers, they sound so clear and the bass is tight and the whole surround sound is so good (the transition from front to rear and left to right) and my mirage omni s12 woofer is complementing them very good. The jamo e8 center could sometime sound boxy but the monitor audio doesent. I was a happy jamo owner for a decade and now i am a happy owner of monitor audio. I didnt know which one to pick rx or bx series but i decided to buy bx and save some money and i am still glad and very happy!
  Back to Forum: Speakers
