I'm running my old fronts.... The RX8's.....
I have the crossovers set to 50hz, so I actually use most of the range of the speaker and it matches ok - however if I was buying from scratch, I'd choose either the RX1 or the GX50 ( depending on budget) and set the crossover at 80....
A friend of mine which doesn't have much room behind his couch, is opting for the GXFX speakers and putting the on the wall... His house is still under renovation so the speakers are not installed yet, so I can't say how they perform.... However, if the fronts are anything to go with, the mid and HF should balance very well together indeed....
When I was running my RX centre, I was pretty happy with it, and no complaints really... Now doing the home test on th GX350, the HF and mids are very well integrated in the front channel, and this causes a perceptual increase in the sound field and the transition in the front sounds seamless...
. I am a very big fan of Monitor Audio speakers. A few years ago I bought a pair of Monitor Audio BR1 speakers that I ran with a Denon dm38 dac amp/cd player and was blown away by the rich full sound coming from these unassuming bookshelf speakers. I have this system in my small bedroom and it serves its purpose well.
